Pages: [1]   Go Down
  Print
Author Topic: How do you make this Domino plunge?  (Read 1341 times)
rjwz28
Offline Offline
« on: April 20, 2012, 02:25 AM »
I am gluing together 2 pieces of 3/4" hardwood together with a 22.5 degree bevel on one side.  They will be around 6 feet long and I would like to put a tenon every 10 inches for strength as it be holding a glass door.  How would you set up the Domino to make this 22.5 degree plunge?  Do I need a jig?  A picture or diagram would be really helpful.
thanks for your time,
Rob
PaulMarcel
Offline Offline
WWW
« Reply #1 on: April 20, 2012, 02:47 AM »
Just tilt the top fence down. It has a positive stop at 22.5.  Lock and plunge.
Coincidentally, I put up a video earlier today from the crib sheet series that talks about that fence and how to setup other angles.
Shirt size: L Cool
Twitter: @HalfInchShy
Kevin Stricker
Offline Offline
« Reply #2 on: April 21, 2012, 12:13 AM »
Make sure you set the fence height so that you are plunging into the top third of the joint.  If you try to center you could blow out the bottom, depending on the size of the Domino.
Also do not just trust that the 22.5 setting is dead on, instead set fence and hold fence to the top of the workpiece and make sure that all of the base is contacting the bevel.  I learned this the hard way joining a 14 foot long beveled frame, luckily I did a dry fit and saw the error and was able to just do a second set of mortices.
Also, the glue up is going to be a bit tricky with that long of a workpiece, not to mention clamping on a bevel.  Stack the odds in your favor by pre gluing the dominoes into one side( side with tight mortices) then you only have to worry about one set when gluing.  Also, only use a single tight mortice on one of your boards, with the rest in the middle position.
rjwz28
Offline Offline
« Reply #3 on: April 21, 2012, 01:42 AM »
Thanks Kevin, your suggestions are well received.
Rob
rjwz28
Offline Offline
« Reply #4 on: April 21, 2012, 01:44 AM »
Mahalo Paul.  If any of you haven't seen Paul's videos, you are missing out big time!
Rob
JSands
Offline Offline
« Reply #5 on: April 21, 2012, 08:40 PM »
Kudos to Paul for posting such great videos for the ww community.... great job Paul... thx
Pages: [1]   Go Up
  Print
Jump to:
