Author Topic: I own at Rotex 150. Is there any reason to get the ETS EC 150?  (Read 922 times)
Offline bwehman
I mean, aside from form factor preferences...
Offline Peter Halle
Re: I own at Rotex 150. Is there any reason to get the ETS EC 150?
« Reply #1 on: December 05, 2017, 03:14 PM »
Your comfort.  The Rotex is a great sander in my usage but if I don't need the aggressive mode I will skip right over to my ETS for the majority of finish sanding.
Offline Birdhunter
« Reply #2 on: December 05, 2017, 03:27 PM »
I use the RO150 for 60-100 then switch to the ETS from 120 to 220. I find the ETS is a lot easier to “drive”. It never wants to go wobbly as does the RO.
Birdhunter
Offline aloysius
« Reply #3 on: December 05, 2017, 04:38 PM »
An ETS EC with the much smaller 3mm of eccentricity will prove much more adept at finishing duties than a Rotex ever could.
FOG-wit since '95:  Some say since birth...
Offline Alex
« Reply #4 on: December 05, 2017, 05:08 PM »
^ Rotex will do any finish just fine, ETS will make it a bit easier though.
Offline denovo
« Reply #5 on: December 05, 2017, 06:01 PM »
If you do any vertical or overhead sanding then the ETS EC is a lifesaver
Offline Steven Owen
« Reply #6 on: December 05, 2017, 06:05 PM »
Because of the weight, Rotex is better suited to boards and unassembled projects.  If you’re sanding an assembled project with curves, vertical sanding and angles, you’ll appreciate the ultra-light weight functionally of the ETS-EC or Mirka Deros.
The Rotex shines on rough materials, polishing and material removal during renovation tasks.
Festool CT Midi, Festool ETS 125, DF 700 Domino Coming Soon
Offline Jim_in_PA
« Reply #7 on: December 06, 2017, 05:56 PM »
I have both a Rotex 150 and an ETS-150/3. As far as I'm concerned, these are "complimentary" tools. I only use the Rotex for heavier work where either the rotary mode or larger orbit is beneficial to a project. It's a two-hand tool and that's not practical for the majority of the sanding I do. The ETS 150/3 does 95% of the work in that respect. But I like both and am glad I have both available.
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
Offline ear3
« Reply #8 on: December 06, 2017, 06:11 PM »
Just get it.  You know you want to...
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #9 on: December 07, 2017, 01:12 PM »
I own a RO150. Due to the recon sale I went and got the EC 150 3. I used  it for the first time yesterday. I must say it is nice. For final finishing with high grit paper 220 and up, it does a very nice job. I cant say whether it does  a good enough job thats better than the RO150 can do. But I can say Ill be using the heck out of it for final finishing cleaning up th surface getting rid of the swirl marks etc
