Author Topic: Kreg Pocket hole system and Festool Vacs...  (Read 10777 times)
Offline Matt Antonucci
« on: March 22, 2009, 09:46 PM »
Hey guys,
   I recently purchased the Kreg K3 pocket hole system...  I am working with Ipe and the dust is particularly nasty...  Included with the Kreg system, there is a dust extractor shroud...  I wanted to be able to connect the Festool vacuum to that shroud...  Does anyone know of an adapter that would allow for connection to the Vacuum?  I believe the shroud is 1 1/4" ID or about 1.4" OD...
Matt
Offline Steve Jones
  • Austin, TX US
Re: Kreg Pocket hole system and Festool Vacs...
« Reply #1 on: March 22, 2009, 10:04 PM »
Matt,
 i use the Kreg jig myself, I've used several adapters but the one i find most usefull is a hose made by (or at least sold as) Porter Cable. One end fits the CT connector and the other fits the Kreg, most PC tools and many others, I've found it at several PC dealers for about $30 i think.
steve
Steve Jones
AdapTableTool, Inc.
adaptabletool@gmail.com
Offline Peter Halle
« Reply #2 on: March 22, 2009, 10:16 PM »
McFeeleys has the adaptor to fit the Kreg jig and the festool standard hose.  Works great.  Got it after a project that I wished I had it for.
Offline Steve-CO
« Reply #3 on: March 22, 2009, 10:44 PM »
If you cut off a couple of the sections of this towards the end, it'll fit in the Kreg dust shroud and the 27mm hose will fit it like a glove, http://www.pennstateind.com/store/DHMULTI.html
Offline fshanno
« Reply #4 on: March 22, 2009, 11:05 PM »
I use a small plastic cutting sheet my wifes let me have, about 9x7.  I roll it up tight and stick it in the Festool hose and the Kreg dust shroud.  It unrolls to fill the gap in each and works like a charm, doesn't fall out when bumped.
Offline johnl1
« Reply #5 on: March 23, 2009, 08:14 AM »
I use a 1 1/4" PVC elbow. I used a barrel sander to increase the inside diameter on one leg of the elbow to fit on the Kreg jig and it works great.
Offline josephgewing
« Reply #6 on: March 23, 2009, 10:18 AM »
I took my Kreg set up and Festool 27 hose to an auto parts store and got a radiator hose and a hose clamp to connect the hose to the Kreg vacuum connector.  The Festool vac hose connects to the other end.  Works good.
Just another option and not too expensive.
Joe Ewing
Las Cruces, NM
Joe Ewing
Offline Rey Johnson
  • Fine Sawdust Maker
    • Festool MFT/TS55 Retrospective
« Reply #7 on: March 23, 2009, 11:10 AM »
Hi Matt,
I have my Kreg setup connected to the CT33 using a stepdown reducer...see this other FOG link for my pics...
http://festoolownersgroup.com/index.php?topic=6123.msg65307#msg65307
Total costs = $5 or so.
TS55|AT65|TDK15.6|OF1400|PS300|RO150E|MFS700|MFS400|FS2700|FS1400|FS1080|FS800|MFT3(2)|MFT1080(2)|MFT800(2)|CT33E(2)|Kapex|RS2E|ETS150/3|Domino
Offline Dave Ronyak
  • Flyin' from NE Ohio
« Reply #8 on: March 23, 2009, 12:07 PM »
Exactly!!  Here's mine in use.
I used a drum sander mounted on my drill to slightly increase the diameter on the end which is attached to the Kreg jig.  The curved shape of the adapter helps to reduce the strain from the hose on the Kreg dust shroud.
Dave R.
Offline woodshopdemos
  • Inactive Member
    • Woodshop Demos - 1400 pages of how-to
« Reply #9 on: March 23, 2009, 12:55 PM »
I took the easy way out. I use a short piece of orilla tape to hold the hose on. It works fine, but I will use an adapter someday. The dust hood is geat add for the Kreg. With the mini it takes all the dust from drilling the pocket holes.
In memory of John Lucas (1937 - 2010)
« Reply #10 on: March 23, 2009, 08:04 PM »
Hey guys,
   Thanks for all the responses...  I think I am going to try one of those "stepped-reducer" pieces to fix the problem...  I was using gorilla tape for a while...  What I found is that after letting the tape sit on the hose end for a few days, it left a lot of residual glue on the hose end after peeling off the tape...
Matt
Offline robsw
« Reply #11 on: March 23, 2009, 09:32 PM »
I found this at HD. Works perfectly with a nice snug slip fit. No tape required.
Offline Tom Ryan
« Reply #12 on: March 23, 2009, 10:06 PM »
I'll second Peter Halle's suggestion to get the adapter from McFeelys.
Neat, simple, no trimming needed, and not too expensive.  I just got one.
Tom in SE Pennsylvania
« Reply #13 on: October 02, 2018, 01:38 PM »
Old thread, I know but do you have a link for that adapter? looked on the site but couldn't find it.
Matt
Offline Birdhunter
« Reply #14 on: October 02, 2018, 02:09 PM »
When I worked last with Ipe, I took a long shower after knocking off for the day. That dust is very bad stuff.
Birdhunter
Offline RKA
« Reply #15 on: October 02, 2018, 03:59 PM »
Matt
I don't think they would carry it anymore, but another option is looking for the 3D printed part on shapeways.  It's not inexpensive though.  Fein also sells a stepped hose adapter that should allow you to connect the festool fitting to the kreg.
-Raj
« Reply #16 on: October 02, 2018, 04:38 PM »
Thanks Peter.  I'll look at both.  Seems like this would be a more readily available part given the popularity of both brands, yes? like a stock item maybe?
Thanks again
Offline thudchkr
« Reply #17 on: October 02, 2018, 08:58 PM »
Best adapter I’ve found is marketed for Fein. Part # 31322771009. https://www.cpooutlets.com/fein-31322771009-1-1-4-in--flexible-connector/fenn31322771009,default,pd.html?ref=pla&zmam=31282435&zmas=47&zmac=722&zmap=fenn31322771009&gclid=EAIaIQobChMIiIW2yIbp3QIVEwOGCh3Z4g9vEAQYASABEgL-lvD_BwE
It is a nice tight fit when stretched over both the hose end and the Kreg adapter.
Clint
TSC 55, TS 55, TS 75, HKC 55, DF 500, DF 700, Kapex 120, UG Ext. Wings, MFK 700, OF 1010, OF 1400, OF 2200, CT 22, CT 26, ETS 150/3, ETS EQ 150/5, PRO 5, DTS 400, RO 90, RO 150, CXS, DWC 18-4500, MFT Kapex, MFT 3 (2), MFT 800, MFT 1080
Offline JayStPeter
« Reply #18 on: October 02, 2018, 09:48 PM »
This is an old thread.  These days there is the Bosch VAC003 adapter for less than $5 from Amazon.  Perfect fit in the K5, but I think it shares the 1 1/4" size with the K3.
Jay St. Peter
Offline Sparktrician
« Reply #19 on: October 03, 2018, 07:45 AM »
I use the vacuum adapter that came with my Leigh Super 18 dovetail jig.  It's a perfect fit.
- Willy -
Offline Garry
    • AVID
« Reply #20 on: October 21, 2018, 10:48 AM »
I wrapped the nozzle on the hood with several wraps of electrical tape and use the 36mm hose.  Works like a champ and virtually free.
http://www.avidhome.com  You're only young once, but you can be immature forever!
Offline ben_r_
« Reply #21 on: October 21, 2018, 11:24 PM »
Just got one of these Bosch adapters off eBay and it fits the dust port on a K5 good and its a tight fit but it fits in/on the 27mm and 36mm Festool hoses.
Offline sprior
« Reply #22 on: October 22, 2018, 11:27 AM »
The vacuum end of brush attachment that comes with the Festool vacs fits the Kreg jig port perfectly then the tool nozzle of the 27mm Festool hose just happens to fit snugly in the brush end of the attachment.  Works great and once I found out about this I stopped looking for another adapter to fit the Festool hose to my Kreg jig.  I don't have a picture handy, but once you know to try it it's really easy.
« Reply #23 on: October 22, 2018, 11:44 AM »
that sounds good. ill give it a shot, thanks.
Offline jpmeunier
« Reply #24 on: October 22, 2018, 12:18 PM »
Yeah the adapter works like it made to do specifically that task.
Offline Trevin
« Reply #25 on: October 22, 2018, 06:42 PM »
I printed one of these from thingiverse and it works great if you have access to a printer...
https://www.thingiverse.com/thing:22865
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
« Reply #26 on: October 22, 2018, 06:44 PM »
just ordered one. thanks guys.
Offline OXCanada
« Reply #27 on: October 23, 2018, 10:55 AM »
Does anyone have a link for the McFeely's adapter?  I've used tape for far too long....
Offline ben_r_
« Reply #28 on: October 23, 2018, 05:29 PM »
Why not get the Bosch one?
Offline guitarchitect
« Reply #29 on: October 24, 2018, 04:46 PM »
I can't remember the name but there's a rigid hose reducer that fits perfectly, off the shelf from home depot... just look for the right size.
