jussi
Offline
« on: March 05, 2012, 04:03 PM » |
I have both the 75 and 55 that I got through craigslist. Both are a few years old. I just got the 55 so all of my rails (besides the one that came with the 55) are set up to work with the 75. I was trying to align the 55 to match those rails but found I couldn't move it close enough. I then checked the thickness of the blades and found the 75 to be .1" and the 55 to be .85". Which one is the current thickness? If it's the smaller one, am I forced to buy all new splinter guards (I have 4 rails  ) or is there an alternate solution?
agehall
Offline
« Reply #1 on: March 05, 2012, 04:16 PM » |
If I'm not mistaken, the kerf of the US-blades varies. In Europe, all TS-55 blades at least, have a kerf of 2.2mm.
TS55, CXS, DF500, CT-22, CT MINI, OF1010, MFT1080, VAC-SYS SE1 + SE2, CMS-TS55, KS120, RO150, RO90, LR-32 kit, 2xFS1400/2, FS800/2, FS1400/2 LR-32
Tom Bellemare
Festool Dealer
Offline
« Reply #2 on: March 05, 2012, 04:31 PM » |
All current TS 55 blades are 2.2 mm kerf. The old ones varied though the Fine Tooth Blade has been 2.2.
ccarrolladams
Offline
Location: Hollywood, California USA Member Since: Apr 2010
« Reply #3 on: March 05, 2012, 04:44 PM » |
Jusi,
All six of the cabinet makers working for me currently owned Festools before we met. I have only purchased one TS75 but I own 7 TS55. I also own a whole lot of rails, some drilled LR32 and most non-drilled. The fellows working with me also own TS55, TS75 and rails.
As they were hired, we have set the toe-in and fit to splinter guard such that the total of 13 TS55 and 7 TS75 all fit each rail the same.
In the USA and Canada all current Festool TS55 blades have 2.2mm kerfs, despite the many typos on page 62 of the 2011 catalog.
My experience is that there is more than enough adjustment available with TS75 and TS55 so they can be set to fit the same rails.
pugilato
Offline
« Reply #4 on: March 05, 2012, 06:41 PM » |
what is 2.2 mm in inches?
duburban
Offline
« Reply #5 on: March 05, 2012, 06:58 PM » |
so this is possible by running the same kerf blade on all saws or at least the same kerf on all ts55's and same on all ts75's? Jusi,
ts75, ts55, ro150feq, ets150/3, trion, ct26, mft1080, estension wings, of1400, parallel guides, dts400, df500,
Sparktrician
Offline
Location: Northern Virginia (That's in the USA, Pilgrim!) Member Since: Dec 2009
« Reply #6 on: March 05, 2012, 07:01 PM » |
3/32".
- Willy -
MFT/3 x2, TS55, Guide Rails x3, Parallel Guide Set, CT22 w/Boom Arm, CT Mini, RO90, RO125, ETS125, RTS400, RAS115.04, C12 + Centrotec Imperial Bits, CSX Set, DF500 Domino Set, SCG-10, Domino Plate from RonWen, MFK700 Set, CMS-GE, OF1010, OF1400, OF2200 Set, LR32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, Ti-15, more "Stuff"-tainers...
Reiska
Offline
Hackers build things, Crackers break them.
« Reply #7 on: March 05, 2012, 07:06 PM » |
2.2mm = 0.088 in but what on earth is that in fractions I don't know - looking at this conversion table it looks like it's between 3/32 and 5/64's. These inch fractions baffle me every time regardless that I'm an engineer by schooling  2.816/32 or 11.264/128 to be precise
The sky's the limit in my workshop, literally.
Sparktrician
Offline
« Reply #8 on: March 05, 2012, 07:12 PM » |
2.2mm = 0.088 in but what on earth is that in fractions I don't know - looking at this conversion table it looks like it's between 3/32 and 5/64's. These inch fractions baffle me every time regardless that I'm an engineer by schooling  2.816/32 or 11.264/128 to be precise  May I correct that number? 2.2 mm = 0.086614" = 3/32".
- Willy -
Reiska
Offline
« Reply #9 on: March 05, 2012, 07:45 PM » |
Ah, so that's why my imperial to metric conversions always suck since we were thought in school that an inch = 25mm or 2.5cm which I guess is more of a rule of thumb since apparently (according to wikipedia) it is actually 25.4mm (which I guess must be somehow logical to the imperial world  )... I wonder if a foot = 300mm or is there another catch there... Apparently yes... 304.8mm And lo and behold - even the yard is actually almost 90mm shorter than Finnish golfers usually use i.e. 1m = 1 yard not the official 0.914m... So my drives actually don't suck as much as before since I'm getting a free yard to every 11 meters But that still doesn't make it any more even with 3/32 (at least in windows calc keeps telling me it's 2.77165/32) - it's more like 11/128 (11.0866/128'2).  I guess I need to get to bed since it is almost 2 a.m. here. G'nite!
Peter Halle
Global Moderator
Offline
« Reply #10 on: March 05, 2012, 07:49 PM » |
Reiska, If you can't get to sleep forget about counting sheep. Count decimal places in conversions  . Every day I get closer to just going to metric. Peter
ccarrolladams
Offline
« Reply #11 on: March 05, 2012, 08:52 PM » |
so this is possible by running the same kerf blade on all saws or at least the same kerf on all ts55's and same on all ts75's? Even back in the days when not all TS55 blades had 2.2mm kerfs, there was enough adjustment the saw could be set to the splinter guard. Of course with only one TS55 that was hardly practical. That was my original reason for buying a second TS55, so I could leave a Panther rip blade on it and still have that set so it did not nick my splinter guards. The current Panther blade is a 2.2mm kerf. My fellows happen to mainly use TS75 blades with 2.4mm kerf. So once set they can have those blades interchanged as needed. I have several older TS75 Panther rip blades with 2.6mm kerf. My own TS75 is clearly marked for Panther only and is set such that on it the Panther blade fits our standard rails the same as all the other saws. The fact is in my shop we hardly ever use a plunge saw to work anything but sheet material. When we need to make a long rip to produce a straight edge on a piece of rough lumber, we clamp it to the slide of my Felder sliding table saw. With all that power and its 550mm blade, the resulting clean-up rip needs very little help later from the jointer. However, when the TS75 first came to North America, I did not have a shop with a slider saw or jointer. To make those clean-up rips I used rails as long as 3000mm and my TS75 with a Panther blade. By then I had gained experience setting my Festool saws for ideal toe-in and also consistent relationship to the rail splinter guards.
agehall
Offline
« Reply #12 on: March 06, 2012, 03:26 AM » |
I was looking at a Panther blade in the US a few months ago and that one had a kerf of 2.0mm, so I'd say it is safe to say you guys still have a mixed kerfs in circulation.
Anyhow, going forward, I suggest the OP tries to stick to blades with a 2.2mm kerf for the TS-55. Anything else is old and will probably mess up your rails unless you are careful.
ccarrolladams
Offline
« Reply #13 on: March 06, 2012, 03:32 AM » |
Who can say what package of that blade you found. In the Festool USA 2009 catalog the Panther blade for TS55 was cat 495 372 with a 2.5mm kerf In that same 2009 catalog the Panther blade for the TS75 was cat 495 378 with a 2.6mm kerf Exactly where did you get that 2.0mm kerf and it was for which saw?
agehall
Offline
« Reply #14 on: March 06, 2012, 03:36 AM » |
Hmm, you could be right. It could have been 2.5mm. All I'm sure of, is that it wasn't 2.2mm and because of that I decided not to buy it. The blade was for the TS-55.
ccarrolladams
Offline
« Reply #15 on: March 06, 2012, 03:46 AM » |
The current TS55 Panther blade cat is 496 305 which has a 2.2mm kerf. In fact the only current TS55 2.2mm kerf blades which do not have a cat 496 xxx is the fine tooth which has not changed in years. It always had a 2.2mm kerf so remains cat 495 377
ctfeet
Offline
« Reply #16 on: March 06, 2012, 09:17 AM » |
Reiska,
I'm with ya. Sometimes I wish we would just make the switch and be done with it. I can't tell you how many times I've tried to explain the difference between 1 ounce and 1 ounce to my wife.  She doesn't get that it could be 1 ounce volume (29.57 ml) or 1 ounce weight (28.35 g). And it would be a whole lot easier to look at a wrench and know what is the next bigger size - 10mm too small, the next size up would be 11mm.
billg71
Offline
Location: lost in the NW Atlanta 'burbs Member Since: Nov 2010
« Reply #17 on: March 06, 2012, 09:37 AM » |
Does it really make a difference? I mean we're talking about a difference of .3mm/2= .15 mm or .0059". Does that little an offset of the splinter guard really increase tearout noticeably on crossgrain cuts? Just asking....  Bill
« Last Edit: March 06, 2012, 09:38 AM by billg71 »
"Born to fish, forced to work..."
fdengel
Offline
« Reply #18 on: March 06, 2012, 09:53 AM » |
It's not just tearout, but alignment as well...
andvari
Offline
« Reply #19 on: March 06, 2012, 11:12 AM » |
Yes, I think there is still some old stock out there, just like some classic systaqiners. But if you stick with part numbers beginning with 496 for the TS 55 you will get 2.2 kerf blades.
Kevin Stricker
Offline
« Reply #20 on: March 06, 2012, 04:43 PM » |
Regardless of the kerf, unless you store your guide rails like you do your engineer squares( and even then)the splinter guard is eventually going to get dinged up.
A simple solution is to just pull off the splinter guard and move it out a bit and recut your reference line. You can easily do this a few times, after that you will need to replace the sticky tape and you can get a couple more.
Or you could replace some of your blades, or only use certain rails with certain blades. Or just say screw it and live with a slight offset, just account for it when measuring for your cuts..
