Pages: [1] 2  All   Go Down
  Print
Author Topic: Parallel Guides on YouTube?  (Read 12271 times)
Neill
Offline Offline
« on: July 22, 2009, 05:54 PM »
I am kind of interested in the parallel guides but don't quite understand how they work.  I know there are some write-ups and pics out there but I seem to understand things best when I see them in action.
I have done a search but can't seem to find any instructional videos.  Does anyone know if there are any out there?
Thanks.
Neill
Kapex, Domino, MFT/3, Rotex 150 FEQ, CT 22E, TS 55, C12 Drill, 1400 Router, Rotex 90 DX, Rotex 125 FEQ, LS 130 EQ Linear, Parallel Guide Set, Deltex 93 E, Trion 300 Barrell Grip, ETS 150/3 EQ, ES125 EQ, Guide Rail Accessory Kit, Sanding Block, various rails, systainers, sortainers, vacuum hoses and accessories for various tools.
Dave Ronyak
Offline Offline
Flyin' from NE Ohio
« Reply #1 on: July 22, 2009, 09:05 PM »
I was not successful in locating a video, either, but did note Brice Burrell's PDF tutorial and review on www.FestoolUSA.com, and Jerry Work's PDF review and tutorial at http://www.mcfeelys.com/docs/IS/495717.pdf and elsewhere.  Both are very well done and should address many of your questions.  When I checked Brice's website, I did not see a video on this topic, but did find http://www.festoolcanada.com/media/pdf/review%20of%20the%20festool%20parallel%20guides.pdf.
Dave R.
Neill
Offline Offline
« Reply #2 on: July 23, 2009, 09:38 AM »
Dave R.
Dave,
Thank you for the links.  I had looked at Jerry's and Brice's write-ups briefly before, but this time since I am actually considering the purchase, I looked a bit harder and actually printed them both.
I was not able to open the link to Festool Canada, but I thank you for that one as well.
By the way, just wondered where you were In Ohio.  I am a former Clevelander.
Neill
woodshopdemos
Inactive Member
Offline Offline
WWW
« Reply #3 on: July 26, 2009, 02:06 PM »
Eleana and I   reviewed the new parallel guide system and like 1/2 of it. SO much so that we use that setup each and every day.
Here is the story: http://www.woodshopdemos.com/Fes-Parallel-1.htm
In memory of John Lucas (1937 - 2010)
Neill
Offline Offline
« Reply #4 on: July 27, 2009, 09:43 AM »
John,
Thank you once again for your insight.  I really like your not so serious approach to what you do.
Neill
Christian Oltzscher
Festool Employee.
Offline Offline
WWW
« Reply #5 on: July 28, 2009, 03:07 PM »
Here it is:
Neill
Offline Offline
« Reply #6 on: July 28, 2009, 03:56 PM »
Christian,
Thanks so much.  I have a much better idea of how they work.  I will probably watch a few more times until the fine points of calibration sink in.
I definitely think this an investment I will make in the near future.  The parallel guides definitely add more precision and functionality to the saw and guide rails.
Neill
EcoFurniture
Offline Offline
WWW
« Reply #7 on: July 28, 2009, 04:34 PM »
Good Video! Thanks.... now I have to get one too Cheesy
woodshopdemos
Inactive Member
Offline Offline
WWW
« Reply #8 on: July 29, 2009, 11:36 AM »
WOW!!!. I just watched the video and 9 minutes and 57 seconds of great explanations. And I have to say that my earlier post isn't wrong but it isn't complete either. There are so many little intricacies brought out in the video. A picture is worth....
   For sure, Elena and I will have to revisit our setup. That said, we still make full use of one half the guide system for every cross cut.
fshanno
Offline Offline
« Reply #9 on: July 29, 2009, 10:51 PM »
Good video.  I'd like to see one demonstrating the use of a single arm as a t-square.
A note about the metric rule.  I wish I could have stuck with it.  Goodness knows I tried.  But it was killing me so finally I tore it off.  When I stuck the imperial rule on I made sure it was almost touching the indent on the stop when the stop is locked.  I think that represents a small enhancement because the metric rule was stuck on so that a gap of over a millimeter existed between the ticks on the rule and indent on the stop with the stop locked.  Another little advantage is that I went all the way out to 26 inches which is farther than the stock rule.
Wonderwino
Offline Offline
« Reply #10 on: August 27, 2009, 03:01 PM »
Great video of the parallel guides!  If it was done with two cameras and a lapel mic, the production quality would have been a little better.  Clear audio and one camera to cut to closeups.  I ordered the parallel guides after Brian demonstrated them to me when I stopped in on my way through Indiana.
Water separates the people of the world; wine unites them.
Mike B
Offline Offline
« Reply #11 on: August 27, 2009, 07:59 PM »
Yep, good video.  Smiley
I do have a question though. How much of the combined saw/track/guide weight sits beyond the edge of the bench when using the parallel guide extensions? I only ask as if I was cutting to retain the piece on the right of the blade, I would want to take the weight of it or somehow catch it as the cut was completed to avoid it falling or tearing off with 10mm left to go. I know I can clamp the work to the bench, but if too much weight is over the edge I'd feel less comfortable running the saw with my left hand so as to hold the cut piece with my right.
Kapex | PS 300 | EHL 65 | TS 55
Jimhart
Offline Offline
« Reply #12 on: August 27, 2009, 09:26 PM »
I can't remember the gentlemans name in the video, but if he's part of the faculty at the upcoming sessions you're in for a treat.
He did a lot of the demo's at Timmy C's Festool Fest in Lincoln last year. I happened to be in town for the football game and got a chance to see a few of his sessions. Very entertaining and a wealth of knowledge.
PS- I'm glad I didn't get picked for the sessions. My mon called and there's a 4 generation family reunion in Chicago that overlaps. I would have missed seeing all those relatives I haven't seen in years.  Cheesy
Brice Burrell
Online Online
Remodeling Contractor
WWW
« Reply #13 on: August 27, 2009, 09:32 PM »
He did a lot of the demo's at Timmy C's Festool Fest in Lincoln last year. I happened to be in town for the football game and got a chance to see a few of his sessions. Very entertaining and a wealth of knowledge...............
That's Brian Sedgeley, he's based in Lebanon so I bet he'll be there. Great guy and fun to be around.
fshanno
Offline Offline
« Reply #14 on: August 27, 2009, 11:51 PM »
You'd want to support that work piece with horses.  He's probably using an MFT probably because that's what he has at hand or because he wants to keep the whole setup Festool.  Here's the setup that you'd use.
As you can see the whole work piece is supported by the horses.  The arms of the parallel guide are floating.  They sag in the back but it's inconsequential.  The weight of the saw forces the guide down flat on the surface so the desired bevel of the cut is correct.
You're going to need 4 tall horses that are at least 48" long.  I have never made a cut with my parallel guide that involved my MFT.   Cutting platforms don't work well either.  You need variable width support.  You can see that I have the horses' legs overlapped so they can be close enough so they support but don't interfere.  Good old fashion horses, that's the ticket with the FS-PA/VL
fshanno
Offline Offline
« Reply #15 on: August 28, 2009, 12:09 AM »
I forgot to mention one thing in my recent post.  Another thing you gain when you let the parallel guide arms cantilever past the sides of work piece is that you can cut any thickness material.  And that highlights the need to have 4 horses the same height available to handle the unique demands of cutting with the parallel guides.
Mike B
Offline Offline
« Reply #16 on: August 28, 2009, 01:32 AM »
Nice, thanks for the information and the picture! The variable width aspect is indeed something to be considered, though in some of the places I've worked finding ground flat enough for 4 sawhorses to be level is a challenge!
The sag might be inconsequential but I'm still surprised Festool didn't build small flanges into the stops (as I recall you did with your extension rails) so they could hang up on top of the  timber to stop the sag. I can't see how that would effect their operation.
fshanno
Offline Offline
« Reply #17 on: August 28, 2009, 09:30 AM »
I drilled holes thru the stops for mounting a flange for that purpose.  I had little metal plates as the flanges but that's not a good idea, they need to be something the saw can cut.
Maybe Festool could make some fancy aluminum horses just for this setup.   I wonder what they would cost?
BMH
Offline Offline
« Reply #18 on: August 28, 2009, 09:43 AM »
Very good video. Brian said that the rails do not guaranty squareness, just equal cuts. Is there a way to guaranty squareness ?
Bruce
Jimhart
Offline Offline
« Reply #19 on: August 28, 2009, 10:34 AM »
Bruce
Since the equal cuts should be parallel to one another, i'm assuming he's talking about the cuts not necessarily being 90 degrees to the ends of the piece. There has been discussion here that you can use one guide butted to the piece you're cutting to make a 90 degree cut. Otherwise, any technique you use to make your crosscuts 90 degrees.
Is this what you were asking?
Jim
Wonderwino
Offline Offline
« Reply #20 on: August 28, 2009, 01:37 PM »
When they are properly calibrated, the guides can be very close to square.  I would still verify by laying a quality speedsquare on the board with the thick edge against the parallel guide and the thin against the rail.  I use a Woodpeckers version.
fshanno
Offline Offline
« Reply #21 on: August 28, 2009, 05:52 PM »
Bruce
When using one arm as a t-square you need to tighten the two brass screws.  That will tighten the arm on the guide removing wiggle at the opposite end of the guide.  If you don't tighten them there is play.  This is natural, otherwise you couldn't get the arm to slide onto the guide.  Once the screws are tight the arms squareness is determined buy all the gear that makes up the arm, the casting, the extrusion, all of it.  Mine is very close, good enough for 24" cross cuts on sheet goods, less than a 64th off at that width.
If you get hold of one that's off, not square even after tightening the little screws, there's bound to be a way to tune it.
Tom Bellemare
Festool Dealer
Online Online
WWW
« Reply #22 on: August 28, 2009, 10:22 PM »
Well put, Fshanno...
It isn't that one can't use the set up as a way to square a guide rail... It's that it isn't designed to "necessarily" be a guide rail squaring device.
By using all of the adjustments available, and there are many in the system, one can make these do more than they are advertised to do. That's just like most well made tools.
Look through the threads on these guides and you will see many excellent adaptations.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
BMH
Offline Offline
« Reply #23 on: August 29, 2009, 11:22 AM »
Thank you all for your answers. The video demonstration and follow up discusion help clarify the capcity and limitation of the system. Hopefuly we will see more quality video from Festool on all of their products.
davidaz
Offline Offline
« Reply #24 on: October 05, 2009, 10:16 PM »
I have a quick question on the parallel guides, as I am considering acquiring a set. All the demos use what appears to be near 3/4" stock. The thickness of the guides mounted under the guide rail raises the rail to the thickness of the parallel guides, correct? Does that present a problem if cutting 1/8" stock or something thicker like 1" stock where the guides would not sit flat on the work area? The approx thickness of the guide rail is 185mm so what if one needs to cut 1/8 or 1/4" stock in widths less than 185mm? I assume the use of the extensions would solve this but I am still confused with having the guide rail and zero clearance edge not resting on the surface of the boad being cut. Can some of you who have this system help explain. David
Brice Burrell
Online Online
WWW
« Reply #25 on: October 05, 2009, 10:28 PM »
David, I discuss the issue of the cutting stock less than 3/4" in my review of the guides, review of the parallel guides. The info you want is on page three of the review but taking a look at the whole thing might be helpful.
In short I use shims under the stock to raise the stock up the rail. The guides themselves can be unsupported with little or no problems in use.
Tom Bellemare
Festool Dealer
Online Online
WWW
« Reply #26 on: October 05, 2009, 10:49 PM »
David:
Quote
I think that's the same thing Brice means when he says:
Quote
Just dangle them off the sides of the work piece and you can cut as thick or thin as you want. That assumes that you don't have anything in the way of them dangling.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
davidaz
Offline Offline
« Reply #27 on: October 05, 2009, 11:12 PM »
Brice and Tom
Thanks so much for you quick updates they were both very helpful and Brice your review totally answered several other pending questions so its time to make the plunge with the wallet.  Thanks again!
EcoFurniture
Offline Offline
WWW
« Reply #28 on: October 05, 2009, 11:52 PM »
I will be ripping 20 sheets of bamboo ply tomorrow and be using the guides on the first bigger project since I got them. So far, I haven't been really impressed as my usual method (pencil line) was faster and most of the time "close enough".
Anyhow, I haven't given up, so will see how tomorrow goes.
quietguy
Offline Offline
« Reply #29 on: October 06, 2009, 12:21 AM »
Quote
I have had a love/hate relationship with my parallel guides, and it took a little time to figure out when to use them and when it was more trouble than it was worth.  After a little experience, they are now one of my favorite Festool accessories.  If you take their operation into account when making your cut list, it makes a huge difference.
Pages: [1] 2  All   Go Up
  Print
Jump to:
