bonesbr549
Offline
I'd rather be woodworking
« on: June 30, 2010, 08:11 PM » |
Well I went by the local woodcraft today to see if they could get the new oneda dust-deputy cyclone for the CT vaccum. I've looked at it for a while now and decided what the heck. I could order it from oneda for $249 + 19 shipping. The manager indicated he had seen it and would see what he could do. He called back and indicated they would start to carry it, and it's going to end up a little cheaper but not much but heck a few bucks is a few bucks. Anyway, I will have it next week and will post a review once I get it. Anybody else here have one? http://store.oneida-air.com/dust-deputy-festool.aspx
Tom Bellemare
Festool Dealer
Online
« Reply #1 on: June 30, 2010, 08:22 PM » |
I have some...And I don't charge shipping. Tom
bonesbr549
Offline
« Reply #2 on: June 30, 2010, 09:19 PM » |
I have some...And I don't charge shipping. Tom thats the story of my life. I put the order in today! Or I'd taken it. Sorry.
Wood_Junkie
Online
Location: Madison, Wisconsin - USA Member Since: Dec 2009
« Reply #3 on: June 30, 2010, 09:35 PM » |
I'm curious if this would be "mountable" on a CT Mini or Midi? Does the Oneida box clip on using the Sys latches, or just sit there in the hose garage of the CT22/CT33?
It seems like the most "bag" for the buck would be realized with the lower capacity vacuums. You get the extra volume capacity (for many fewer emptying trips) and also use fewer bags.
JeromeM
Offline
« Reply #4 on: June 30, 2010, 10:02 PM » |
It latches onto the vac. The only possible problem is that you do loose a small amount of suck. So if the vac is just coping at full power it may not with a cyclone in the loop. I use a clearview with a CT22 and there are almost no problems.
Tom Bellemare
Festool Dealer
Online
« Reply #5 on: June 30, 2010, 10:40 PM » |
if this would be "mountable" on a CT Mini or Midi? I haven't tried it yet, but it should have no problem mounting. It mounts just like another Systainer to the Sys-Dock. I don't know how effective it is but I suspect it has similar qualities. I'll find out tomorrow and report. 'Gotta go do some things now... Tom
rtanton
Offline
« Reply #6 on: June 30, 2010, 10:47 PM » |
I picked up and installed one on a CT22. It mounts easily and the dust collector is sturdy. There does not appear to be any loss of suction and I look forward to not constantly changing bags.
Corwin
Online
« Reply #7 on: June 30, 2010, 10:53 PM » |
Hey Junk, I also have the NAAM (not available any more) ClearVue cyclone on one of my CT22s. As mentioned, the new DD should mount onto a Mini or Midi as well as the larger CTs. As for the most "bang for the buck," that would arguably be the one of Oneida's other models of their Dust Deputy. This new version made for the Festool extractors is a premium, but the basic model does the same job for less $$$.
Wood_Junkie
Online
« Reply #8 on: June 30, 2010, 11:49 PM » |
Excellent, thanks for the information everyone.
Knock on Wood
Offline
« Reply #9 on: July 1, 2010, 09:23 AM » |
Does anyone know what the small plastic tubing is for that runs from the Oneida Container to the 90 degree elbow that enters the Festool Vac... it can be seen in picture #3 of the 4 thumbnail pics.
Jim
Measure twice.... cut once.... pound to fit.
bonesbr549
Offline
« Reply #10 on: July 1, 2010, 09:35 AM » |
I'm assuming it applies suction to the bag to keep it out against the wall of the container.
Monju123
Offline
Location: Katy, Tx (Katrina-ed out of New Orleans) Member Since: Mar 2008
« Reply #11 on: July 1, 2010, 10:06 AM » |
Can anyone tell me if this makes a CT22 taller than the handle assembly? Mine just fits into it's cubbyhole and I can't afford for it to be any taller.
TS55, Domino, OF1400, RO150,CT22, MFS 200-400-700, LR32,Parallel Guides
rtanton
Offline
« Reply #12 on: July 1, 2010, 10:16 AM » |
The bin is about an inch shorter than the handle, but with the cyclone on its top it is much taller than the handle. If you need an exact measurement let me know. Does anyone know what the small plastic tubing is for that runs from the Oneida Container to the 90 degree elbow that enters the Festool Vac... it can be seen in picture #3 of the 4 thumbnail pics.
Jim
The unit that I purchased and installed does not have the small plastic tube. There is no reference to it in their instructions. Russ
twang120
Offline
« Reply #13 on: July 1, 2010, 10:16 AM » |
I do not have the handle assembly, but have the DD/Festool on my CT22. The outlet out the top of the cyclone is pretty high up, probably more than 4ft off of the floor. The black plastic dust container looks similar in size to a systainer 4. Add the cyclone at another 12-16" high or so.
1010 router, 1400 router, RO150 rotex, C12 Drill, TDK12 drill, TS55 Saw, midi vac, CT22 Vac, MFT3, DTS400, Trion jigsaw, new Domino, DTS400 sander
Tom Bellemare
Festool Dealer
Online
« Reply #14 on: July 1, 2010, 10:28 AM » |
I'm assuming it applies suction to the bag to keep it out against the wall of the container. You are correct, bones. That was added since the first batch, Russ. Tom
rtanton
Offline
« Reply #15 on: July 1, 2010, 11:19 AM » |
I'm assuming it applies suction to the bag to keep it out against the wall of the container. You are correct, bones. That was added since the first batch, Russ. Tom Thanks for your post Tom. I ordered the tube from Oneida.
