Author Topic: Haven’t bought a kapex bladw in awhile. Wow  (Read 2432 times)
Offline PA floor guy
« on: February 10, 2018, 05:50 PM »
146 dollars.  What!!!!   I could not believe it.  Where do you guys send your blades for sharpen.
Offline tjbnwi
  • Cedar Tucky Indiana
Re: Haven’t bought a kapex bladw in awhile. Wow
« Reply #1 on: February 10, 2018, 05:57 PM »
Offline Brian Livingstone
« Reply #2 on: February 10, 2018, 06:41 PM »
Try $ 218 plus 15 % tax in Nova Scotia,Canada.
If I happen to cut myself with it, I do have free health care to get stitched up.
Nothing like a new blade !
Kapex, TS75, MFT, OF1010, OF2200, DTS400 REQ, Parallel guide rails, 800, 1080, 1400, 1900, 3000 guide rail, Domino 500, CT36, CT Midi, , RS2E, RO150, Boom Arm, Crown stops, 6 drawer Sortainer, Carvex, Syslite II, Festool safety glasses must start to wear.
Offline Mario Turcot
« Reply #3 on: February 10, 2018, 07:39 PM »
Brian, check out ToolsToday.com They sell AmanaTools blades made for the Kapex. I would not be surprised the blades are from the same manufacture then the Festool ones.
Kapex Blade They have TCG and ATB configuration. The TCG is on my whish list  [big grin]
Oh and their price can be displayed in CAD, shipping is pretty cheap and fast. I usually get the order the next workable day.
« Last Edit: February 10, 2018, 07:42 PM by Mario Turcot »
Mario
Offline Peter Halle
  • Another Avatar Coming Soon
« Reply #4 on: February 10, 2018, 07:51 PM »
Festool blades are manufactured by Leitz.  When choosing a sharpening service make sure that they can sharpen the Festool blades - particularly those of the Kapex.  Some can't due to the variable tooth spacing.
Offline rst
« Reply #5 on: February 11, 2018, 12:07 PM »
I'm with Mario, I buy all my blades and most of my router bits from Toolstoday.  Their Electroblu aluminum cutting blades are amazing.  I've been cutting different thickness' of aluminum for 38 years using everything from plywood blades mounted backwards, to Sears carbide wood cutting blades to standard aluminum blades but these are the best...I really have trouble any other blade could work better.  In the past I would use WD-40 as a lube for cutting every thickness, now I only lube if the thickness is .375 and up.
« Reply #6 on: February 12, 2018, 07:46 AM »
I checked out that place.  Can someone tell me which blade they buy.  I feel weird cheating on tool nut. But 146 for a blade is out of control.
« Reply #7 on: February 12, 2018, 10:31 AM »
I know Forrest will not sharpen Kapex blades.
Offline Peter Halle
« Reply #8 on: February 13, 2018, 12:13 PM »
 By the way item 203150 is still a available here in NA.  1 60 tooth and 1 80 tooth.  Current price is $210 USD.
Offline Tracky
« Reply #9 on: February 13, 2018, 12:43 PM »
Two suggestions:
  • Harbor Freight circular saw blade sharpener. Don't use the index system, but slowly touch each carbide face to the diamond blade. That is how I sharpen my blades, even the regular spaced ones.
  • Handheld diamond sharpener? Unless chunks of carbide are missing, you should be able to use a fine sharpener such as DMT diasharp. Use those for router bits too. Just be careful not to change the the angles. Same amount of strokes on each tooth, like a chainsaw.
Offline RKA
« Reply #10 on: February 13, 2018, 02:38 PM »
@Tracky
What grit do you use/suggest for a final pass on carbide bits and blades?  I'm finding some say 600 but others suggest 1200.
I just mangled a dovetail bit (clamp slipped - bit meet washer).  DMT makes a diamond flat file (V shaped) but the finest grit is only 600.  Their rectangular flat files go up to 1200, maybe higher, but the form factor isn't ideal for some router bits.
-Raj
Offline Tracky
« Reply #11 on: February 13, 2018, 03:02 PM »
@Tracky
Saw blades don't seem to have a super fine finish from the factory. I've been using 600 (fine). Router bits probably would benefit from 1200 (xfine), but I've mostly been recovering low-$ router bits after use on MDF and 600 has been fine.
Regarding the form factor. You may want to look at the 'credit card' models. Just bought one, but haven't tried it yet. They are a lot thinner and also come in 1200. See here. I got a 600 as part of a set.
Offline RKA
« Reply #12 on: February 13, 2018, 04:26 PM »
Thanks, I'll give it a go.  Hopefully the backing material is stiff enough.
-Raj
Offline Bhend18
    • Hendricks Construction
« Reply #13 on: February 13, 2018, 09:11 PM »
and you can send them to Leitz to have them sharpened. I have
Domino DF 500, CT 36 E, Boom Arm Set, CT MIDI, OF 1400, LR 32, FS 2424/2-LR 32, FS 1400/2 LR32, TS 55 REQ, TS 75 EQ, HKC 55 EB, FS 800, FS 1080, FS 1900, FS 3000, FSK 250, FSK 420, Parallel Guide Set, MFT/3, Kapex KS 120, Kapex UG, CXS, PDC 18/4, Drilling Dust Nozzle, CMS-GE, Carvex PS 420 EBQ, Pro 5 LTD,RO 90 DX, RO 150 FEQ, RTS 400 REQ, RS 2 E, LS 130 EQ, RAS 115 E, HL 850 E-F Plus, MX 1200 E EF, CT Wings, Vecturo OS 400, SysLite KAL-2, SYSRock
Offline tjbnwi
« Reply #14 on: February 13, 2018, 09:27 PM »
Quinn sharpens the Festool blades. They do a great job (equal to or better than what I get back from Leitz) with less hoops to jump through then sending the to Leitz.
Offline fshanno
« Reply #15 on: February 14, 2018, 01:09 PM »
For both?
« Reply #16 on: February 14, 2018, 02:03 PM »
For both?
You got it...it’s a deal. I’m ordering a set before the March price increase.
Offline Peter Halle
« Reply #17 on: February 14, 2018, 04:36 PM »
I was surprised to find the set in the catalog and on the website.  I thought that it had been discontinued before.  If I remember correctly it was a North American only set.  Before I posted I did confirm with Festool USA that it was still correctly available.  Funny thing is that I bought a set years ago and have never even tried the 80 tooth blade.  I've been happy with the 60 tooth blades for going on 8 years now.
PS.  The price increase on this sky is $10 on March 1, 2018.
Offline fshanno
« Reply #18 on: February 14, 2018, 05:52 PM »
I'm running the original 5 year old blade in my Kapex.  Never been sharpened.  Time for something new.  The set looks like a good deal.
But I'm curious about the Oshlun blade I see on Amazon for $55.  At that price it's worth experimentation.  If it proves to be inadequate it can always serve as a backup blade for cutting questionable stuff.
I bought the $25 Oshlun 48 for my 55 back in May and it's never been off the saw.  New out of the box rips were just as good as the Festool 48 tooth.  Crosscuts were very close, not quite as good as a new Festool but acceptable.  I figured I'd get one kitchen out of it.  I did get that one large kitchen but it's still going strong.  Very nice rips and respectable crosscuts.
Offline ear3
« Reply #19 on: February 15, 2018, 08:04 AM »
The set is a good deal -- just got another one a couple of weeks ago.
I have the Oshlun for doing aluminum cuts on the Kapex -- which I do only rarely -- and it has performed just fine.  I also have a few Oshlun for my tracksaws when I know I'm going to be dealing with embedded nails/screws in the material.  They do what I need them to do.
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T18+3 w/Centrotec Installer's Set • PDC 18/4 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS-EC 150/3 • ETS 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • CT 26 w/BT module • CT Sys w/Long-Life Bag • MFT/3
« Reply #20 on: February 15, 2018, 08:44 AM »
@PA floor guy, sorry I missed your question  [sad]
If you are looking to replace the original Kapex blade look at that link from Toolstoday.com. It comes on top for me, make sure to select the Festool #495388
Mario
