Author Topic: Leigh 704R Guide Bushing Adapter Questions  (Read 788 times)
Offline rmhinden
« on: January 10, 2019, 11:50 PM »
I got a Leigh 704R guide bushing adapter for my OF 1010 router..   As advertised, it is looser and allows for better centering of the guide bushing.
Two question:
Where can I get some M4 screws with flat heads that won't protrude above the base of the plate?  The ones I have are too thick.
As you can see in the attached picture, the Festool guide bushing adapter has four circular slots in their guide bushing plate.  These work well for dust collection.   I was thinking of drilling a series of holes in the Leigh adapter for the same reason.  Has anyone else done this?
Thanks in advance.
Offline Sanderxpander
Re: Leigh 704R Guide Bushing Adapter Questions
« Reply #1 on: January 11, 2019, 01:28 AM »
I had the hardest time finding them too. Going to a local hardware store to test is your best option, but even then I ended up having to file down the head of the best fitting pair. Everything I could find was too high when mounted. I think it's a real shame Leigh doesn't provide a pair.
Offline rmhinden
« Reply #2 on: January 11, 2019, 04:06 PM »
I contacted Leigh.  They said they would send me two screws.  I will report back after I receive them.
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
« Reply #3 on: January 11, 2019, 05:55 PM »
Regarding Leigh / Festool vacuum circular slots:
Drilling holes IS an economical and interesting solution.
Leigh has a vacuum solution for ALL router brands -
Not just a solution for Festool routers - Or Porter-Cable - Or Trident - Or...
It’s their Leigh VRS Vacuum & Router Support.
https://www.leighjigs.com/vrs-vacuum-router-support/
BTW... It works great!
Little or no dust - And a great router support, too boot.
I use it with both my Festool OF1400 and my Porter-Cable 690LR.
« Last Edit: January 11, 2019, 06:00 PM by Joe Felchlin »
FESTOOL: CT26 and CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides and Extensions, OF1400 EQ Plunge Router, OF1010 EQ Plunge Router, HL 850 Planer, RO125 FEQ Rotex Sander, LS 130 EQ Linear Detail Sander, DX93E Detail Sander, C12 Cordless Drill, CXS Cordless Compact Drill Driver, SYS-Centrotec-Set, Domino XL DF 700 EQ Plus Tenon Joiner Set, Domino DF 500 Tenon Joiner | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIGS: D4R 24 Pro Dovetail Jig, FMT Pro Mortise & Tenon Jig | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
Offline rmhinden
« Reply #4 on: January 11, 2019, 06:17 PM »
I agree that is a very good solution for their dovetail jigs for dust collection and router support.   I was thinking of dust collection using a template and guide bushing where the slots would help.
Offline Sparktrician
« Reply #5 on: January 11, 2019, 06:55 PM »
Use 4 mm x 0.70 mm pitch cheese head screws, head thickness 1.85 mm max.
- Willy -
Offline rmhinden
« Reply #6 on: January 11, 2019, 11:30 PM »
Can you point me to a supplier for these?  I have have done some searching and can find anything with this head thickness.
Thanks!
« Reply #7 on: January 12, 2019, 09:30 AM »
Thanks!
I got mine from Leigh.  McMaster-Carr doesn't sell them with thin heads like these.
- Willy -
