eruzich
Offline
« on: December 13, 2007, 10:10 PM » |
I am going to make a router table for my OF 1400 EQ. Has anybody here done this? I have read many post that suggested to just by a different router for a table and I agree there are cons to having a great router stuck in a table. However I have only one router and do not want to by another one for the occasional use. The problem I see is that the base does not have through holes to mount to a plate and the threaded holes appear to weak for mounting. If any body has used this router in a table, any advice would be appreciated. Thanks
eruzich
Offline
« Reply #2 on: December 14, 2007, 01:17 AM » |
Thanks my Aussie friend, in the states we only dream about the entire festool line. I am really looking for a cheap solution. It appears I can make my own table insert and attach the router using the 5 small screw holes used for the base plate. Anyone know the screw thread or have any other ideas? Thanks
Eli
Offline
A Yankee in Kangaroo Court
« Reply #3 on: December 14, 2007, 03:35 AM » |
M6? This just came up week before last when we were talking about new sub-bases to use w/ the guide rail. Dubya?
Do nothing, stay ahead.
eruzich
Offline
« Reply #4 on: December 14, 2007, 03:52 AM » |
Thanks for the screw thead. Lucky for all of us Dubya will soon be gone.
Eli
Offline
« Reply #5 on: December 14, 2007, 05:11 AM » |
No I meant, I think they are M6, hence the question mark. DavidDubya was a principal poster on the thread in question.
But yeah, it'll be great for you guys to get rid of The Shrub (little Bushie) as well. But he's already FUBAR'ed so many things, it'll take forever to fix.
Jim McFarland
Offline
MFTs provide excellent shade
« Reply #6 on: December 14, 2007, 04:08 PM » |
On my OF1400 (US -- assume others are same base and threads): M6 X 1.00 threads are highlighted by Blue arrows M4 X 0.70 threads are highlighted by Yellow arrows
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts." - Bertrand Russell
mntbighker
Offline
Needs head examined for festoolian addiction <<---
« Reply #7 on: December 14, 2007, 07:46 PM » |
darn, serious drool factor on all those goodies us yanks can't buy
Festoolian since November 2007
TS55EQ saw - OF1400EQ router - OF2000 router - HL 850 planer - MFT 1080 - DF 500Q - RO 150 sander - RO 90 sander - CT 22 dust extractor - Kapex - CXS drill
Dixon Peer
Offline
« Reply #8 on: December 14, 2007, 10:28 PM » |
Buy another router, hang it under a flat surface and use your expensive plunge router from Festo to do work above the table. Then you'll have a dedicated really small "shaper" that you don't have to take apart when you need a router for other applications. Believe me, if you're doing any amount of woodworking other than once a month hobbyist stuff, this is the way to go.
eruzich
Offline
« Reply #9 on: December 14, 2007, 11:28 PM » |
I picked up some M4's on my way home today and I will post some pics when the insert is done. FYI I will eventally by a dedicated router there just is not enough cash coming in to justify another router at this point. Thanks All
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #10 on: December 15, 2007, 03:28 PM » |
I'd use the M6 screw holes in the base of the 1400 if I was wanting to mount the router onto another base. There is a lot more metal in the root of the M6 screw threads than in the M4 threads. And you won't have to remove and reinstall the non-scratch Festool base so switch over can be quicker. I also strongly agree with the others who recommend buying another router to mount in a table. Freud, PC, Triton and others make 12 - 13 Amp routers that can be purchased for half or less than the cost of the 1400, and they work well inverted in a table.
Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
