Pages: [1]   Go Down
  Print
Author Topic: New to festool, Electrician in need of a drill!  (Read 3532 times)
Vario
Offline Offline
« on: March 18, 2012, 06:58 PM »
Hey guys
I am a new member, I came across this site as I was trying to find information on the Festool CXS and C12 drills.
I am an Electrician, here in Ontario Canada
I am looking for the ultimate drill, I have owned and tried every other brands of compact drills, there are things I dislike about all of them. I have never tried a festool drill, I went to see them in store and I really liked the cxs. I am trying to see if the price is justifiable.
What the drill must do:
Be lightweight, it's on and off my belt all day.
It must be able to survive construction environment. (rural/residential/farm).
It must have a light on it, (preferably that stays on for seconds).
It must be able to work even if it gets cold outside. (I understand no drills like -30.C. When it's that cold, I use my 18v)
It has to drive 1in, 1.5in and 2in screws repetitively.
It will be fastening a lot of #1 and #2 machine screws?. (#6, #8)
The cxs seemed to have an awesome trigger, I really liked it.
I am wondering if the brushless motor from the c12 is a must have?
Looking for opinions in general. This drill is going to take a beating. I must say that my makitas and milwaukees have never been destroyed on the job. I have busted up some dewalts, hitachis, ridgid...
What is the general consensus?
duburban
Offline Offline
« Reply #1 on: March 18, 2012, 07:02 PM »
panasonic tough ip 14.4 impact drill combo.
ts75, ts55, ro150feq, ets150/3, trion, ct26, mft1080, estension wings, of1400, parallel guides, dts400, df500,
Vario
Offline Offline
« Reply #2 on: March 18, 2012, 07:30 PM »
The closer to 2 lbs the better. Under 3 a must.
Shane Holland
Festool USA Employee
FOG Administrator
Offline Offline
WWW
« Reply #3 on: March 18, 2012, 07:53 PM »
Welcome to the forum. I work for Festool. If you ever have questions or need help, let me know.
The C12 is going to squeak in under 3 lbs., the CXS is right at 2 lbs. All of our drills come with a three year warranty, which cover the batteries as well. If you're primarily driving machine screws into pretapped holes, the CXS should do great. You can expect about 250-ish screws off a single charge. The C12 is going to have more torque at the expense of weight. The brushless motor is going to help with battery life (screws per charge) and will generally last much longer than a brushed motor. It sounds like compact and lightweight are prerequisites for you, so I'd recommend the CXS. If you have the need, it has a right angle chuck available which can be bought with the drill as a package.
Festool offers a 30-day money back guarantee. So, get one, try it, if you don't like it or want to exchange it for another model, just take it back to your dealer for a refund. No risk, no hassle.
More information on all of the drills --- http://drills.festoolusa.com
Shane
Shane Holland | Festool USA | Sales: 888-337-8600 | Service: 800-554-8741 | sho@festoolusa.com
Faster. Easier. Smarter.
Power Tools, Domino Joiners, RRP HEPA Vacs, Track SawsDrywall Sanders, Cordless Drills, Tools for Painters, LED Worklamp, Router Tables
vkumar
Offline Offline
Sunnyvale (near San Jose) California
« Reply #4 on: March 18, 2012, 09:15 PM »
I thought the CXS was the only drill in the Festool line that was not Brushless.
Vijay
Shane Holland
FOG Administrator
Offline Offline
WWW
« Reply #5 on: March 18, 2012, 09:25 PM »
As far as current models, that's true. Did I say something that gave the wrong information or impression? My apologies if that was the case.
hockey_magnet
Offline Offline
« Reply #6 on: March 18, 2012, 09:49 PM »
Unless light weight is paramount, I would go with the C12 or C15 just for the brushless motor, torque, electronic clutch  and battery life. Although keep in mind you could buy 1 CXS kit, plus a second CXS for backup for less than the price of a single C12 kit.
Shane is dead on though. Just buy one - probably the CXS - if it meets your needs, keep it, if not, return it.
Vario
Offline Offline
« Reply #7 on: March 18, 2012, 09:57 PM »
I am also worried about the amount of electronics in the c12.  It will see harsh environment.  The other thing is when I compare the torque ratings of these to other manifacturers. It dosent add up. Are the other numbers bloated up? I tried the cxs in a piece of wood in store and it did not have 1/3 of the torque of the milwaukee.
Also. Can I modify the centrotec quick connect to accept the standard 6in 1/4in hex #8 robertsonbits I use? I was going to grind the a bit to fit in the centrotec .
Festool does not make robertson (square) bits as far as I could tell.
« Last Edit: March 18, 2012, 10:12 PM by Vario » Logged
Brice Burrell
Online Online
Remodeling Contractor
WWW
« Reply #8 on: March 18, 2012, 10:53 PM »
I can tell you the electronics in the Festool drills are tough and I don't worry about them at at all in me two T15 drills.  I once forgot one of my drills outside in a downpour, that drill still works perfectly fine more than seven months later.  I work in some pretty nasty jobsites and my drills regularly see plaster, saw and drywall dust, no problems.  Just today my drills spent most of the afternoon in amongst rat feces, so I think you can tell I don't baby them. Tongue Out
Peter Halle
Global Moderator
Online Online
WWW
« Reply #9 on: March 19, 2012, 02:24 AM »
Welcome to the forum.  I cringe every time I see the video below, but you might not have come across it before.
Would you loan your drill to this person?
You are correct that Festool does not currently offer a centrotec version of a robertson bit.  Some here have made grinding ,modifications, some are happy with the wire detent versions in the centrotec magnetic bit holder/adaptor.
Rick Christopherson
Retailer
Online Online
WWW
« Reply #10 on: March 19, 2012, 02:40 AM »
As an electrician, the feature that will make any of these drills a must-have for you will be the right-angle drive attachment.
PeterK
Online Online
« Reply #11 on: March 19, 2012, 09:13 AM »
If you can, try the T drills versus the C drills for fit in your hand. For me, the T drills are a far better fit and much more comfortable to use in my size hands. I had a C12 and just never liked the size of the grip. If you go for one of the T or C drills, go for the 15 volt versions. Only $50 more, much longer battery life, no noticable weight difference. I have a t12 and T15 as well as the CXS. I find absolutely no benefit to the T12 over the T15. I use the CXS the most but it is not designed to bore holes for running Romex as a full time job. For the screws you mentioned, it will work fine but the small batteries will need recharging far more offer than the larger drills if you are driving screws all day.
Wood_Junkie
Offline Offline
« Reply #12 on: March 19, 2012, 09:16 AM »
I am not a professional, but I do all of my own electrical work on my houses (we're allowed to, with permit & inspection, here in Madison).
I use the CXS for 99% of that work.  It meets all of your criteria, is incredibly light, compact, powerful, and has the right angle chuck.
However, are you going to be able to drill 3/4" holes through floor joists with a self-feed auger bit in the CXS?  No.  You would be able to drill those holes using a normal brad point or twist bit, but it will take a bit of time.
So if the speed and torque for this type of purpose are of primary importance for you and you want only one drill, unfortunately the CXS won't be it.
A T-18 or C-15 would be great choices.
fisheye
Offline Offline
« Reply #13 on: March 19, 2012, 10:35 AM »
I noticed you didn't mention drilling, so I'm wondering if something like the Milwaukee M12 impact driver would be a good addition to your kit. I own one, and love the thing. It's one of the few non-Festool small powertools I own that I would replace if lost with the same.
http://www.amazon.com/Milwaukee-2450-22-12-volt-Impact-Driver/dp/product-description/B001F7BIH6/ref=dp_proddesc_0?ie=UTF8&n=228013&s=hi
Tom Bellemare
Festool Dealer
Online Online
WWW
« Reply #14 on: March 19, 2012, 10:57 AM »
Like Mr. Junkie, I do a lot of electrical work at times. If it's new construction, most of the time, you can drill a stud with a full-size Festool C or T drill using a self-feed bit straight on. Sometimes, the studs are too close together and the Right-Angle Chuck is indispensable.
If I'm crawling around in an attic, being able to switch to a right-angle configuration without having to carry 2 drills is really important. I've drilled a lot of studs and plates with the NiCd C12 and never really had a problem. I'm not sure I would want to crawl 50' through an attic with only my CXS. It's a powerful drill for its size but...
Another nice thing about crawling in tight spots with Festool drills is the ability to easily and quickly change bits/drivers without carrying much.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Vario
Offline Offline
« Reply #15 on: March 19, 2012, 11:23 AM »
I have a multitude of other drills. Haha. For the major drilling around the house I use a corded drill.  When I m roughing electrical I use the m18 hammer drill with a 7/8 auger if I need to add a few holes. This drill is going to be for finishing and the small rough in stuff like mounting boxes etc.
I just want to make sure it is ok to pay the premium to run a festool that is still a brush motor.
Wood_Junkie
Offline Offline
« Reply #16 on: March 19, 2012, 03:11 PM »
Well then, taking big drilling out of the equation then, IMHO, the CXS is gonna be a peachy addition to your toolbelt.     Thumbs Up
Order a TwinBox also.  Substitute a few Robertson #1 and #2's in there, and you're all set for most anything.
SRSemenza
Global Moderator
Offline Offline
« Reply #17 on: March 19, 2012, 03:41 PM »
Hi Vario,
Welcome to the FOG!  Smile
CXS seems like a perfect fit.  As a pro you will certainly get enough use in 30 days to know for sure  Wink
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
SRSemenza
Global Moderator
Offline Offline
« Reply #18 on: March 19, 2012, 03:42 PM »
Brice you need to find better job sites  Blink
Seth R. Semenza
Tim Raleigh
Offline Offline
WWW
« Reply #19 on: March 19, 2012, 05:19 PM »
Hope you had a mask. That "crap" is horrible.
Tim
Kodi Crescent
Offline Offline
« Reply #20 on: March 19, 2012, 10:40 PM »
You don't want to be breathing any of the dust from rodent droppings.  There was some outbreak of some disease in the 90's associated with breathing the dust from rodent droppings.  I don't remember the name of the disease.  I think people were dying within a few days.
- Hantavirus - was the name of it.
nyman_666
Offline Offline
« Reply #21 on: April 08, 2012, 11:50 AM »
I also work as an electrician and use the old c12 at work and it works just great. The only problem is drilling holes larger than 20-22mm, that requires often a corded drill or a larger battery drill. I use the Protool quadrive 18 volt or the protool corded drill for big holes. Bought a month ago the new c15 for private use and thats a nice compensation. It's lighter than the old c12 and stronger. 22mm holes are no longer any problem. I'd go for the c15 any day. Lightweight and powerful!
GhostFist
Offline Offline
« Reply #22 on: April 08, 2012, 07:01 PM »
For drilling bigger holes the cxs isn't going to do it, BUT it is my go to drill for most of my screwing and small diameter drilling. I personally can't see how anyone could pass it up. The ultimate tight space drill IMO
HowardH
Offline Offline
« Reply #23 on: April 08, 2012, 10:43 PM »
I second that.  I was attaching a Wixey fence scale to my new Hammer K3 today and needed to drill a hole in the side of the steel table to use as an attach point.  A traditional drill wouldn't have worked.  I used the right angle attachment and it make it very easy.   This is only the second time I have used this attachment and it was a life saver.  I had no other way to drill this hole.  I told my wife this is why Festool is the best.
Howard H
The Plano Texas Festool Fanatic!
Shelby Metcalf, basketball coach at Texas A&M, recounting what he told a player who received four F's and one D: "Son, looks to me like you're spending too much time on one subject."
mft1080, T15, RO150FEQ, TS55, RTS400, ETS 150/3, OF1400, CT22, CT33, MFS 400 & 700, Boom Arm, 800, 1080, 1400, 1900 rails CSX drill Qwas dogs
FulThrotl
Offline Offline
« Reply #24 on: April 09, 2012, 03:03 AM »
Hey guys
i am an electrical contractor in southern california.
in my experience, you need a single drill.
T-18
it's US $625. suck it up, and buy it.
i took 5 drills off my truck that were replaced with this.
including a Milwaukee hole shooter, 1/2"
i've never ran a battery down yet in a day.
the right angle attachment will simply blow your mind.
now, if festool would get it together, and release the
18 volt carvex in the US, i could get rid of my sawzall.
« Last Edit: April 09, 2012, 03:05 AM by FulThrotl » Logged
... it's not good.... my festool dealer
knows me by my first name....
...i'm suspecting i'm his 401K.....
Vario
Offline Offline
« Reply #25 on: April 16, 2012, 07:26 PM »
Well I did it. I bought the cxs. Today was the first test!
I'm unfortunately going to try a T drill instead.
I really liked the weight of the cxs but it had a hard time with the 1-1/2 and 2 in screws. I like to leave my drills in high gear.
The thing that bothered me the most is the fact that I work using 6in long bits. I pry open the electrical boxes, I use the bit to twist wires around screws, the grip on the cxs is all the way back compared to a T-shaped drill. It felt weird to work use overall.
I have to say the cxs is a nice little tool but not exactly made for me. (Personal choice, that's all)
I'm not quittin' yet. I'll spend the extra 200 bucks and try the T12 or T15. I'll probably go T12 for the weight factor and it should be enough power wise.
Anyone knows if these still turn in -20 degree C temperature?
fdengel
Offline Offline
« Reply #26 on: April 17, 2012, 09:41 PM »
I think I'm going to +1 to the poster who suggested considering an impact driver in this situation.
Mine is a Ryobi, but regardless of brand, for driving tough screws it just does a much better job than most drills, while still being small and light.  I just checked and the Ryobi is apparently just a bit under 3 lbs, I'm guessing w/o the battery.
They are noisy, though...
Note that I do love my (older version) C12 as well.  It's great for most things, including most screws, but if I (rarely) run into screws that it chokes on, the impact driver will get them practically every time.
Since you already have other drills that you are using to make holes...
Pages: [1]   Go Up
  Print
Jump to:
