Jesus Aleman
Offline
« on: January 17, 2009, 08:47 PM » |
Hi, I have been reading some thread from last Spring about the OF2200. It appears that a few people were going to review the product later in the year. Has anyone done any kind of review on this router?
Eiji Fuller
Offline
« Reply #1 on: January 17, 2009, 11:57 PM » |
There are some really good reviews linked on the consolidated list of festool links. It is a stickiew thread at the top of the Festool Tools and Accessories page here.
Jesus Aleman
Offline
« Reply #2 on: January 18, 2009, 12:12 AM » |
Thanks. There was only one review for the OF2200 that I could find and it was a magazine article. I was looking more for the user type review.
Chris Hughes
Offline
« Reply #3 on: January 18, 2009, 09:49 PM » |
What are you going to use it for? I bought one this summer because the price was right and I'm tooling up to do solid surface. At the regular retail price and its massive size, this router is not a casual purchase. I've used mine a few times and it is the workhorse it is supposed to be. I want to incorporate solid surface material into my furniture design so as far as dust control goes it kicks butt. I also bought the accessory kit for it and I would concider that must have for this router. C Hughes
« Last Edit: January 18, 2009, 09:57 PM by Chris Hughes »
nickao
OfflineMember Since: Feb 2008
« Reply #4 on: January 18, 2009, 10:05 PM » |
Hey Chris if you work with solid surface Eagle has some good solid surface bits that normally go for 110.00 for 20.00! Here is one: http://eagleamerica.com/solid-surface-ogee-bowl-bit/p/43910/Here is another. 88.00 for 10.00: http://eagleamerica.com/solid-surface-topmount-bowl-cutout-bit/p/43936/I have used these Porter Cable bits and I like them a lot! They had more but it looks like they may have sold them, sometimes Eagle hides the good stuff so poke around a little.
« Last Edit: January 18, 2009, 10:07 PM by nickao »
The one who says it can't be done should avoid interrupting the person doing it. (or designing / contemplating it)
Bill in seattle
Inactive Member
OfflineMember Since: Oct 2007
« Reply #5 on: January 18, 2009, 10:28 PM » |
These bit are a great deal if you have a use, but these bits are discontinued because the bevel mount bowls have been discontinued in the US. not a popular style here for many years and difficult for most S.S. shops to do at best. But if you are going to have to do repair work( arrrrghh) then the 10 degree bit is great for this with the proper collets to make repair plugs. The bowl bit is a great deal but the relief angle cut on these bit makes you do a lot more sanding to remove the bead line after you cut the bowl. Once again if you are doing a bowl removal and replacement ( a PIA job at best, and best left for the warranty specialist) then this would be a bit to have if you screwed up a bowl or had to replace a damaged one.
Bill in seattle
Inactive Member
« Reply #6 on: January 18, 2009, 11:03 PM » |
The of 2200 router is the beefiest router on the market today, Hands down. It does have a beefy price to go with it though. It is the most versatile for heavy duty operation and the quick change base plates are a dream come true for multiple operations.
The dust collection really rocks and gets the job done in some tough situations. Even running 1'' bullnose bits without the lower dust guard it still gets 95% of the crud throw off.
I dropped a brand new huge $375 custom router bit while taking the goo off. After it bounced off the concrete and took a big chunk of carbide off of one wing(Youuuch), I had no choice but to run the bit as there was no time to have another made or have it repaired. ( I do not recommend or advise anyone to run a damaged bit for safety's sake) but the 2200 had enough heft and so balanced that it absorbed the vibrations of the off balanced bit and was able to get the job done with out a hiccup and get the job out on time. I would not even considered this with any other router, but I said this things got beef, WTH. I did not having to make that proverbial phone call saying there is a problem and I'm going to be late. Therefore I was able to keep this demanding contractors schedule and not be backcharged.
For production and heavy duty long runs it can't be beat. I've seen many other H.D. routers burn up (literally, FLAME ON!!!!) and this router just purrs through these tasks effortlessly . The only drawbacks I have seen so far is how to mount it in a router table with easy hieght changes.
Otherwise this a more akin to a hand held shaper that can run large bits with ease and effortlessly.
A must have for anyone doing solid surface or running big bits.
Thats my Opinion so far, this is one seriously H.D. router in its own class.
Jesus Aleman
Offline
« Reply #7 on: January 18, 2009, 11:09 PM » |
Chris, certainly is not the cheapest tool out there. Woodworking is a hobby for me, but I have a few projects in the house that will require larger bits (doors and kitchen cabinets). I have narrowed down to the OF1400 or OF2200. I can get a used OF2200 (mint condition) which makes the purchase price a bit more attractive (although it is still a lot of dough). I only want one router that can be used primarily as hand held, but can work under a table in a pinch. I know there are other alternatives (brands) out there, but I'm pretty set on the Festool thingy due to space, dust and time constraints. The OF1400 will cover most of my needs, except for two of the larger projects that I would do the interior doors and the raised panels for the kitchen cabinet doors (>2" diameter bits). I would hate to have to buy an extra router (3 HP) to do the job and then have it collecting dust (I could sell it I guess). Plus buying another router will likely pay for the difference between the OF1400 and the used OF2200.
JGA.
nickao
« Reply #8 on: January 18, 2009, 11:20 PM » |
Why put an OF 2200 in a router table anyway? It is NOT a draw back at all. It is designed to be a stable large hand held router, not a table mounted router. What current does it pull? I imagine it pulls 15 amps, or it would pop the breaker. Many routers pull 15 amps meaning it is not more powerful than them, simple electronics. Now PC make industrial routers that are 240V and actually are more powerful than the regular consumer models and would run at 20 amps if it were in a 110V circuit, so really there are more powerful routers made, just not for hand held use and not for 110V systems. The benefit is that this router can run huge bits and be stable as a hand held, something no other 15 amp router can do. So the entire point of this monster router is to run huge bits in a hand held position, in a table it just becomes another 15 amp router. Any 15 amp router can swing a 3 or 4 inch bit IN A TABLE. Actually, my old Hitachi was measured at 17 amps and blew many 15 amp circuits years ago when they first came out, so they reduced the routers strength and the newer ones did not pop the 15 amp circuits very often. Now if someone says this Festool router runs at more than 15 amps and a 20 amp circuit is required than it would be a little more powerful than most routers in a table, but I have seen the thing run on a 15 amp circuit so that is not the case. So I do not care what the watts are or the calculations if the thing does not pop a 15 amp circuit, it is a 15 amp unit and pulls the same current as my 625 DeWalt. 15 amps is 15 amps no matter the efficiency of the unit. So do not waste this thing in a table it defeats the entire purpose of it. There are just as powerful routers made, just not any yet that can run HUGE bits hand held. Again a table is a waste for this router. That's why it is tough to put this router in a table, it never was designed nor intended for that. One heck of a gorgeous machine! I would not want to hide it any way! I would show it off!  Nickao
« Last Edit: January 18, 2009, 11:31 PM by nickao »
Chris Hughes
Offline
« Reply #9 on: January 18, 2009, 11:31 PM » |
I have a couple of PC 3 1/4 hpthat I use. One of these routers is dedicated to a lift under the table and the other I used primarily for the heavy lifting (raised panels, rail and style). At about $300.00 a piece they are about 1/3 the price of the of2200. I would not switch PC's out at that price. The of1400 IMHO is a great router for general use due to its array of accessories, power to weight and its dust collection. In other words "its Festoolness". The 2200 is maybe a little too substantial for general use. It is a great router however and if you can justify the expense then jump on it, I did. C Hughes
nickao
« Reply #10 on: January 18, 2009, 11:33 PM » |
I say if you need a hand held router that can run the biggest bits, the OF2200 is for you! I can see it come in handy for stair making, big railings, some exterior deck and gazebo work and some other things like solid surface, etc. I would love to make a railing cap in one pass instead of three, if they designed the bit I needed to do it, like some shaper cutters are designed to!
« Last Edit: January 18, 2009, 11:36 PM by nickao »
Jesus Aleman
Offline
« Reply #11 on: January 18, 2009, 11:49 PM » |
Thanks guys. I primarily want it for hand held use, but with the ability to go under a table (briefly) if the need arises. I certainly see the advantages of running some larger bits hand held, but I'm not sure I want to try routing a raised panel hand held. Chris, based on your experience with the router can this be done? I would think this would be safer and easier on a table.
Chris Hughes
Offline
« Reply #12 on: January 19, 2009, 12:04 AM » |
I have never routed a panel from the top and don't think I ever would. It is so easy to mount a router under a table and by the way I see it conciderably safer. Not to mention tenon on rail and style. C Hughes
nickao
« Reply #13 on: January 19, 2009, 12:04 AM » |
A raised panel should be done in a table for sure, even if the OF 2200 could do it, why? The way you need to switch in and out templates for each door a table is made to order for that operation.
Steve-CO
Online
« Reply #14 on: January 19, 2009, 01:00 AM » |
Safety is key, anytime you're spinning a bit the size needed for a raised panel, use a table. Most catalogs will guide you as to which bits are designed for table use only. If it doesn't "feel" right don't do it.
nickao
« Reply #15 on: January 19, 2009, 01:13 AM » |
Well I have cut a panel from the top on a shaper table many times. The cutter itself actually cuts the panel face up and it is wild seeing the shaper cut that raised panel as you go. Still that is in a table not free hand.
richard.selwyn
Offline
Normandy, France
« Reply #16 on: January 19, 2009, 09:12 AM » |
The OF 2200 IS designed to run in a router table - as are the other two Festool routers - but it's the Festool router table insert (I know everyone will say its NAINA...) I only have the old model table, but I believe the new one can be height adjusted from above. They are expensive though and maybe Festool feel there is too much router table competition in the US. I don't know how the OF2200 attaches, but my 1010 Festool router takes a couple of minutes to fit to the table. If someone could get a drawing of the Festool setup it should be easy to see how. Having said that, those of you who know more than I do on this thread are saying it's a waste to put it in a table. I want to get one to do just that as my small Festool router is a bit TOO small to be in a table in my view. I've "ogled" the 2200, but as I'm in the process of spending a fortune on a horizontal slot mortiser (a sort of giant horizontal router in a way?) it will have to wait.
Tom Bellemare
Festool Dealer
Offline
« Reply #18 on: January 19, 2009, 11:06 AM » |
The OF 2200 draws 2200 watts maximum. That's about 19 amps. Due to the MMC electronics with the soft start, it is highly unlikely that you will ever do anything to cause that much current draw unless you have done something where you would want it to stop anyway. The OF 1400 is a 1400 watt machine, the OF 1010 is 1010 watts. Being the latest plunge router introduction by Festool, the OF 2200 has all of the latest and greatest Festool features. Just like the OF 1400 improved on the features of the OF 1010, the OF 2200 improved on them both. I agree, Nick. It is like a hand-held shaper. It can also be a mounted shaper, though. It is a good idea to get the accessory kit, either the Metric Accessory Kit for OF 2200 or the Imperial Accessory Kit for OF 2200. Tom
Jesus Aleman
Offline
« Reply #19 on: January 19, 2009, 11:19 AM » |
Does anyone know if the version 2 of the OF1400 is in the making and when it will be released? It would be nice to have the OF2200 features in the OF1400 package.
Dave Ronyak
OfflineMember Since: Jan 2007
Flyin' from NE Ohio
« Reply #20 on: January 19, 2009, 12:49 PM » |
Jesus,
Almost all of the people (myself included) who attended the Festool Fantasy Camp in Henderson NV in April 2008 asked that question when the OF 2200 was introduced to us. We did not get any answers then, but the Festool personnel certainly listened to our remarks. I haven't heard any "noise" about a revised OF 1400. Maybe others have.
Personally, I'd be much more excited if Festool would update the 1010 router along the 2200 design concepts, including addition of 1/2 shank capability. Many times I find myself having to use my OF 1400 because I have a relatively small 1/2 inch shank bit that fits the job, and the greater weight and height of the OF 1400 makes it difficult to balance and control.
Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
Notorious T.O.D.
Offline
« Reply #21 on: January 19, 2009, 01:07 PM » |
Just get a shaper for doing doors and raised panels....easier, faster, safer and smarter.
And if you get a feeder you can do climb cutting which is the ultimate...
One thing I never liked about using big bits in big routers was the bits slipping out of the collets. Now I know that the collets have gotten a lot better in the last 20 years...my big Elu was the first big router that didn't have trouble with bits coming loose...I still like the cutters locked down with a big old nut on a 3/4 or 1 1/4" solid spindle....not a 1/2" shaft in a collet.
Best, Todd
PeterK
Offline
« Reply #22 on: January 19, 2009, 06:52 PM » |
I have not seen or used the 2200 but am sure it is awesome - and I crave one!! From what you said, if it was me I would purchase the 1400 and also something like the PC 7518 for router table use. This would approximately equal the price of a 2200 and give you 2 setups with more capabilities. I can't imagine trying to work with only one router. The time benefits of having multiple routers even in hobby use is tremendous. I have used my 7518 handheld with huge bits while it was still hanging in my router lift. The additional mass of the lift allowed very comfortable usage with a roundover bit that was about 3 1/4" diameter. Pete
nickao
« Reply #23 on: January 19, 2009, 06:54 PM » |
Well I disagree, becasue there is an adapter or special insert needed means they adapted it. It was designed from the ground up to work free hand. There are loads of things that could have and would have been designed into the model if it were designed for a table. It is clearly designed to be a hand held unit that takes big bits like no other router can. Using it in a table is an after thought and a WASTE of money and time. Lastly, if it were DESIGNED for a table it would have been marketed as a table router, like the big Milwaukee unit or Triton are. I do not think I have ever seen an ad mentioning it for a table(okay find one now guys), let alone marketing it as a unit for a table. Why would they design it for something and then not show ads for that use? In short the ads say HUGE bits in a hand held unit. I think this is semantics here, just because it can be used in a table does not mean it was designed for a table.
« Last Edit: January 19, 2009, 07:03 PM by nickao »
Jesus Aleman
Offline
« Reply #24 on: January 19, 2009, 07:55 PM » |
Hey guys, let's get back to the original question. Has anyone used the OF2200 and would be willing to share their thoughts with us. I appreciate everyone's opinions and experience. I realize that a shaper, multiple routers, other routers, etc offer greater flexibility, but I'm pretty set on my ways and have very little space. I want one hand held router that can be mounted under a table in rare occasions when I want to spin panel and door bits. This is a hobby for me. I don't need a production machine or setup, and I only like buying tools that will be used frequently. I don't think I will be using a router table and a hand held frequently. Hence, I only need one optimized for hand held use, but with the flexibility to sit under a table. After many weeks of research I'm looking at the OF2200 or OF1400. I will rephrase my question. Has anyone done used door or cabinet panel bits (1 1/2"-2" range) with the OF-1400 and done this safely, perhaps at the expense of additional passes to get the profile?
BTW, both the OF1400 and OF2200 can be used under a table. Festool has a router table attachment currently not available in NA. I don't believe that this qualifies these router to be designed for table use, but capable of it with optimized features for hand held us.
Cheers,
JGA.
Forrest Anderson
Global Moderator
Offline
« Reply #25 on: January 19, 2009, 07:58 PM » |
Well, since you asked, here is the 8-page brochure for the TF2200 and TF1400 table routers. The TF2200 comes with an above-the-table crank for adjusting the height, routing guard and dual dust ports, whilst optional extras include a sliding table and extension table. In addition to its own brochure, the TF2200 also gets a whole page in the 16-page OF2200 brochure:  Also see the page devoted to the TF2200 at http://www.festool.co.uk/artikel/artikel_weiterleiten.cfm?id=854Forrest
« Last Edit: January 19, 2009, 08:01 PM by Forrest Anderson »
Chris Hughes
Offline
« Reply #26 on: January 19, 2009, 08:30 PM » |
How the much is that table?!? LOve it, get me two please. C Hughes
nickao
« Reply #27 on: January 19, 2009, 08:32 PM » |
I knew you would do that Forrest you are the man  Cheater. I still say it designed for above table work, I'll stick to that. I bet my Milwaukee or PC or are just as good in the table. Strike that, they are better for sure if no other reason becasue of cost. I would get an OF and you would never see it in my table, ever. What a waste.
« Last Edit: January 19, 2009, 08:35 PM by nickao »
Chris Hughes
Offline
« Reply #28 on: January 19, 2009, 08:47 PM » |
I would agree with that Nick, but I'm looking at the table. Very nice design. I have a Jesum Master Lift and I love the vertical control it allows and the top placement of the adjuster tool. However, this set-up is mounted under my delta unisaw and not a great design for stick and cope applications. I would not remove my current lift, I would use a better station for a more difficult opperation. The big plus is that it looks cool. I might have a job in Scottland this summer, so I'll be putting my grubby little hands if all goes well. C Hughes
nickao
« Reply #29 on: January 19, 2009, 08:53 PM » |
Looks WAY cool, no doubt.
