Author Topic: MFT 3 fence and accessories work on a Kreg universal bench?  (Read 5611 times)
Offline W1ngnu7
« on: February 17, 2014, 11:03 PM »
Will the MFT 3 fence and accessories work on a Kreg universal bench?  Is there something special about the MFT 3 that makes the attachment of these parts specific to just that bench?
Offline Corwin
Re: MFT 3 fence and accessories work on a Kreg universal bench?
« Reply #1 on: February 17, 2014, 11:29 PM »
Welcome to the forum.  The MFT/3 fence and accessories mount to the table's extruded aluminum profiles that 'frame' the table's top.  These aluminum profiles are V-shaped along their top surface which allows for one to place the MFT/3 fence and accessories at any location along the profile and then fix in place -- this is not compatible with the T-track style mounting of the Kreg system.
If you look closely at the photos on Festool's MFT/3 page, you will see what I mean by the aluminum profile's V-shaped groove.
« Last Edit: February 17, 2014, 11:38 PM by Corwin »
Looks like your rabbit joint is a hare off! ;)
Offline bkharman
« Reply #2 on: February 17, 2014, 11:52 PM »
You can use the fence with a number of different dogs as well. I haven't attached my fence with the MFT parts for quite sometime.
You can also use that combo with other fences to achieve a custom setup.
People, I just want to say, you know, can we all get along? Can we get along?
Offline W1ngnu7
« Reply #3 on: February 18, 2014, 08:53 PM »
That is very helpful, thank you.
Offline W1ngnu7
« Reply #4 on: February 18, 2014, 08:55 PM »
Do you have any examples of what works together?
Offline bkharman
« Reply #5 on: February 18, 2014, 09:32 PM »
I use the Tool Improvement Bench Dogs and the Festool fence. It is nice to drop it where I need it and not fuss around with getting it dialed in.
I also use Parf and Qwas and Precision dogs to make the rail perpendicular to the fence or dogs.
Offline Corwin
« Reply #6 on: February 18, 2014, 10:39 PM »
You are most welcome!   [big grin]   A "thank you" is always nice to receive!
I don't think that bkharman understood your question, as his reply is about installing a fence on the MFT using the MFT's 20mm holes rather than the factory option.  As I understand, you are looking to use the MFT/3 parts on a Kreg table.
Another option to mounting Festool MFT/3 parts to something other than an MFT/3 table is to purchase a length (or two) of the aluminum profile from Festool to attach to your own bench -- that way you know they fit…  Some members here have done just that so they could mount a guide rail to their own custom bench using the MFT's guide rail brackets.  Yet, I don't recall anyone adding the aluminum profiles to their table so they could use the MFT/3's fence -- probably because there are other options for a fence...
Offline DIY WoodWerx
« Reply #7 on: August 22, 2017, 09:10 PM »
I know this is an old thread, anyone know if these are available anywhere or anything similar?
Festool TS 55 REQ-F-PLUS
Festool OF 1400 EQ-F-PLUS
Festool CT MIDI HEPA
Festool Domino DF 500 Q-PLUS
Festool PRO 5 LTD (ETS 125 REQ)
Festool FS 1400/2 (x2)
Festool FS 1400/2-LR 32 Guide Rail
Festool LR32 Router Hole Drilling Set
Offline FergieBergie
« Reply #8 on: January 21, 2018, 05:11 AM »
Are these made by your hand or are they somehow obtainable? This is exactly what I am looking for.
Offline TinyShop
« Reply #9 on: January 21, 2018, 03:19 PM »
They once were (optimal word "were") made by a particular FOG member under his "Tool Improvements" brand (the same operation that currently produces the "Slop Stop" for the MFT guide rail assembly).
