Pages: [1]   Go Down
  Print
Author Topic: Plywood bits for OF 1010  (Read 2123 times)
JimB1
Offline Offline
« on: February 26, 2012, 05:10 PM »
I'm going to be starting the casework for my kitchen island soon and I have a few pieces that are going to be a bit long and awkward to try and get a good cut on the tablesaw with a dado set. Going with the theory that it's easier to bring the tool to the wood in this case, my 1010 seems to be up for the challenge Smiley . I did a couple of test cuts using a standard 3/4" straight bit and the fit's not horrible but I'd like to get it a little tighter if possible.
Freud, Whiteside, and a few others make slightly undersized bits for routing plywood so you get a tight fit in dados and grooves but I haven't used any of them yet. Really doubting I'll find any with a 8mm shank but 1/4" shank with the straight 3/4" bit seems to work fine (only going 1/4" deep for the dados) so I'm guessing any good name brand 1/4" shank bit is going to work out OK.
Anyone using their 1010 for plywood dados? Any favorite bits to use for this?
Any help is appreciated...
-Jim
OF 1010, RO 150, ETS 150/3, RTS-400, Pocket StickFix Sanding Block and a CT Midi
pugilato
Offline Offline
« Reply #1 on: February 26, 2012, 05:35 PM »
You might want to look at Joe Fusco's (RIP) series on cabinetmaking... No dados used to build what appear to be pretty sturdy base cabinets.
SRSemenza
Global Moderator
Offline Offline
« Reply #2 on: February 26, 2012, 05:48 PM »
You could also go with a 1/2" (or anything less than the plywood thickness)  straight bit and sneak up on an exact fit.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
Jay Evans
Offline Offline
« Reply #3 on: February 26, 2012, 05:56 PM »
Jim,
You could always measure your plywood and see if straight metric bits would work, They can be bought from Festool with metric shanks and although a bit pricey and needing to be ordered, Festool does make EXCELLENT router bits.
John Lucas (RIP) from Workshop demos, had a really neat method of making exact slot sizes with the Festool system and some playing cards- a search should help you find it, plus I believe you can still get his archive DVD through Woodcraft(?).
I thought it was a clever idea.
Good luck
Jay
andvari
Offline Offline
« Reply #4 on: February 26, 2012, 06:50 PM »
Paul Marcel did a video showing how to make exact fit dados with several tools including a router+rail and the Bridge City Kerf Maker.
http://www.halfinchshy.com/2011/06/bridge-city-km-1-kerfmaker-users-guide.html
The router bit is about 2/3 the way into the video.
woodwreck
Offline Offline
« Reply #5 on: February 26, 2012, 09:09 PM »
I don't understand your issue - as you point out numerous manuf make 1/4" shank bits for the three undersize plywood thicknesses, nominal 1/4, 1/2 and 3/4 with 1/4" shanks. For heavier work sure you want a 8mm adapter to half but the 1010 is 1/4" shaft I believe. You state you are only doing 1/4" deep.
For example see also, Rockler.com, P/N 9011, 90110, 90264
Regards,
Woodwreck
ccarrolladams
Online Online
« Reply #6 on: February 26, 2012, 09:33 PM »
Actually, the Festool OF1010 router uses and is supplied with both 1/4" and 8mm collets.
sancho57
Online Online
« Reply #7 on: February 26, 2012, 09:47 PM »
I used to use other methods pocket holes, dados etc… Till I saw Joes video, I had a conversation with him ( May he RIP) and He was the one that got me interested in Festool.
I also use his method now for building cabinets.  I can honestly say I have not had a failure yet.
Here is the link to his U Tube Channel
http://www.youtube.com/user/joefusco1960?blend=1&ob=5#p/u/17/CGYBJQUxE7Y
Shhhhhh Dont tell the wife butttttt I bought another…….
billg71
Offline Offline
WWW
« Reply #8 on: February 26, 2012, 10:32 PM »
I like the Freud downshear mortising bits, they give a pretty clean cut on both sides and they're available in 1/32 undersizes for ply.
For the absolute ultimate in fitment you'll need to make yourself a jig: Cut two straight rips of the material you're using, long enough to span your workpiece plus a a few inches for a couple of spacers and whatever you want to use for a fence. Add a fudge factor for trimming. They should be half as wide as the OF1010's base or more, if you're routing 24" case sides I'd suggest 4" or wider for strength. Make two short crosscuts from your shelf material, slightly shorter than its thickness.  Turn them 90 degrees and use them as spacers to glue the two rips together, don't clamp them real tight(you might want to add a piece of brown paper bag as a shim so you can get the shelf in). Now crosscut one end of the assembly dead-nuts square and add a fence.
 Clamp the jig across the work and use any top-bearing flush trim bit smaller than the thickness of your shelf and short enough to allow for the depth of the dado and the thickness of your jig. Rout out out your shelf dado up one side and down the other and avoid climb-cutting.  Just make sure you're routing in the right direction. If you want to be picky get yourself a 1/4" shank downshear bit and a bearing to match. Now you're officially splitting red cat hairs....   Wink Just don't forget the brown paper bag or you'll never get the thing together....
It's a matter of paying your money(or time) and taking your choice. For me, the 1/32 undersize bits are close enough as long as I'm consistent in assembly. YMMV.
HTH,
Bill
« Last Edit: February 26, 2012, 10:37 PM by billg71 » Logged
"Born to fish, forced to work..."
woodwreck
Offline Offline
« Reply #9 on: February 27, 2012, 12:30 AM »
Agreed, but my thought was that the undersize bits in in question to my knowledge are available in 1/4 or maybe in  1/2 shank and the 1010's 8mm just isn't applicable. If I misunderstood the issue, my apology.
Regards,
Woodwreck
TomGadwa1
Offline Offline
« Reply #10 on: February 27, 2012, 05:03 AM »
As stated above the OF1010 is supplied with a 1/4 inch collet. Freud makes under sized plywood bits in the 1/4 inch collet sizes. These are nice bits and will make a snug fitting dado.
TS55 EQ  OF1400 EQ  DFQ 500 Q  RO 125  LR32 SET  Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E  Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
JimB1
Offline Offline
« Reply #11 on: February 27, 2012, 09:40 AM »
Not really any issues per se with 1/4" vs 8mm, just that if I am buying new bits, I'm willing to look at 8mm as well if someone has a source but there's just not that many out there in NA. Like I said, I can't see using a plywood size bit for more then 1/4" deep dados, grooves and rabbets so 1/4" shank should be fine. I never really used a router for dados before. Until I got the 1010 I really didn't like using a router by hand so I don't have a lot of bits and I'd like to start using the router more since now I have a good one. Usually I just use a dado set in the tablesaw and move on with life, so I don't know much about brands of bits or if the ply sized bits are good so I was hoping to get some first hand reviews.
The rest of the cabinets are done so I just have a refrigerator frame and the island to do so I'm not looking to change the build type in mid build but some good vids you guys linked to. Maybe when I rework my garage I can try those cabinets...
I'm just not all that conversant with using routers by hand I guess is what it comes down to Smiley
Thanks for the suggestions and info so far...
-Jim
GreenGA
Offline Offline
JR
« Reply #12 on: February 27, 2012, 01:09 PM »
I agree with andvari.  Thumbs Up
Using the KM-1, as shown in Paul's video, allows the thickness of the plywood to be all over the place, and it might very well be, even from the lot, and you still can get a perfect fit every time.
Never use a 2x4 when a 2x6 will do just as well
SYS-Lite, CMS/GE, TS55, KAPEX, MFT/3, CXS Kit, C15 Set, TI 15 Set, C12 Set, CT48 w/Boom Arm, HL850, RO90, RTS400, DTS400, LS130, DX93, RO150, ETS 150/3, RAS 115/4E, RS2E, Domino Classic, OF1010 EQ, OF2000E+, OF1400, MFS700, LR 32-SYS+97" rail, 2011 Centrotec, Zobo Forstner Bit Set, Guide Rail Kit, Parallel Guides, Tradesman Cleaning Set, Shinex, lotsa 'tainers (Sorts, Attics, Classic, New and Blue).
Coming Attractions: MFK700 Kit, Workcenter, Domino XL Kit, Carvex 420 & Accessory Kit
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #13 on: February 27, 2012, 01:39 PM »
...You could always measure your plywood and see if straight metric bits would work, They can be bought from Festool with metric shanks and although a bit pricey and needing to be ordered, Festool does make EXCELLENT router bits.....
The last I made dados use Metric bits for plywood.
I'd agree, screws work great assuming you can hide them.  I miss Joe's willingness to to help out in on the construction forums.  He sort of came off as a typical New Jersey knucklehead* in some of his videos, but the guy sure knew his stuff.  His site was filled with some great construction info.  At least his Youtube channel is still up.
* No offense intended to our New Jersey knucklehead friends out there. Tongue Out
Ken Nagrod
Restricted
Offline Offline
« Reply #14 on: February 27, 2012, 01:43 PM »
Brice,
I'm a pinhead so no offense taken.  Big Grin  Tongue Out
BTW, Joe was from Staten Island, NY
« Last Edit: February 27, 2012, 01:45 PM by Ken Nagrod » Logged
zapdafish
Offline Offline
« Reply #15 on: February 27, 2012, 02:49 PM »
IMO plywood bits by themselves are absolutely useless unless you are extremely lucky and your plywood supplier happens to match your bits. When I first got into woodworking they sounded like such a great idea till I discovered that 3/4" is measured differently by different manufacturers.
If the bits are undersized you can waste alot of time sanding the ply to fit and if they are oversized you get loose panels.
PaulMarcel
Online Online
WWW
« Reply #16 on: February 27, 2012, 03:15 PM »
The best way to make a dado/groove for plywood is by running two passes.  I think the key is that plywood is 'nominal' 3/4", which is a bit of the industry word to mean "take what you get; we don't check it".
I have a set of plywood bits, but not because I expected to use them for a one-pass groove that would fit well.  Since I use two passes, it doesn't matter the size of the cutter as long as it is larger than half the size of the groove I want.  I got the plywood set on a clearance for next to nothing; they work well (not as well as a nice spiral, but I didn't get 4 spirals for $9).  As Andvari and GreenGA mentioned, I use the KM-1 to exactly size the groove.  There are other ways to do it, but that one is fast and usable on a number of tools (dado stack comes to mind).
Speaking of spiral bits, a compression spiral will give you very clean and fast grooves.  That's all I use when grooving plywood unless it is really shallow in which case I use a down-spiral.
Shirt size: L Cool
Twitter: @HalfInchShy
ccarrolladams
Online Online
« Reply #17 on: February 27, 2012, 03:43 PM »
I agree with Paul, for nominal 3/4" plywood I use 12mm compression spiral bits. For nominal 1/2" plywood I use 8mm compression spiral bits. For nominal 1/4" plywood I use 4mm bits.
Jim Kirkpatrick
Offline Offline
« Reply #18 on: February 27, 2012, 04:03 PM »
Don't waste your money on fancy bits that will never fit sheet to sheet.  John Lucas's tip works flawlessly.
Sent from my DROIDX using Tapatalk
« Last Edit: February 28, 2012, 08:03 AM by Jim Kirkpatrick » Logged
sancho57
Online Online
« Reply #19 on: February 27, 2012, 04:42 PM »
Yea your right as long as ya can hide them.
I use a 3" long #9 robertson head screw. It works great.
Once I gang the cabs together and add a end panel Im good.
Joe was quite a character. His site had a chat function, Him and I and a guy from Texas used to chat with each other.  He was very colorful when discussing things at the old break time. Thats where I met him (online)
I learned a lot from him.
Brice Burrell
Offline Offline
WWW
« Reply #20 on: February 27, 2012, 07:20 PM »
Brice,
Yeah, I know you're a pinhead, but I forgot Joe was from Staten Island. Doh! Big Grin
Ken Nagrod
Restricted
Offline Offline
« Reply #21 on: February 27, 2012, 07:27 PM »
That's it!  I'm sending Kreg's Roadshow to Pitzburg.
stairman
Offline Offline
« Reply #22 on: February 28, 2012, 11:46 AM »
Since I began using eCabinets about 4yrs. ago, I've been using BLIND DADO joinery on everything that comes off the CNC,  and since I started using FESTOOL, I now use BLIND DADO on everything else that doesn't come off the CNC...
I should add, that I tried on a couple prior occasions, and determined the joints were too time consuming to machine manually, but with Festool, that's no longer the case.
Blind Dado joints have a bit of a learning curve to them,  but once you find your "best way" to machine them,  they go pretty fast.
By the way, the only "Plywood Bits" I use are from Collins,  and they are not for dados,  rather for edge joining plywood.  http://www.collinstool.com/base.php?page=collins_ply_prep.htm
for conventional dados, the 2 pass sneek-up works best.
Kapex on a UG, TS75, OF1400 (x2) OF2000,,HL850,  Domino, RO90, RO125,  LS130, RAS115, MFT3, C12 Set, CXS Set, LR32 Set,  arsenal growing as fast as I can afford it!
Looking to buy: RO150EQ+ ; LR32 guide rails, 3000mm guide rail, parallel guide set   ;  another TS55 to replace the 1 I sold...   OF1010 and additional Festool Routers ;  RS2  ;    and a FESTOOL BS105 BELT SANDER SET
OK, let's face it, I'm always looking for any Festools / accessories.
JimB1
Offline Offline
« Reply #23 on: February 29, 2012, 09:07 AM »
Thanks for all the replies. I actually ordered the 23/32 Freud plywood bit, really good quality and sharp as all heck Smiley it's maybe 1/64 or less too small but as most of you have said I think two passes is the right way to go.
Just need to decide on a jig or technique. I like this one a lot...
just need to get a rail now. I was planning on getting one this weekend anyway so it's not a big deal to make that purchase.
-Jim
GreenGA
Offline Offline
JR
« Reply #24 on: February 29, 2012, 09:36 AM »
There are a number of jig videos on YouTube that show how to make a jig, using scrap, to get perfect dado's every time, no matter the thickness of the inserted material.  Some even use 1/2" bits to rout for 3/4" shelving to prove the point.
-Jim
Pages: [1]   Go Up
  Print
Jump to:
