Author Topic: OF 1400 Trammell Unit  (Read 5643 times)
Offline infinidem
« on: January 04, 2011, 07:17 AM »
has anyone found a good trammell unit for the 1400.  the one available from Festool is only for a 1010.
Offline Peter Halle
  • Another Avatar Coming Soon
Re: OF 1400 Trammell Unit
« Reply #1 on: January 04, 2011, 07:43 AM »
The MFS 400 and 700 can be used as trammel units in addition to other uses.  MFS link
Offline Wood_Junkie
« Reply #2 on: January 04, 2011, 09:59 AM »
I recently picked up off eBay a 1300mm trammel for the Festool routers.  It is the OF-FZ 1300.  Pretty nice plexi/acrylic.  Like the saddle routing aid.
It's a "Festo" branded product, and I did some research.  It was last in the 2005 catalog, and then disappeared in 2006.
It wasn't cheap back then, at about 12x the price of the short trammel  ($193 vs. $16).  With price increases it'd be pushing about $250 now, I suppose.
You can see it here, on page 38:
And here's a glimpse:
Anyway, I will be putting it to use within the next two weeks making some 30" diameter round end tables for my wife.  The current trammel has 30" as its extreme limit and wasn't feeling as stable as I'd like for such a big routing task.
Various retailers have similar circle jigs.
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #3 on: January 04, 2011, 10:13 AM »
+1 on Peter's recommendation of the MFS.  Super accurate and flexible.
If this is for a one-off project, they are easy to make.  Use some plywood scrap.  Use the base of your router to mark where screw holes should be drilled.  Get some longer screws and screw the router to the end of the ply.  Plunge down to reveal the bit location.  Then measure the radius from the inner or outer edge of the bit, drill a hole for the pivot (nail, screw, rod, whatever) and you are done.  Need another radius?  Drill another pivot hole.
Offline Dovetail65
« Reply #4 on: January 04, 2011, 10:35 AM »
This has been said before, but skip the Festool trammels, there are far better and the best made, IMHO is the Micro Fence system.
Get a Micro Fence and get true precision and less monkeying around. The Micro Fence is made to order for precision matched radii and the only thing better that I have found is a CNC.
Festool really should get something of the Micro Fence caliber going. As it stands now my most accurate set up is anything with the Micro Fence attached. I happen to have an OF 1400 on one set up and an OF1010 on another and a floater Micro for any router I choose.
I am not sure there is anything that matches a Festool router on a Micro Fence for circle and radius cutting with a hand router. If there is I have not found it.  :)
Well, the little base that Micro Fence makes is sweet, but does not allow for a very powerful router.
Circle and Radii:
Plunge Base:
« Last Edit: January 04, 2011, 10:41 AM by nickao »
Offline Michael_MA
« Reply #5 on: January 05, 2011, 02:10 AM »
In addition to the recommendation of Peter and Jesse..
here is an video showing  showing the versatility of the MFS System for cutting rectangular cutouts for doors and stairs
- (1:50) - it shows also with how to cut an large arc-ed table with the OF2200
But i must admit, for smaller circles and cutouts it's a bit bulky to use, so the mentioned alternatives may be better here.
kind regards, Mike
« Last Edit: January 05, 2011, 02:22 AM by Michael_MA »
Glad to be back - pleasure to see familliar names..
Festool addicted since 2004
