Author Topic: Router - OF 2200 vs OF 1400?  (Read 3611 times)
Offline Jimxavier
« on: June 13, 2018, 01:33 PM »
It will be my only router for the time being.
I may eventually want to get a nice router table for it with an incra fence. I likely won’t get the Festool router table.
It will be used for routing groves, dove tail joinery, and routing the designs in picture frames. Those are some of the sample tasks.
I don’t have a table saw. I have a TS75 and MFT table.
What do you guys recommend?
I was leaning towards the OF 1400, but thought I’d check in here. I’ve heard great things about both.
Offline ben_r_
Re: Router - OF 2200 vs OF 1400?
« Reply #1 on: June 13, 2018, 02:30 PM »
The OF 1400 for sure for those tasks. The OF 2200 is a heavy beast and probably overkill for those tasks listed.
Offline Birdhunter
« Reply #2 on: June 13, 2018, 02:33 PM »
I have the 3 Festool routers, 1010, 1400, and 2200. The 1400 gets 90% of the usage.
Birdhunter
Offline Jimxavier
« Reply #3 on: June 13, 2018, 03:16 PM »
@Birdhunter can you describe an application the OF 1400 cannot be used for? Does it do ok under a table?
Offline Brian Livingstone
« Reply #4 on: June 13, 2018, 05:08 PM »
I sold my 1400 and bought a 2200.
The 1400 is great, the 2200 is amazing.
I haven’t regretted it.  The 2200 like the TS75 is just that much better.  It is a big machine but it is easy to handle.
Brian
Kapex, TS75, MFT, OF1010, OF2200, DTS400 REQ, Parallel guide rails, 800, 1080, 1400, 1900, 3000 guide rail, Domino 500, CT36, CT Midi, , RS2E, RO150, Boom Arm, Crown stops, 6 drawer Sortainer, Carvex, Syslite II, Festool safety glasses must start to wear.
Offline ben_r_
« Reply #5 on: June 13, 2018, 05:49 PM »
And like a lot of people feel the TS 75 is too bulky for everyday use and overkill for many tasks, many feel the same about the OF 2200. Just something to consider. This is why so many of us end up with multiple routers!
Offline Sparktrician
« Reply #6 on: June 13, 2018, 05:52 PM »
For the tasks you mention, the OF 1010 might be the better choice.  It's certainly the best choice for doing dovetails using the Leigh 18" SuperJig in my shop.  It's light enough that it doesn't deflect the guide plates.
- Willy -
Offline Birdhunter
« Reply #7 on: June 13, 2018, 07:57 PM »
You asked what I would not use the 1400 for. I use the 2200 for hogging out pockets, profiling really hard woods like Ipe, and taking deep cuts where it wouldn’t work to take multiple passes. These are tasks I would not ask my 1400 to do. The 2200 is a real beast.
The 1010 is a really fun light duty router. It can’t take the 1/2” shank bits I prefer.
The 1400 is right in the middle between the 1400 and 2200.
Birdhunter
Offline epicxt
« Reply #8 on: June 13, 2018, 08:04 PM »
You can spin a much larger bit (i.e. panel-raising or large lock-miter bit) in the 2200 and the dust collection system is far superior to the 1400. However, if you won't be using the router in a table, these likely aren't important factors for you. I would lean toward the 1400 or 1010 with an eye on a dedicated motor in a lift down the road.
n = number of Festools I've got.  (n + 1) = Festools I want
Offline rst
« Reply #9 on: June 13, 2018, 08:11 PM »
I have 13 routers including two 2200s, and the 1010.  I use the 1400 for 90% of my work.
Offline Naildrivingman
« Reply #10 on: June 13, 2018, 09:17 PM »
I don’t own the 2200, but I do have a table and I chose to invest in a high quality lift and use a PC 7518 as the power head. I have no regrets. I don’t have anything against the 2200, but it does seem like a sizable investment to hang under a table. Plus, removing the router from the table may be quite an undertaking. You may want to have a dedicated motor for the table. Regardless of what motor you choose, I would strongly recommend a high quality lift.
Dance with who brung ya...
Offline Gerald_D
« Reply #11 on: June 13, 2018, 10:13 PM »
Based on the tasks you mentioned, if it were me I would buy the OF1400 first and add to your stock later.  Like @rst, I have a lot of routers (PCs from my pre-Festool days and 6 Festool) and use them all.  Some folks here believe you cannot have too many clamps- I feel that way about routers as I leave some setup and dedicated to certain tasks.  However, as others have mentioned, the two OF1400s I have get the majority of the work.
I have 2 7818 PC motors in Jessem and WP PVL lifts and I also have a CMS with 1400- I don't know if it's because the PCs are older but I get more vibration from them as compared to the Festool setup.  If others have both setups, please chime in if you have the same experience or not.  Otherwise, I've been pleased with both setups.  I have a 2200 but only use for larger bits and haven't used in the CMS- it is heavy but once you have it on the work it is a joy to use.  I really should use it more often.
Good luck with your purchase.
Regards,
Gerald
Gerald
I have Festools- Big and Small and a few other tools
Offline jtwood
« Reply #12 on: June 13, 2018, 10:34 PM »
I have the 1400 and like it very much.  It is very versatile and will handle most jobs, like the ones you are talking about doing.
One thing you said, that you might want to get a router table for whichever you get, and probably won't get the Festool router table.  One of the companies that makes router tables now has a router lift that fits the 1400.  I can't remember which (maybe someone else on the forum does?) but I doubt you would ever find an aftermarket lift for the 2200.  If mounting the router in a table is important to you, I would consider the 1400
Steve
I found the link to the JessEm router lift and plate that fits the O)F1400 and OF1010, as well as others:
http://www.jessemdirect.com/product_p/02322.htm
« Last Edit: June 13, 2018, 10:40 PM by jtwood »
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #13 on: June 14, 2018, 12:00 AM »
Jim,
Honestly, I think that the 1400 would be the best bet for the tasks you are doing.
But, if you want to get a 2200, I have one with all the accessories that has had very little use.
I'm thinking about selling it for 50% of current Festool catalog price.  It is in great shape, but
I need to downsize.
PM me if you are interested.
Offline grbmds
« Reply #14 on: June 14, 2018, 12:18 AM »
The OF1400 is possibly the best router for all-around use, but would seem to be kind of a waste for mounting in a non-festoon table. While I don't own the OF2200, I have used one and find that it is very large for general use as a plunge router. For mounting under a table, especially if it's an Incra table/fence/lift, I'm not sure that the Festool routers can be mounted with available Incra lifts. I would guess you could mount the either of those with a homemade or purchased plate.
I own a PC7518 router installed in an Incra lift in an Incra table with an Incra fence. It's an extremely accurate and precise setup with great dust collection.
I also find that the OF 1400 router is one of the best routers on the market as a hand-held plunge router and maybe has the best dust collection available.
Randy
Offline Birdhunter
« Reply #15 on: June 14, 2018, 05:29 AM »
I think it’s a real misuse of a 1400 router to hang it under a table. There are some nice router lifts that work very well with the Porter Cable router motor. For me, having all the positioning controls above or on the table beat having to fiddle with controls under the table.
Birdhunter
Offline Reiska
  • Hackers build things, Crackers break them.
« Reply #16 on: June 14, 2018, 06:14 AM »
I bought the OF1400 and the CMS router table package and I must say that while all parts are high quality as Festools is I find myself way too lazy to move the router between table mode and handheld mode. Most of the time I find myself coming up with any weird jiggy solution to do table operations handheld just to avoid fiddling with the CMS conversion attachments and using the less than stellar Festool CMS fence for the router table.
Since I got the Incra LS Superfence system on my MTF + VL I have stopped using the CMS-GE entirely. (albeit I mostly have my TS55 in the CMS-module permanently in the VL and only occasionally do routing when I can't get away with handheld routing.)
The good news is that the 1400 does about everything and I believe that the OF2200 is actually not supported for most dovetail jigs for its heft and base size. What is the most enticing feature to me on the 2200 would be its dust collection system as that's far superior to the more traditional dust hose placement of the 1400 and 1010.
If I could do this again I would get one of the better aftermarket router lifts and a 2kW+ router motor to permanently have in a table and then pimp it out with digital readouts, motorized lifts and the Incra fence system and then get the 1010 for handheld stuff like the LR32 work (1400 works for this as well, 2200 not).
The above is assuming you have a permanent workshop space available. I don't, so I'm stuck with movable equipment until the kids move out of house and I can re-purpose one of their rooms as a shop space.
The sky's the limit in my workshop, literally. [big grin]
Offline nvalinski
« Reply #17 on: June 14, 2018, 08:13 AM »
If your grooves are generally not that big, I'm going to echo @Sparktrician in suggesting the 1010. I own the 1010 and 1400, and love using the 1010 in my dovetail jig and for small grooves, edging details, etc. The 1400 comes out for template work. I can't say I've actually used it on my dovetail jig, but I think it would be a bit too heavy for the task. Take a look at any of the tasks you do and just check if there are any that would actually need a 1/2" bit.
« Reply #18 on: June 14, 2018, 08:28 AM »
Quite true, but it CAN take the 8mm shank bits that are commonly used with the Leigh dovetail jigs.
- Willy -
Offline TXFIVEO
« Reply #19 on: June 14, 2018, 05:47 PM »
I use the 1400 for all my handheld stuff and for the router table I have the PC7518...total beast mode there.
Offline JimH2
« Reply #20 on: June 14, 2018, 06:18 PM »
As an only router the 2200 is not what would ever be useful for you. I recommend buying a Bosch or Dewalt in the $150 range to what you want to do. The 1010 is too restrictive in terms of the bits you can fit it plus it cannot take 1/2" bits. The 1400 and the Bosch or Dewalt can take them. If a bit has a 1/2" equivalent then buy that versus the 1/4".
Offline Motor
  • Owner of Finishing Touch Carpentry
« Reply #21 on: June 20, 2018, 09:45 PM »
I own a 2200 and a 1010. The 2200 is an amazing router and has incredible power. I use it for routing stair stringers and other heavy work. I recently used it to cut a 1/2"x2" deep groove with a 1/2" bit in solid maple. It handled that task flawlessly. I would say it's a bit big for cutting designs in picture frames but I don't know exactly what you are doing. A 2200 in a router table would be an amazing machine - much like a commercial shaper.
Offline jeep jake
« Reply #22 on: June 26, 2018, 08:34 PM »
I own the 2200 and the 1010 there both great. I never really liked the 1400. Seamed to big for my likings for small tasks, and couldn’t accommodate some of my larger bits that I use from time to time.
Offline grbmds
« Reply #23 on: June 27, 2018, 02:43 PM »
The OF1400 is the best all-around router in the Festool line and has the power to a lot more beyond basics. Buying a much less expensive plunge router like a Dewalt, Bosch, Triton, or Milwaukee is a great idea if you're going to get another for use with an Incra table later except for the fact that the Festool routers excel at dust collection, can be used on Festool tracks on the MFT, and allow centering of the bit via marks on the base. Just those 3 features alone make the OF1400 worth it to me.
As for under a non-Festool table, a Festool router isn't the best choice in my opinion. An Incra lift with the Incra positioner fence, in a table is the most accurate around. Add a PC7518 motor or another similar brand motor for less money than the Festool routers. It's best to dedicate a motor to the table if you can. It's just needless messing around mounting and unmounting that I got tired of.
Randy
Offline yetihunter
« Reply #24 on: June 27, 2018, 03:12 PM »
If you're going the Incra/Jessem/Woodpeckers route (pun intended), just plan to purchase one of the myriad of lower priced Mexican and Chinese made big brand routers for that.
In the meantime, I own a 1010, 1400 and 2200 and I use the 1400 for 90% of tasks.   [big grin]
No, not really, but most, nonetheless.
However, if you're doing picture frames, the 1010 would be sweet for that.
Offline ben_r_
« Reply #25 on: June 28, 2018, 01:34 PM »
Exactly! The Porter Cable 7518 is the tried and true router motor for a dedicated router table setup. Especially with the Incra router lift and the magnetic CleanSweep inserts! Absolutely no reason to waste money on dedicating a Festool router for a table setup. Save the Festools for handheld operations.
Offline rst
« Reply #26 on: June 28, 2018, 08:37 PM »
The PC 7518 is definitely a good choice for a table router.  I've been using one in the table I made for better than 20 years.  I have the original router table lift, a Bench Dog.  This is an beast as it is all cast iron and brass and was marketed for light industrial use.  I especially like the iron table as I can use Magsitch 400 and 600 magnets as my tension fences.  I've really been tempted to buy their cast iron table but so far have been able to resist.  I also used another PC with an over size base for pattern routing.  That being said I now have two 2200s, a 1400, 1010, and 700...the Festools are sooo much smoother than the seven PCs and Boschs that I have and the dust collection is amazing.
