Author Topic: Is there a Festool Tool or accessory that you regret purchasing.  (Read 22625 times)
Offline 3PedalMINI
    • Signature Sound & Video
Re: Is there a Festool Tool or accessory that you regret purchasing.
« Reply #90 on: September 24, 2017, 07:23 PM »
Carvex and the accessory kit :(
Everything else has been perfect!
The Bitterness of poor quality remains long after the sweetness of low price is forgotten -Benjamin Franklin
Professional Custom Audio Video System Designer/Installer serving Southern - Middle NJ, Eastern PA & the Surrounding Shore Points.
www.sigsv.com
Kapex 120,TS55,RO150,ETS125,CT-26,CT-MIDI,Tradesmen Cleaning Kit, Festool Ratchet Kit, Sys-lite, Sys Roll Cart, T18 +3, 2013 Centrotec Kit, Carvex 420, Carvex Accessory Kit, CXS,RO90, TI15 and Various Festool Systainers
Offline Holmz
« Reply #91 on: September 24, 2017, 07:54 PM »
The centrotec seemed ideal, and I got it marked down.
But other than "as an idea" it is crap... The SYSTEM is a bespoke size (6-mm) no one else in the world uses, and the bits rust quick.
Offline Marven
« Reply #92 on: September 29, 2017, 11:07 AM »
I bought the Festool Guide Rail Accessory Kit to cut 90deg angles on 4x8 roofing sheets. The angle finder is easily bumped out of square and is hard to set exactly right.  Didn't work for my purpose.
I bought the GRS-16 Guide Rail Square from TSO Products.  Works great.
Offline JimH2
« Reply #93 on: September 29, 2017, 11:10 AM »
Carvex and accessory kit and MFT accessory kit.
Offline maccruiskeen
« Reply #94 on: September 29, 2017, 11:46 AM »
Centrotec 3mm countersink with depth stop bought 8 or 9 years ago and still used on every job.
Little did it realise it would thin end of such an expensive wedge  [big grin]
Offline Womble
« Reply #95 on: September 29, 2017, 11:54 AM »
The dust bag for the Festool EHL 65 EQ GB Planer is a complete & utter waste of money.
Literally NO dust whatsoever goes into the bag & i really do mean NO dust no matter what angle you plane at all the dust is ejected out the bottom of the planer. The planer works fantastic with dust extraction hooked up but seriously do not purchase the dust collection bag.
Offline Gunder
« Reply #96 on: September 29, 2017, 02:31 PM »
Tape measure is horrible.  Tough to read, doesn't retract.
Parallel guide set.  Too darn short, clumsy, even with extensions sucks to cut narrow stock.
Offline Kevin D.
« Reply #97 on: September 29, 2017, 07:11 PM »
My older PB jigsaw I regret.
The parallel guides.
The quick angle gizmo for the tracks also.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Offline Gunder
« Reply #98 on: September 29, 2017, 07:40 PM »
Just bought the CXS and immediately returned it.  darn thing wouldn't even sink a screw.  Hoping the PDC I had my dealer order as replacement is a heck of a lot better.
Offline Peter Halle
« Reply #99 on: September 29, 2017, 07:46 PM »
I can say that returning the CXS because it doesn't suit your needs and then moving to the PDC is a huge jump in desired features.  I watched the PDC in action in the hands of testers at the Festool Connect event.  Smiles and really big eyes.  Probably a few sore wrists.
Offline DB10
« Reply #100 on: September 29, 2017, 08:00 PM »
 Well those two drills are like chalk and cheese, a CXS is better suited to cabinetry work than say site work and you didn't mention what size screw you were trying to sink, the CXS and PDC in a lot of situations can compliment each other.
Offline bkharman
« Reply #101 on: September 29, 2017, 09:32 PM »
I have both and love them both for their intended purpose.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline duburban
« Reply #102 on: September 29, 2017, 09:36 PM »
Parallel guides for sure
helper: i used a festool "circular saw" to do something simple and it made it really hard
me: exactly, it makes simple cuts complicated and complicated cuts simple
Offline VW MICK
« Reply #103 on: September 30, 2017, 03:25 AM »
Yep no 2 for the above
Although I have used the clamps out of the guild rail kit
Mick
Offline Gunder
« Reply #104 on: September 30, 2017, 11:47 AM »
5.5 x 9.5 ski binding screws. These are always pre-drilled with a 3.6 or 4.1 x9.5 bit. I bought the CXS as the torque on these screws is critical. I need a driver that will install them to the same torque every time. 7.5NM to be exact and this is right in the middle of the 15nm range of the CXS.  I also tried plane old drywall screws and it wouldn't even sink them into a 2x4.
When I purchase Festools I expect them to perform at least as good as the cheaper competition, but with more precision and better build quality.  Even a $100 Makita that I was using worked better.   My plan was to have a smaller drill for light tasks like this, and then have the PDC for all around usage.  But this experience is making me re-think going Festool for drills altogether.  Lets face it the XS series is very dated now, and for the price should be a at a minimum brushless. The 18 series is obsolete with the PDC.  The fact that Festool has no impact driver is also insane.  Maybe its time Festool takes its drill line more seriously and updates it to at least be on par with the completion.  I would love to see a compact, brushless XS sized drill / impact driver that actually has a torque setting for the impact driving side. This would be a serious game changer.
Offline Peter Halle
« Reply #105 on: September 30, 2017, 12:11 PM »
If you are looking to purchase a drill driver (any brand) that installs screws to a critical user defined torque that has to be exact to .5 NM then honestly you need to be looking at specialized equipment.  The odds of any manufacturer having a preset torque setting to exactly to your exact needs is slim.  I suspect that you will need to do extensive research.
But I hope that the PDC works for you.  My fingers are crossed.
Offline rst
« Reply #106 on: September 30, 2017, 02:47 PM »
I confused about the CXS bashing.  I've been driving screws...real screws 12s, 14s, lags etc. for 50 years.  I started using B&D battery driven in the late 70' and early 80s.  Graduated to 9.6 Makitas, then 14v Freud and Makitas.  I currently have at least 8 Milwaukees in 12 and 18v and use them for commercial/industrial work...wood, aluminum, steel, plastics.  I just bought the CXS just for the right angle function and for S&Gs.  The comment about it not driving drywall screws is either user error or a bad drill.  Just to check, I just went out to test mine.  I use 4 1/2" #12 screws to fasten aluminum storefront frames.  With the torque setting on 12 and low speed I drove one in 2 inches before camming out when the thicker part of the screw hit.  I then backed the screw out.  Not sure how many times the driver would do this but it is NOT under powered for it's size.
Offline SRSemenza
« Reply #107 on: September 30, 2017, 03:12 PM »
I can't see there being much in the way of user error with the CXS so more likely a bad drill or battery problem. I have not used a CXS myself but I have watched it drive some really large and long screws.
Offline six-point socket II
  • aka @the_black_tie_diyer
« Reply #108 on: September 30, 2017, 03:24 PM »
5.5 x 9.5 ski binding screws. These are always pre-drilled with a 3.6 or 4.1 x9.5 bit. I bought the CXS as the torque on these screws is critical. I need a driver that will install them to the same torque every time. 7.5NM to be exact (...)
What you obviously want/need is a cordless driver like they use in production lines. The chance that either CXS or PDC have a torque setting that equals 7.5 Nm exactly is close to nonexistent.
For this task you'd be best suited with a Exact ION 12-450 from Bosch for example: http://www.boschproductiontools.com/com/en/iwocs/exact-ion-12-450-usa-38427-ocs-p/
Be sure to read the manual on how torque preset is set on these to ensure it meets your demands.
EDIT: I forgot to add, in your desired torque range these can be had with up to 1100 rpm - in case 450 rpm isn't fast enough.
I'm also sure there are other brands who make production line/exact torque cordless screwdrivers. But I'm just familiar with Bosch's line up, I apologize.
If you get one, I'd love to read a review/your thoughts on it - there is a special section here on the FOG for reviews about other brand's tools.
Kind regards,
Oliver
« Last Edit: September 30, 2017, 03:32 PM by six-point socket II »
Kind regards,
Oliver
Offline Holzhacker
    • www.aic-chicago.com
« Reply #109 on: September 30, 2017, 07:17 PM »
For me probably the WCR. Nothing wrong with it but my work has changed so it just doesn't get used enough to be worth it.
Offline Harry1561
« Reply #110 on: September 30, 2017, 08:56 PM »
 The guide rail accessory kit,  the adjustable rail square is not fit for purpose a waste of money.
Offline Cochese
    • The 144 Workshop
« Reply #111 on: September 30, 2017, 11:25 PM »
Probably the Pro5. Just from the standpoint that I shouldn't have invested in the 125 paper when I had plenty of 150 paper and hould have put that towards a Rotex.
Offline Monju123
« Reply #112 on: October 01, 2017, 07:45 PM »
CSX. Greatly prefer my M12 Milwaukee tools. And the Centrotec system is a joke. Exorbinently priced for no gain in performance.
TS55, TS75, Domino 500, OF1400, RO150,CT22, MFS 200-400-700, LR32,Parallel Guides, MFT3, Domino 700, RO90. CXS, CT26,  Kapex, UG with KA-UG RL
Offline lnmnmarty
« Reply #113 on: October 01, 2017, 08:22 PM »
Thanks to festools return policy one should never regret a tool. For those prices if the tool doesn't really impress me it goes back. They want this forum about the tools we like not the ones we hate.
Offline Coen
« Reply #114 on: October 01, 2017, 09:40 PM »
Wow, so often the Carvex. Seems I did the right thing by buying a Trion. But the Carvex came just a bit later.
Offline bkharman
« Reply #115 on: October 01, 2017, 11:04 PM »
FWIW, I like my carvex. It had treated me well with coping and 4x6 timbers and everything in between.
Cheers. Bryan.
Offline john5mt
« Reply #116 on: November 28, 2017, 12:26 PM »
Carvex
Barley lasted past its warranty. Totally exploded. Have a Bosch thats 10 years old and still working flawlessly
Smoking the green crack
Offline Wooden nickel
  • Luck wood have it
« Reply #117 on: November 28, 2017, 12:51 PM »
Not sure if I should laugh or cry at this point. LoL
Just bought parallel guides, carvex from recon, cxs from woodcraft.
But for the guides I understand they can be used with the lr32
And I like the cxs for cabinet work
And lastly the carvex is on its way.... let’s see how it turns out.
Offline Coen
« Reply #118 on: November 28, 2017, 04:17 PM »
Perhaps the Domino + systainer full of domino's that I only used once... for like 70 Domino's total or so. That's about 15 euro's per domino placed...
Or the refurbishment of the T12 (NiCD) that I was given. I spend too much on a new switch (~65), new outer housing, etc. Also had to re-cell one batterypack, only to find the other one rather weak a little later.
I regret buying my EHL-65 before it was released with plug-it. I like the plug-it system, and the EHL-65 is the odd one without it in my collection.
Other than that; no, not really. But then again I didn't buy the first Carvex. (Nor the current one, as my Trion is doing fine.)
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #119 on: November 28, 2017, 10:21 PM »
Parallel Guides, I bought mines before the after market ones came out a pain for me to calibrate I think I finally got them calibrated but the extensions are a pain to use b/c of the big saddle.
I bought the 850 planer, and the bench stand and the angle stop (fence) I sort of regret bc I bought it to well joint boards thinking with the full length angle stop I would be able to and the bench unit for jointing small boards. Yes it will work but this tool and accessories does stay in a systainer sitting on a shelf most of the time. But I will say it does a good job when fitting doors so its not a total loss.
The boom arm I thought it was a great idea but now looking at some of the ideas the guys here have come up with well it isnt really making me happy. Maybe if in the future I have a larger shop the it may make me happy.
The 2200 kit, I only used one base for it the rest sit in the Systainer. But I dont keep my 2200 in the CMS, but when I use it for free hand routing the pieces of the kit does come in handy. Most of the kit sits in the systainer on a shelf next to the 850.
If i think of more Ill add to this most, well one I dont regret but wish FT had other options id the CS 50 fence for the TS 75 CMS mosule which I dont have
