Pages: [1]   Go Down
  Print
Author Topic: Gecko on pre finished maple plywood?  (Read 2115 times)
Les Spencer
Offline Offline
« on: April 03, 2008, 05:03 PM »
Has anyone tried using the gecko and adapter to cut cut prefinished maple ply? How did it work?
Les (near Indy) XL
Michael Kellough
Offline Offline
Southern New York
« Reply #1 on: April 03, 2008, 06:11 PM »
Sorry I can't answer your question but I'm guessing the next item added
to the new vacuum clamp system will be a vacuum powered Gecko.
That would surely work on pre-finished surfaces.
Jonhilgen
Offline Offline
« Reply #2 on: April 23, 2012, 02:29 PM »
A little late for a reply, but I didn't want to start a new thread.
Had to remove the 1/4" panel so the HVAC guys could access the blower so they could hook up the duct work...But I needed a way to put it back.  Enter the geckos!
A bead of caulk on the panel perimeter, micro pins and done.
Jon
The more Festools I buy, the more money I earn.  The more money I earn, the more Festools I buy.  The more...
TS 55, TS 75, Domino, CT22, OF 2000, C12, CXS, RAS, Trion, Fogtainers!
Alan m
Offline Offline
« Reply #3 on: April 23, 2012, 03:45 PM »
did youy design in that feature from the start
now
wish list
Jonhilgen
Offline Offline
« Reply #4 on: April 23, 2012, 05:19 PM »
Kitchen designers rarely design these things in.  It always starts with a proactive phone call to the designer that ends with "can't you just..."  Big Grin.  I've almost got him trained...
Just something you have to work around as a kitchen fitter.
Jon
fifo28
Offline Offline
« Reply #5 on: April 23, 2012, 05:33 PM »
I had the Gecko's and often use unfinished ply.  They did not hold.  Gecko's hold on laminates, glass, etc.
lambeater
Offline Offline
« Reply #6 on: April 23, 2012, 08:50 PM »
Hey I tried it on ply but found it can be a pain to set up with a rail, but... all is not lost I do stick it to the side of my full sheets for carrying, works awesome.
thx
Lambeater
Emer Construction
Online Online
« Reply #7 on: April 23, 2012, 09:20 PM »
I use it on pre finished birch with the parallel guides...it also makes it easier to carry my cabinet boxes around when done.
Steven
Pages: [1]   Go Up
  Print
Jump to:
