Author Topic: Jig saw circle cutting  (Read 8190 times)
Offline richard.selwyn
« on: July 26, 2010, 05:49 PM »
I've read some comments about the new jigsaw and the circle cutting jig.  If I understand correctly the circle cutting foot is being/has been modified.
I have 10 x 150cm diameter circles to cut this week and want to know if it is worth going out and buying the new saw "set" right now or struggling with my existing Trion and then the 1400 router on a jig.  Last time I did this it was in MDF which routed fine.  This time its 18mm ply so I am not so sure.  I cannot seem to get the trion (or my bosch) to cut close anough to the line hand held.
Any guidance greatfully received.
Richard.
Offline Michael_MA
Re: Jig saw circle cutting
« Reply #1 on: July 26, 2010, 07:03 PM »
Richard.
Hello Richard,
I've already made some experience with the Carvex Jigsaw and the circle cutting jig..  you can find the review of this Jig saw in the Review section along with some videos. I did quite some Half Circle cuts with 500mm Radius and found it to be easy and effective.. after modifying the base as explained in my Video. Be sure, you are using a saw blade with interleaved teeth for the Curve cutting (like the Trion S75/4 FSG or S105/4 FSG)
kind regards, Mike
Glad to be back - pleasure to see familliar names..
Festool addicted since 2004
Offline Tom Bellemare
  • Inactive Member
    • Tool Home LLC
« Reply #2 on: July 26, 2010, 07:42 PM »
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #3 on: July 26, 2010, 07:43 PM »
If you have a router why not use it?  Do a search on the forum and you'll find a number of great homemade circle jigs for the 1400.
Offline mosez
« Reply #4 on: July 27, 2010, 04:35 AM »
i used the trion with the 15 euro circle cutter to make 70 cm radii. i just kind of put the matal rod together with a longer one with a self-build clamping mechanism that holds pretty tight (a square aluminum "pipe" with the to rods overlapping inside and machine screws pressing them towards the bottom of the "pipe").
the circles i cut were perfect.
turn the pendulum action to zero and check if you have to use a festool k blade (black, yellow, very sturdy but only half the size of a normal blade). But with a 150cm circle, you might not need it.
PS 300 EQ (Circle Cutter, Guide Stop), CTL Midi (Cleaning Kit), TS55 EBQ (1400mm, 800mm Guide Rails, SYS-FS 2, 2 FS-HZ 160, 2 FS-SZ 120 2 FS-SZ 300, Panther Blade, Universal Blade), RO 90 DX FEQ (selfmade SYS-STF 90), RO 150 FEQ (SYS-STF 150), paddle-style DF 500 Q Set (Domino Assortment Sys), OF 1400 EBQ (Circle Cutter, Guide Stop, Edge Guide), MFT/3 (Clamping Elements), CMS-GE, CMS-OF, CMS-TS55, CMS-PS300, CMS-LA, CMS-ST, CMS-VB, Fein MultiMaster 250Q (T-LOC Systainer, Plug-It-Pigtail), Bosch GBH-26 DFR, GWS 15-125 CIH, GHG 660 LCD, Dremel
