jmbfestool
Online
« Reply #150 on: March 14, 2011, 02:58 AM » |
The shower tray was also fitted before i tiled the floor so I tiled up to the shower tray to make it look more slim lined.
Jmb Hi jmb, No the way it should be done is that you tile the top of the ply box then you can lower the bath down into the hole and the rim of the bath should sit slightly off the tiles supported by its legs not the tiles. This leaves you with a neat joint under the bath rim which is sealed with silicone. Then once the bath is connected and tested the front of the ply can be tiled, usually an access panel is left ie one tile is stuck with silicone so it can be removed. Ive done a few built in baths in the 20+ years ive been a joiner I hope I know what im doing lol. Chris JMB,
JMB,
JMB,
Well you see a few reasons! 1. The bath only cost me 40quid from BnQ because it was damaged! Well gues where the damage was! On the side I have against the wall! 2. I don't like the curve I actually hate it so having it It in the corner kinda hides it but 40quid is nothing as the bath was worth £300 or more. It's a very deep bath. I have sunk the bath into the floor otherwise you would have to try and hurdle over the bath. Well I always seen tiles go onto the bath better water seal so are you saying should I of tiled the front top of the bath first then put the bath on to of the tiles i then tile the back wall so the tiles go on top of the bath
I wasn't sayin u didn't know. Just I was not sure if you was on about all the tiles or just on the boxing. So I agree with u on the boxing just not on the Walls as I have always seen bath in first then the Tile the Walls on to the bath. I prefer flush look though so I did it the wrong way  . I did say in my previous post wat do you mean tile the lot then do the bath or just the boxing. Oh I didn't use the legs on my bath legs are crap hey lift the bath to high. The boxing at the front supports the bath and a frame right around the bath supports the bath and I made my own supports under the bath and sunk the bath in to the floor joist the bath is actually about 5inch lower than the tiled floor height. If I had used legs e bath would of been 10 inch higher if it was sat on the floor. Jmb
« Last Edit: March 14, 2011, 03:48 AM by jmbfestool »
jmbfestool
Online
« Reply #151 on: March 14, 2011, 03:06 AM » |
i normlly fit the bath test it all then box it in leaving the correct gap for a tile to slide under the rim of the bath. I try not to use ply either as i had a delaming issue on a job(nothing major) so always use a tile backing board now for piece of mind and i believe it is a much better job
Yes I have done that before left the boxing low to slide the tiles under suppose the same as tile before then putting the bath in. I would not like to just tile the top leave the rest then put the bath in then tile the rest of the bath room like every one says (joiner1970) because you would have to work out where your tiles on the Walls are going or floor maybe to make sure your are inline with the wall when they get tiled. Suppose it depends how big your boxing is an how much if that was a problem or not. I never said my way was the right way! Just a nicer way  in my opinion.
« Last Edit: March 14, 2011, 03:26 AM by jmbfestool »
jmbfestool
Online
« Reply #152 on: March 14, 2011, 03:54 AM » |
Get things straight! lol I did the bathroom as cheap as I could with out trying to compromise on looks! So I got a cheap bath I hate the rounded corner but it saved me a lot of money as I wanted a large deep bath which normally are not cheap. I dont love the shower enclosure to much metal! I prefer just glass! I wanted a walk in shower just not got the room really. I dont like the edge of bath showing so I sunk it into my boxing so I could tile up the the edge (apparently the wrong way  ) give a sleeker look The tiles well they are okay I wanted these other tiles but they where like £28 per metre. These only cost me £14/15 per square metre I am not happy with the grout lol but it does look okay! Basically I hate being on a budget! If I had the money to spend I would of done and got a few things different! Bath is one of them! I like the Toilet! Oh and I like the sink! that was only £40quid! I do like the bathroom dont get me wrong just I couldnt get what I wanted! I also wanted LEDS in the insets on the walls but just time and money to put them in. overall turned out okay! My girlfriend LOVES it thinks it amazing! So thats all good lol! JMB
« Last Edit: March 14, 2011, 02:59 PM by jmbfestool »
joiner1970
Online
« Reply #153 on: March 14, 2011, 01:33 PM » |
Yeahj thats another way I have done them as well I dont get involved too much I just do the boxing for the plumber. I can plumb and I can tile very well if I do say so myself but when Im on a new build we have plumbers and tilers so I dont need to do any of that. Regarding the plywood we have never had a problem with delaminating but a lot of the time we do use wedi board or cement board as it is a better job.
joiner1970
Online
« Reply #154 on: March 14, 2011, 01:41 PM » |
I think they are the same parent company who do Moben kitchens and always sub the work out.
I hear they pay very poor rates and consequently only get fitters that cant get work anywhere else.
I suppose if that is right then the tilers are of a similar breed.
Yeah and Sharpes bedrooms another bunch of rip off merchants. I felt sick when she said what she was paying for it. Sadly she would have used us but she didnt know us when she booked Dolphin. They tried to get her to book the kitchen in with them as well but luckily for me she didnt. I finished her kitchen Friday, built her a new master bedroom made up from two beds knocked into one with an entertainment wall, plasma tv etc, walk in wardrobe to do and they want us to fit out their new offices at the company they own. So not a bad little job
jmbfestool
Online
« Reply #155 on: March 14, 2011, 03:06 PM » |
Yeahj thats another way I have done them as well I dont get involved too much I just do the boxing for the plumber. I can plumb and I can tile very well if I do say so myself but when Im on a new build we have plumbers and tilers so I dont need to do any of that. Regarding the plywood we have never had a problem with delaminating but a lot of the time we do use wedi board or cement board as it is a better job. I prefer Cement board over ply! I think ply around a bath is fine though never had a problem! The company I use to work for ALWAYS used ply even in the shower enclosure! Well I never agreed with that! I always said we need cement board but it was just dismissed. It was crap using ply in a shower enclosure always had to pack the plasterboard to get it flush with the ply because they only wanted to use ply in the shower area and plasterboard the rest then plaster it! I always thought because one was plasterboard and other was ply it might crack the tiles or grout as they would move differently two difference surfaces but it didnt. On my own jobs I only use cement board and often tank the shower area. JMB's
jmbfestool
Online
« Reply #156 on: March 14, 2011, 04:10 PM » |
Yeah and Sharpes bedrooms another bunch of rip off merchants. I felt sick when she said what she was paying for it. Sadly she would have used us but she didnt know us when she booked Dolphin. They tried to get her to book the kitchen in with them as well but luckily for me she didnt. I finished her kitchen Friday, built her a new master bedroom made up from two beds knocked into one with an entertainment wall, plasma tv etc, walk in wardrobe to do and they want us to fit out their new offices at the company they own. So not a bad little job  I was working for a company at the time so did not really have time to do my mums bathroom but I did end up doing it any way! This was because we had dolphin to come and price to do the bathroom they wanted £25000  My dad was like £20 000 you have a deal! My mum went mad and said you thing im stupid are takin the P I dont wanna pay more than £15000 the Dolphin sales men was like no chance can we do it for that price! My mum said well your ridiculous no way can you justify that price he was sayin its all high quality stuff and everything the sales man eventually said he would do it for £18 000! Well my Dad jumped in and said DEAL my mum was not happy as she thought she could get them down to £15000 so my Dad was in the bad books! Any way they said 2 weeks and they could start when they have all the stuff in 2 days later they said the tiles you have chosen we can not get hold of them we have these others very similar! My mum said no if you cant get the tiles I chose then I want my deposit back they said they would knock £1000 of the price but my mum said no if im paying that much I want what I want they eventually sent her refund. Crazy prices Dolphin are CRAP JMB
joiner1970
Online
« Reply #157 on: March 14, 2011, 05:10 PM » |
You wouldnt mind paying the money if it was high quality but its not , i watched this guy using ordinary plasterboard to clad all the boxing for the cistern etc before he tiled, a complete cowboy. The woman was told by dolphin it would take 19 man days to do it which is ridiculous , the fitter did it in a week.
jmbfestool
Online
« Reply #158 on: March 20, 2011, 05:33 PM » |
New! New! New! And Gues what its GERMAN made! I think I might aswell live in Germany! All the stuff I buy is always German lol! Apart from some ladders I just ordered from Rex Crystals! I wanted the Zargers cus all my steps are Zargers and they are MINT BUT these tripple ladders by zargers weighed 36KG and the UK brand Lyte are 28Kg and £80 cheaper so. I caved in and went with the UK brand I gotta support UK  no really it was the weight the Zargers where just to heavy really plus the Lyte are shorter but also extend longer so just seem all round better larder for the money. I was also told the zarger parts where made by lyte for the UK and for how much I would actually use triple ladders they dont have to be as heavy duty. Any way BACK to the NEW NEW! I have a NEW Tow Bar lol! I know its nothing exciting but dont it look sexy?! edited: I forgot to mention the hole! Its where my reversing Camera goes but He had to remove my rear bumper completely so the camera had to come of aswell because as you can see the main bar runs inside the bumper so he also had to cut the bumper he did it all at my place so that was handy! I just aint got round to putting the camera back on yet because the bar is in the way now to tighten the nut behind the camera so I gotta think of another way to fix it back I told him I would do it as he was going to fix it onto the bumper then fit the bumper but then I wouldnt be able to get my camera back off with out removing the entire bumper again because I broke to camera so it doesnt always work properly so I need to replace it really so I would like to take remove it easilly when I replace it.    JMB
« Last Edit: March 21, 2011, 03:10 AM by jmbfestool »
jmbfestool
Online
« Reply #159 on: March 20, 2011, 05:44 PM » |
woodguy7
Offline
« Reply #160 on: March 20, 2011, 05:49 PM » |
Its a tow bar dude  What did that cost ya ?
If its made of wood, i can make it smaller. Shirt size medium p.s- ive started reading these too
Ken Nagrod
Restricted
Offline
« Reply #161 on: March 20, 2011, 05:52 PM » |
I guess this is the only time showing your bottom is ok.
jmbfestool
Online
« Reply #162 on: March 20, 2011, 06:00 PM » |
Its a tow bar dude  What did that cost ya ? I know aint it a great tool? lol Ill be putting it to good use! £350 including Vat tow bar kit and fitting. I wanted 1 which folded away cus I know what I am like ill properly loose the key or loose the tow bar lol but they dont make one for scudo! JMB
jmbfestool
Online
« Reply #163 on: March 20, 2011, 06:01 PM » |
you know you love it!
windmill man
Offline
« Reply #164 on: March 20, 2011, 06:12 PM » |
Stop It Stop It Keep getting flash back to JMB`s mirrored TV in the bath!!!!!!!!! I guess this is the only time showing your bottom is ok.
you know you love it!  John
jmbfestool
Online
« Reply #165 on: March 20, 2011, 06:19 PM » |
you know you love it!  John uwwww lol dirty mind ! JMB
windmill man
Offline
« Reply #166 on: March 20, 2011, 06:23 PM » |
Brett , Your van needs a wash as well  . It will go faster with out the muck  . John
joiner1970
Online
« Reply #167 on: March 20, 2011, 06:31 PM » |
I think I might aswell live in Germany! All the stuff I buy is always German lol! JMB
Apart from your van  Get yourself a real van a Volkswagen  Festools fit better in a VW
Ken Nagrod
Restricted
Offline
« Reply #168 on: March 20, 2011, 06:38 PM » |
JMB's doing all this stuff to his van, buying all these tools in the UK and he's moving to Australia to be a nanny site chippy. Doesn't make sense to me.
Dan1210
Offline
« Reply #169 on: March 20, 2011, 06:57 PM » |
darn jmb you got a money tree in your back yard! I did 2 installs for moben worst experience of my working life! They charge the customers ludicrous sums and pay their fitters peanuts, my installs were top notch i struggled to make any money out of my moben fits but i made sure the customers were happy! Never again tho avoid at all costs...
Festooligan since 2006
djc-interiors.co.uk
LostInTheWood
Offline
« Reply #170 on: March 20, 2011, 10:07 PM » |
Hey JMB, congrats on your new tow bar haha! Tell me how that thing stays locked in the socket. I can't make out the diagrams in the pictures. Just curious cause here in the states we have a very caveman yet reliable connection for the hitch. It's just some steel square stock for the hitch and fits into a larger piece of square stock on the tow bar. The two are secured together with a steel through pin. So do tell. It's cool look'n.
jmbfestool
Online
« Reply #171 on: March 21, 2011, 03:06 AM » |
Brett , Your van needs a wash as well  . It will go faster with out the muck  . John Yo windmill Yeah I know the fitter said that when he removed my bumper and loads of mudd fell out he said it's much lighter now so yiunwill go faster. Jmb
jmbfestool
Online
« Reply #172 on: March 21, 2011, 03:07 AM » |
Apart from your van  Get yourself a real van a Volkswagen  Festools fit better in a VW  Yeah true! Forgot about my van Dam It! Jmb
jmbfestool
Online
« Reply #173 on: March 21, 2011, 03:08 AM » |
JMB's doing all this stuff to his van, buying all these tools in the UK and he's moving to Australia to be a nanny site chippy. Doesn't make sense to me.  Haha Well I was thinking if I was to go i would just take my van with all my tools inside all in one go and I'm ready to when I'm over der! Jmb
jmbfestool
Online
« Reply #174 on: March 21, 2011, 03:26 AM » |
Hey JMB, congrats on your new tow bar haha! Tell me how that thing stays locked in the socket. I can't make out the diagrams in the pictures. Just curious cause here in the states we have a very caveman yet reliable connection for the hitch. It's just some steel square stock for the hitch and fits into a larger piece of square stock on the tow bar. The two are secured together with a steel through pin. So do tell. It's cool look'n.  Very simple actually I think. It has a tapered bar inside which moves back and forth when I push the lever into the red stone back into the green zone. Their are 3 balls you can see 2 on top in the picture and 1 underneath. Well when I push the leaver forward the bar inside moves back and the balls fall down flush. This then allows me to push the tow bar into place. Inside the bracket on my can it has a groove for the balls to go into. When I release the lever a spring forces the lever back and the rod forward the rod pushes the balls outwards into the groove. Their is no way The tow bar could come of now as the Walls can not retract while the bar is behind them pushing them outwards. It feels very solid no movement at all. Plus you can see the green section is half way well when fitted the lever only goes part way on the green so it's constantly trying to tighten up while it's on. It comes with a key so the leaver can not be pushed passed green into to the red area where it would release. Jmb
CNC Paul
Offline
« Reply #175 on: March 21, 2011, 07:08 AM » |
Hi JMB [/url] But I am looking for a minimum size of 8'x4' I would like a larger one but I can not afford that so as long as it can take 8'x4' sheets of MDF or ply + auto 0 for tools + auto tool change + Vacuum base + circular saw + more lol This is what I am interested in I spoke to the company the other week I told him what I wanted to do and everything and what I wanted and he recommend the Nested base which comes with everything I want on it! http://www.multicam.com/eng/Products/nestedbase.htmlJMB, Have a look at these http://www.shopbottools.com/ you are more than welcome to see mine working. Paul
« Last Edit: March 21, 2011, 07:16 AM by CNC Paul »
jmbfestool
Online
« Reply #176 on: March 21, 2011, 01:56 PM » |
Hi JMB [/url] But I am looking for a minimum size of 8'x4' I would like a larger one but I can not afford that so as long as it can take 8'x4' sheets of MDF or ply + auto 0 for tools + auto tool change + Vacuum base + circular saw + more lol This is what I am interested in I spoke to the company the other week I told him what I wanted to do and everything and what I wanted and he recommend the Nested base which comes with everything I want on it! http://www.multicam.com/eng/Products/nestedbase.htmlJMB, Have a look at these http://www.shopbottools.com/ you are more than welcome to see mine working. Paul yo Paul What price are you talking for these? The MultiCam Nestedbase is about 63 000 I think cnt remember for sure. So a much lower price would be GREAT! lol I want it to make units so holes to be drilled from above and from the side would be nice for easy assembling. Whats your setup like? You got any accessories for it? Cheers JMB
CNC Paul
Offline
« Reply #177 on: March 21, 2011, 02:28 PM » |
JMB,
If you are making nested cabinets you cannot do horizontal drilling unless you reposition the panels that require horizontal drilling, that causes problems with repositioning accuracy. I produce nested cabinets and use Rafix fittings from Hafele that do not require horizontal drilling. For pricing check the website for their price list, I have a10 x 5 with two spindles and a drilling head, their tool changer is about £10,000 but was not available when I bought mine.
There are about 7000 Shopbots around the World, even people like Boeing use them for cutting components, also the Shopbot support is second to none.
What size of operation do you have (manpower and workshop size) ?
Any other question , just ask
Paul
« Last Edit: March 21, 2011, 02:32 PM by CNC Paul »
speed
Offline
« Reply #178 on: March 21, 2011, 04:26 PM » |
what are you planning on towing? you will be buying a bigger van soon as you will soon get fedup of towing a trailer, ask me how i know
has made the change. now 100% T-loc
Ken Nagrod
Restricted
Offline
« Reply #179 on: March 21, 2011, 04:29 PM » |
what are you planning on towing? you will be buying a bigger van soon as you will soon get fedup of towing a trailer, ask me how i know  He's planning on towing another van. JMB's Caravan.
