Author Topic: LS-130 Scraper Attachment (Glue Squeeze Out?)  (Read 660 times)
Offline yetihunter
« on: December 03, 2017, 12:34 AM »
Obviously, a sandvik/bahco carbide scraper does the job. However, has anyone tried using the LS-130 w/ scraper attachment on glue squeeze out (woodworking)?
That people use it for carpet and tile should be a red flag, however, it's worth asking.
I know that I certainly wouldn't use a multimaster scraper, alas, the LS-130 does have flat registration.
Re: LS-130 Scraper Attachment (Glue Squeeze Out?)
« Reply #1 on: December 03, 2017, 12:53 AM »
I’ve only used it for tile. It worked great for me though.
Offline ear3
« Reply #2 on: December 03, 2017, 07:47 AM »
I don't own the scraper attachment, but the specs say:"Uses the linear motion of the LS 130 EQ sander to quickly strip small areas of carpet, wallpaper, glue, and other difficult to remove materials."  I suppose it would also depend on how difficult the surface is to access -- are we talking about glue along the seam of edge joined boards, or in a corner or butt joint type of situation (where I imagine it would be more cumbersome to use)?
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T18+3 w/Centrotec Installer's Set • PDC 18/4 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • CT 26 w/Long-Life Bag • CT Sys w/Long-Life Bag • MFT/3
Offline ScotF
« Reply #3 on: December 03, 2017, 09:07 AM »
I though Paul-Marcel mentioned it in one of his reviews as a good use for the scraper. I do not own it, but I think it could work on an edge joint.
Offline HarveyWildes
« Reply #4 on: December 03, 2017, 10:30 AM »
I didn't know this accessory existed until today.  I have a Milwaukee M12 hackzall scraper blade that I use for construction type scraping tasks.  It works great on construction adhesive, tile, etc., but it's rough.  I also have a scraper blade for my oscillating tool and find that though it is less aggressive than the hackzall scraper, it tends to get out of control quickly.  The scraper blade is sharp and tends to act like a chisel, so when it gets out of control, it digs into the wood.  I suspect the LS-130 scraper would do the same jobs more slowly and with more finesse than the hackzall or the oscillating tool.  Given my experience, I'd  experiment a bit with the LS-130 scraper on scrap before trying it out on a real project.
For glue squeeze out on woodworking projects I always use a hand scraper.  The weak point is removing squeeze out from corners.  I often resort to chisels for that - but since it feels like an abuse of chisels, I normally use my jack-of-all-trades chisels (an old Record set) rather than my good ones.  Maybe the LS-130 scraper would be able to get into corners.
On woodworking projects, I normally use Titebond or Titebond III, and try to scrape when the glue is dry but still flexible.  Once the glue gets brittle (fully hardened), it can occassionally hang on to bits of wood from the edge of the joint - not a lot, just enough to be irritating.
« Last Edit: December 03, 2017, 10:37 AM by HarveyWildes »
Offline yetihunter
« Reply #5 on: December 04, 2017, 03:49 AM »
@ear3 Definitely edge jointed boards, only.
@HarveyWildes Yes, for remodeling and what not, the LS-130
attachment looks like a dream.  Scraping with an oscillating tool (multimaster),
there's a very narrow sweet spot between not removing enough and digging a crater.
I absolutely cannot imagine trying to control a sawzall scraper. :0
