Author Topic: Kapex Power dilemma  (Read 1585 times)
Offline Mario Turcot
Kapex Power dilemma
« on: January 11, 2018, 10:29 PM »
For those that have a Kapex, how do you hook the Kapex power to the DC?
Do you use a dedicated DC or else. Here my setup, I have the CT 26 with boom arm and plug it cable attached to the hose. Each time I want to use the Kapex, I have to remove the plug it from the DC and plug the Kapex cable directly. Wondering if there is a plug it adaptor to address this.
I read that power consumption is an issue with the OF 2200 but the TS 75 comes with a plug it and both the TS 75 and Kapex are rated at 1600 w. Is there any way to fix this without having to get a second DC?
Mario
Offline Don T
  • Phoenix, Az
Re: Kapex Power dilemma
« Reply #1 on: January 11, 2018, 10:37 PM »
There is no plug it for the Kapex. You can run any Festool tool with the DC. You will need to unplug your other tool or use an adapter to convert the single outlet to a 3 outlet. Then you can leave the plugit cord connected. Hope this helps.
« Reply #2 on: January 11, 2018, 10:55 PM »
That's what I was doing, found it quickly annoying. Thanks for confirming!
Mario
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #3 on: January 12, 2018, 04:46 AM »
In order to make using my Kapex and other tools easier I have created my Dust Hub. This allows me to have the Kapex setup all the time and I have several options for using other tools. Here is a link to the video:
Offline Birdhunter
« Reply #4 on: January 12, 2018, 10:05 AM »
I have a dedicated Festool Mini vac connected to my Kapex through a short wide hose. The short wide hose did significantly improve collection. The vac nestled neatly under the Kapex stand.
Birdhunter
Offline JimH2
« Reply #5 on: January 12, 2018, 10:43 AM »
I've never had a problem with my Kapex, OF2200 or HL850 on 15amp or 20amp service.
« Reply #6 on: January 12, 2018, 10:56 AM »
I have a dedicated Fein Turbo II that I use with my Kapex.
However, when I need to run multiple corded tools on my MIDI or CT 22, I just use this 3-way adapter.
Offline SoonerFan
« Reply #7 on: January 12, 2018, 04:39 PM »
Same for me.  Dedicated CT and short 36MM hose under my Kapex on the cart I built.
« Reply #8 on: January 14, 2018, 02:17 AM »
Peter, I saw that box on one of your video and almost ask you to make a video about it. And there you go :)
Thanks!
Mario
« Reply #9 on: January 14, 2018, 02:19 AM »
That is the solution I was planning until I saw Peter hub. It`s going to be plan B if Peter`s hub is not an option for me.
« Last Edit: January 14, 2018, 11:24 AM by Mario Turcot »
Mario
Offline TomGadwa1
« Reply #10 on: January 14, 2018, 05:28 AM »
I have a UG cart with a shelf that I made to hold a CT-MIDI. As others have mentioned a short length of the 36 mm hose runs downward to the CT. The KAPEX plugs into the CT which is then plugged into a standard 15 AMP household outlet. I have had good results from this setup and have not tripped a breaker yet!
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
