Pages: [1] 2  All   Go Down
  Print
Author Topic: OK, what's the deal with lead and asbestos? (HEPA dust extractors)  (Read 4278 times)
moofie
Offline Offline
« on: February 27, 2011, 11:56 PM »
Hi, gang.  I am a weekend warrior, looking for a new dust collector.  My house is 100 years old, and does have lead paint.  It has some suspicious-looking ceiling tiles.  (pretty sure there's asbestos there.  Only thing I intend to do would be to take them down.)
Here's my question.  I want to be wise and prudent as I work around my house.  I don't expect that I'm going to have the EPA beating down my door.  Do the Festool dust extractors, with HEPA filters provide adequate common-sense protection against hazardous airborne particulates, or do I need to run for a contractor any time I contemplate working on these things?
I understand that the EPA guidelines are, well, not so good at guiding.  I've got some good resources here in my town that talk about how homeowners can work responsibly to mitigate these hazards.  I'm just trying to figure out if I'm cruisin' for a bruisin' without heavy duty containment systems (negative pressure rigs, whatever).
I'm hoping that I can use a good face mask (the 3M one with the good filters) and maybe a bunny suit for the asbestos.
I read a couple threads from last year, but I'm curious to see what the current thinking is like.  I read the manual for the CT26/36 and was surprised that they said they were not for vacuuming asbestos.  No mention of lead.  (I'm sure this is a liability issue as much as anything).
I understand this can be a touchy subject:  Lots of you folks make your living dealing with this issue, and it doesn't seem like the EPA is making your lives easier.  I'm just hoping I can benefit from your expertise.
Thank you!
LostInTheWood
Offline Offline
« Reply #1 on: February 28, 2011, 12:08 AM »
You can go here   epa.gov/lead to know what you need to know.    Other than that homeowners are not required to follow RRP rules.   If you want to be safe anyway just follow the general guidelines here (skip to page 13)  http://epa.gov/lead/pubs/sbcomplianceguide.pdf
Keep kids and pets out of the area.   If you need more details, then describe your project and I'll do my best to help you with the RRP.   I'm sure there are others here that can help too.
Oh and asbestos is an entirely different animal no to be related or confused with lead paint and RRP work.    Don't fool with asbestos.  Let the pro's do the abatement.
« Last Edit: February 28, 2011, 12:10 AM by LostInTheWood » Logged
Ken Nagrod
Restricted
Offline Offline
« Reply #2 on: February 28, 2011, 12:47 AM »
If you want to deal with the lead paint in your house, no problem using the CT's as long as you seal off the room/area you're working in and collect ALL the debris, wrap it all up so it can't escape, then you're allowed to dispose of with regular trash.  The asbestos can become airborne fibers that you as a homeowner or even a typical contractor cannot contain.  Even with a respirator and a suit, the stuff transfers easily and that's the problem - containment.  That's why the special air handling units, showers, etc.  Best and safest to let the expert remediator handle it all.  Once it's in your lungs, it's permanent!
moofie
Offline Offline
« Reply #3 on: February 28, 2011, 01:45 AM »
Thank you for the advice!  I'm not too enthused about dealing with the asbestos, but the lead seems more manageable.  Much appreciated!
Cableaddict
Offline Offline
« Reply #4 on: February 23, 2012, 04:36 PM »
I came here looking for similar info.
I am taking down a ceiling that I'm 90% sure has asbestos in in. (Brown cellulose tiles from the 1960's)
I cannot possibly afford to pay a specialist to come in.  Plus, a lot of the ceiling already fell, or was pulled down, so the stuff is already everywhere.
All I want to know is:
Do the new HEPA certified Ct vacuums contain asbestos, or put it back into the air?  Does anyone have a definitive answer?
FWIW:  I always use the fleece bags, and I also have glued hepa filters to the outside of my CT's exhaust ports, which not only contains the brushes' carbon dust, but makes the machine even more quiet.  (A highly recommended mod.)
« Last Edit: February 23, 2012, 05:01 PM by Cableaddict » Logged
Cableaddict
Offline Offline
« Reply #5 on: February 23, 2012, 05:15 PM »
Update:
I found a list that shows Asbestos fibers as being  0.7 - 90 microns, so theoretically a sealed HEPA vac (Which the new CT's evidently are) should work well.
Yet, several websites warn that HEPA vacs are not sufficient. They don't go into details.   Are they just being absurdly over-cautious?
« Last Edit: February 23, 2012, 06:07 PM by Cableaddict » Logged
Tom Gensmer
Offline Offline
Residential Remodeler in Minnesota
« Reply #6 on: February 23, 2012, 05:42 PM »
I'm EPA certified for RRP.
From the class I took, the message I got was that if you set up your containment properly, you should not have a great need for a HEPA vac unless you are sanding the lead-containing paint.
Speaking with other contractors who are doing a lot of lead work, the message that I am getting is that, to avoid cross-contamination, they DO NOT allow lead tools to be used for anything other than lead work.
Soooo....... if you are working with lead, treat it like you're working with asbestos. 6 mil poly on the floor, up the walls, set up air locks, etc.... HEPA respirators, Tyvek hooded suits, rubber gloves duct-taped to the Tyvek suit sleeves, boot covers. No one leaves the room until it's clean.....
Many contractors I have spoken with have stated flat-out that they won't bid on projects that might contain Lead. Too many liabilities to justify the potential gains.
In addition to potential EPA fines ($32,000 per infraction, per day), there are also the potential lawsuits from the people who may move into your house and 15 years from now have a child with a learning disability that they may blame on your disturbing the Lead. Regardless of how well you clean, there will likely be measurable Lead levels still in your home.
Anyways, what I'm getting at is, just buying a HEPA vac does not ensure a safe Lead project. Make sure you educate yourself, and make sure that you are ensuring the safety of not only yourself but also of future residents of your home.
Have a great week!
Best,
« Last Edit: February 23, 2012, 05:45 PM by Tom Gensmer » Logged
Kapex, CT-26, CT-Midi, RO-150, RO-90, OF-1400, EHL-65, DTS-400, Domino (WITH PINS!!), MFT/3, Sprinter full of Systainers
Umbro
Offline Offline
« Reply #7 on: February 23, 2012, 06:01 PM »
Festool sell a vac that they claim contains asbestos.
Haven't read up on it but remember seeing it when I was buying y CT26.
http://www.festool.co.uk/Products/Pages/Product-Detail.aspx?pid=584139&name=Special-application-mobile-dust-extractor-CLEANTEX-CTH-26-E-a
To be honest, it's a specialist job for a reason!
What price would you put on your health. You're a long time dead!!!
andvari
Offline Offline
« Reply #8 on: February 23, 2012, 06:20 PM »
You might be lucky. The type of tiles you describe don't necessarily contain asbestos. Those are usually white or gray. Before I did any work I'd investigate a bit, and get some testing done.
You might find this helpful.
http://inspectapedia.com/sickhouse/asbestoslookA.htm
Cableaddict
Offline Offline
« Reply #9 on: February 23, 2012, 06:24 PM »
Thanks, I have seen that site, and many others.  The ones that site shows are exactly what I have (they are brown on the inside, and asbestos can be white-ish, brown, or blue.)  Also, a contractor who has had other tiles tested said these look identical to known bad ones.
Regardless, why take a chance. Heck, I don't want to inhale cellulose fibers, either!
Hoping for the official word from Festool.
I'm VERY curious about the Ct 26 E/ a that Umbro linked.
It says: "Approved for dust category H and asbestos dust." - and: "For wood dust and dust with MAC values < 0.1 mg/m³ "
Plus they sell a special bag for it, # FIS-CTH.
Is this an older model, made redundant by the new filters?
Is it current, but only available in the UK? If so, can my new USA CT36 be modified to become this model?
« Last Edit: February 23, 2012, 06:40 PM by Cableaddict » Logged
WarnerConstCo.
Offline Offline
WWW
« Reply #10 on: February 23, 2012, 06:35 PM »
If it is your house and you are doing the work, you are exempt from following anything.
I still think the EPA is exempt from logical thinking too.
ccarrolladams
Offline Offline
« Reply #11 on: February 23, 2012, 06:41 PM »
The USA Federal EPA rules are a minimum. Individual States, Counties and Cities can and often do, make stricter rules.
Therefore, before doing your own lead removal, check with your local building inspectors and public health department.
When the time comes to sell your home, the fact you did your own lead removal could well be something you need to disclose to the buyer. This is a function of the real estate laws of your state.
Please consider the potential future liability before deciding to do your own lead removal.
« Last Edit: February 23, 2012, 06:43 PM by ccarrolladams » Logged
Tom Gensmer
Offline Offline
« Reply #12 on: February 23, 2012, 06:42 PM »
I agree that he would be free from following the EPA regs.
However, even if you're the homeowner, I would still worry about a future resident coming after you. Put a child with developmental problems in front of a jury and you'll lose every time.
Either way, it has the potential to be a HUGE can of worms. Tread VERY lightly with Lead, and don't even bother with Asbestos, hire it out. It's just not worth the risk.
Best of luck to you!
Ken Nagrod
Restricted
Offline Offline
« Reply #13 on: February 23, 2012, 07:40 PM »
As Tom Gensmer said, the correct method of remediation includes DEDICATED tools.  The CT's sold in the United States have not been certified for asbestos work.  That does not mean they aren't a good choice, but everything connected to the CT will have asbestos fibers within it.  The potential for a cross contamination or release is there.
As Carroll Adams said, check with your local authorities before shooting yourself in the foot (figuratively, because literally aint good either!).  Proper legal disposal is usually the toughest part for the homeowner.
justahobby
Offline Offline
« Reply #14 on: February 23, 2012, 08:09 PM »
If you do the work yourself (paint or asbestos), maintain a negative pressure in the cleanup zone.  And don't neglect to filter the exhaust air...no need to let any of this stuff in the air for others to breath.  As mentioned above, check your local regs: in my area (USA), VAT over certain square footage required certain levels of containment/ processing.  At 900+ sqft, I had a contractor do it.  If the material is friable, do what you can to have the surface wet to reduce airborne fibers.
If you have air quality testing done during or post removal, understand the testing process and the applicable permissible exposure limits.
Good luck and take care of the lungs!
ccarrolladams
Offline Offline
« Reply #15 on: February 23, 2012, 08:14 PM »
Each building and safety and/or health department could well have individual rules for lead and asbestos work.
My suggestion is that these are not practical DIY projects, largely because of future liability.
So, if FOG members want to have the lead removal experience, how about making friends with a certified contractor and joining a crew for a few days. Who knows, working with lead might turn out to be your personal bliss. In which case take all the needed classes, obtain the several required licenses and have at it. Same goes for learning to remove asbestos.
It is no secret I consider the money and time I spent participating in the 2011 Festool Solid Surface class instructed by Steve Bace to be an outstanding investment. By the third hour of working with solid surface material I realized doing so was far from my bliss. Knowing this has made my relationships with the many solid surface contractors I meet each year far better.
During my career I managed many projects which started out with asbestos removal. Despite using the best available contractors those jobs always ran longer than planned and cost far above the original budget. Just one case was a multi-story commercial building containing a late 1920s palace-size movie theater. The original budget was for 3 weeks at a cost of about USA$900,000. Before we finished removing the asbestos so we could deal with lead and everything else, we spent USA$18 million over 22 months. I was horrified, but the various inspectors kept telling me we actually lucked out.
At least a few years later, when my former employer sold that building to investors, all the inspection reports were solid gold.
Cableaddict
Offline Offline
« Reply #16 on: February 23, 2012, 09:37 PM »
...don't neglect to filter the exhaust air...no need to let any of this stuff in the air for others to breath.....  If the material is friable, do what you can to have the surface wet to reduce airborne fibers.
Good ideas, thanks.  I've got 2 industrial air purifiers running continuously, but didn't think about using water.
ANYWAY:
I still would like the basic answers to my questions, above, from a Festool employee.
Does the current CT36, which is HEPA certified and thus should contain material down to 0.3 microns, fully contain (within HEPA ratings) all asbestos dust, which theoretically will be no smaller than 0.7 microns?
If not, then what is the difference between my machine and the E / a units?
Can mine be "upgraded" ?
Will using those more expensive bags make a difference?
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #17 on: February 23, 2012, 09:52 PM »
Please don't take this as an official answer from Festool.  Shane's availability to the FOG is very limited this week.  Europe has different models of CT's with different filtering levels.  I have never seen Festool here in NA make claims about the CT's here being acceptable / approved for asbestos work.
Alex
Online Online
« Reply #18 on: February 23, 2012, 11:37 PM »
This is not an older model, it is a brand new model, but designed according to European standards. Standards that don't apply in America because America has its own. In Europe, for vacs there are 3 mayor classes, depending on the filtration needed. L is the lowest, most common class, M is the next step where filtration needs to be a lot higher, and finally class H for hazardous materials that need the best containment. That's why the naming for Festool vacs in Europe is different from America, in America all vacs are named CT, but in Europe they're named CTL, CTM and CTH to specify the dust class for which they are rated.
Sorry, but the CTH models (CTH 26 & CTH 48) and their accessories like the special dust bags, are only available in Europe. You can not order them from America because Festool forbids its dealers to sell tools to other countries. So Europeans can't order ultra cheap sandpaper in the States, and Americans can't buy vacs like the CTH 26 or the CMS system. Only way to circumvent this is to go to another country yourself or ask people you know in other countries to buy and send it to you. But there is no official way through Festool.
Theorethically, I think your machine could be upgraded. All CT vacs are based on the same parts with some minor differences. When I look at the parts diagrams I don't see any other differences but the filter, filter bags, and the flow detection unit of the CTH. But you won't be able to buy the parts from Festool directly because they're only sold in Europe. Even if you could, it would turn out very costly.
As for the bags, they will make a difference, but most of all, they're meant to be 100% safe when filled and removed from the vac. After all, the H class vacs are meant for hazardous materials.
I'm no Festool employee, but I'm pretty sure they will not confirm you can use them for asbestos. The only thing that's official in America is that all Festool vacs are rated for HEPA, but I believe the HEPA specification doesn't say anything about asbestos.
WarnerConstCo.
Offline Offline
WWW
« Reply #19 on: February 24, 2012, 12:08 AM »
Asbestos and lead have been blown out of proportion.
Asbestos is pretty harmless as long as you don't turn it into powder and snort it.
heck, 1/2 the water mains in most towns are lead pipe......
Ken Nagrod
Restricted
Offline Offline
« Reply #20 on: February 24, 2012, 01:27 AM »
That explains the extra eye on your back.
Cableaddict
Offline Offline
« Reply #21 on: February 24, 2012, 01:33 AM »
I agree with that first part.  Not quite as much with the second, but also to SOME extent.  That's why I don't feel the need to starve for 2 months in order to pay a pro to clean this up.
Still, it would be foolish not to be as careful as possible.
Alex, thanks for that info.  Very helpful.
« Last Edit: February 24, 2012, 01:35 AM by Cableaddict » Logged
mastercabman
Offline Offline
NORFOLK,VA
« Reply #22 on: February 24, 2012, 07:21 AM »
I agree,leave it alone and you will be fine.
andvari
Offline Offline
« Reply #23 on: February 24, 2012, 11:03 AM »
If you are a smoker, exposure to asbestos increases the likelihood that you will get lung cancer by 50 times. It's a really bad combination.
http://www.atsdr.cdc.gov/asbestos/site-kit/docs/CigarettesAsbestos2.pdf
« Last Edit: February 24, 2012, 11:19 AM by andvari » Logged
Holzhacker
Offline Offline
WWW
« Reply #24 on: February 24, 2012, 11:24 AM »
Lead, asbestos, blah, blah. Some of the discussions would lead you to believe you'll get cancer or die just looking at it. The rules are in place because the products CAN be hazardous. Everyone has different levels of physical tolerance and that's why we need protective rules. I grew up in a town with lead mains, we still have lead mains. Would I be smarter if I had grown up in a town with only copper water mains? Who knows. HUD came out with an article a couple years ago that stated that kids weren't getting much lead poisoning from eating lead paint (which has tended to be the common assumption). The study showed that lead poisoning was primarily coming from airborne contamination. As much as the rules may be a PIA do any of us want to breathe crap because the neighbor hired a slimeball contractor?
As far as asbestos, I feel for the people who have gotten sick. Unfortunately I can't buy into the severe predictions of asbestos exposure. If it were that bad I'd be long dead.
andvari
Offline Offline
« Reply #25 on: February 24, 2012, 11:48 AM »
It's all statistical. You might go swimming in the stuff and have nothing happen. What is known is that thousands of people die from it every year. As such the precautions are justified.
Cableaddict
Offline Offline
« Reply #26 on: February 24, 2012, 04:52 PM »
BUMP.
Still waiting for an official answer from Festool.
Tom Gensmer
Offline Offline
« Reply #27 on: February 24, 2012, 05:20 PM »
Lead pipes is NOT THE SAME as lead paint. The Lead paint itself is relatively harmless, it's the DUST that it produces that can be harmful.
Also, we need to separate the difference between ACTUAL risk levels versus PERCEIVED risk. I agree that most of us grew up in houses that contained some amount of lead based paint. Did it affect us? Well, not as far as we know.
The issue for contractors is, the EPA DOES think it's a significant issue, and will fine you over $32,000 PER DAY if they find that you are not in compliance with the regs. It doesn't matter if you disagree with them, or think it's a non-issue. The EPA has already started to fine contractors, starting back in early 2011.
As for homeowners performing the work, I suppose it depends on how long you plan to live in the house. Something to consider is resale. As mentioned above, when you go to sell the place and the potential buyers look at your place and say "Hmm, 100 years old, looks like you've remodeled recently, who did your RRP work?". Again, it's all about perceived risk. Some people may be like-minded, shrug their shoulders and say "oh well, no big deal".
Then there is the crowd like a customer I worked for last summer. My helper accidentally broke two CFL bulbs in an unfinished attic. I drove to the home center to buy two new CFL's to match the ones my helper broke. The customer met me at the front door and just about lost her mind. She was just barely able to restrain herself from screaming at me, going on about all the mercury that was released into her house, and how would we clean up the "toxic waste" in her attic?
Granted, the EPA is not going after homeowners. But what about the people you sell the house to? When their baby grows up and develops a learning disability and haul you in front of a jury, which side do you think will win? The disabled kid will win 100 times out of 100.
Anyways, I'm not trying to dissuade anybody from working on their homes. Just practice safety. Follow the EPA guidelines. Cover your butt. Wear the Tyvek suit, wrap everything in 6 mil plastic, and document EVERYTHING. Whenever I start a Lead job one of the first things that I do is document that there is already Lead in the soil, because if you live in a metropolitan area there WILL be Lead in the soil, and you need to document that it was there prior to your involvement.
The negative pressure idea is a no-no, unless you are filtering the outgoing air with a certified HEPA filtration unit. The list goes on and on....
As for the Asbestos thing, hire it out, hire it out, hire it out. If you do try to tackle it yourself, buy a vac designed specifically for asbestos, and either sell it or dispose of it when you're done. My guess is that Festool is going to tell you that, in the North American market, they do not recommend the use of any of their dust extractors for Asbestos work.
I'm not trying to be a party pooper here, but there are potentially HUGE criminal and civil liabilities here, and any project involving Lead or Asbestos should be undertaken with a high degree of caution.
Thanks!
Best,
(stumbles off of soapbox)
WarnerConstCo.
Offline Offline
WWW
« Reply #28 on: February 24, 2012, 07:51 PM »
Spray asbestos with water if you have break it up.  Spray the bags with water, water keeps the dust down.
I see asbestos abatement companies all the time just knocking the stuff down, no suits or respirators,  just knocking it down and hosing it with water.
Just waking up and going out to get in the truck is hazardous enough.
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #29 on: February 24, 2012, 08:02 PM »
BUMP.
You might want to send an email.  Lots of people are out of town and playing catch up on threads will be tough next week.  Your post has a good chance of being overlooked.
Pages: [1] 2  All   Go Up
  Print
Jump to:
