Author Topic: Second Festool Drill  (Read 4329 times)
Offline Jmacpherson
« on: November 09, 2017, 07:46 AM »
I'm looking for a drill that falls between the cxs and pdc within the festool stable.
I know there are other options in other brands, I own Makita 18v tools. I am even on the fence about this myself but that is a separate discussion I feel.
Which leaves the C18 or T18. When I originally bought my PDC I demo'd all 3x and wasn't interested in the C and found the weight difference between the T and PDC negligible and went the PDC route.
Cxs is fun to use but I do find that I still tend to use my index finger on the trigger instead of my middle finger like it is designed to be used.
So something beefier than the cxs but doesn't require the grunt of the PDC or can be used in conjunction with the PDC etc.
That being said, in terms of the C handle if you are not using it as intended in terms of your middle finger on the trigger are you getting the full benefits from the design?
How easy is it retrain your brain as it were to adjust to the C handle?
If I can't adjust then would the T make more sense?
Then again since I preferred the PDC over both C & T originally would a DRC make more sense then as drill #2?
Offline RobBob
Re: Second Festool Drill
« Reply #1 on: November 09, 2017, 07:51 AM »
Makita subcompact set or just the drill with the Centrotec adapter.
Makita 18v drill
Centrotec keyless chuck adapter
Offline mrB
« Reply #2 on: November 09, 2017, 10:09 AM »
T-18 compact with the small batteries feels in a different weight class to the PDC with the large 4.2 or 5.2ah batteries . . . The T-18 with the compact 3.0ah batteries is 200g lighter in body and 100g lighter in battery than the PDC as well as being a slimmer and smaller machine.
The C-Drills really need to be held in "pistol grip" with the middle finger (CXS) or ring finger (C18) as the trigger finger. Or you just have an awkward feeling drill . . . And loving the CXS does not mean you will love the much bigger and weightier ergonomics of the C18!
Offline grobkuschelig
« Reply #3 on: November 09, 2017, 02:51 PM »
Do you have some of the smaller 3.0 ah batteries?
Maybe visit your festool dealer and check the combination of PDC+3.0ah. Might already make a difference.
I am a C-Type and love my C18 in conjunction with the CXS and PDC. But I also know that I do not need 3 drills. But I have them now. So no reason to go back. ;)
Remind yourself to use your index finger to point at the screw/place to drill. This makes a big difference for me, since my hand is calmer and I have more control than with a T handle.
I would have gotten a CDC, if they had one. Eying the BHC18, but that is a different story... ;)
Offline Jmacpherson
« Reply #4 on: November 09, 2017, 03:28 PM »
I bought 1x 3ah AS battery when I bought the BHC basic kit recently.
It does make the PDC a little lighter but you can still feel its gearbox up there :)
I assume with enough practice I can train my brain/hand to adjust to a C-handle but as @mrB states its not a given I'm going to like it which worries me. As you say the 3ah should be very noticeable on the smaller drills.
After some additional research I'm leaning towards the T.
@grobkuschelig - Off-topic, I got the bhc18 because 1) the new makita which is similar isn't coming to my country and 2) I have a rsi in my wrist  and from research others with similar issues have recommended it. It is a joy to use. Can feel the weight difference on the machine between 3ah and 5.2ah.
Offline mrB
« Reply #5 on: November 09, 2017, 04:51 PM »
As I've said before here, I love the CXS but find with the C18 that there is too much weight sitting in front of your grip and it makes the drill feel heavy, and the drill bit end wants to drop down all the time. . On a T style drill the weight is evenly balanced directly over the hand grip. .
It's not a matter of strength but comfort in prolonged use. .
Offline Birdhunter
« Reply #6 on: November 09, 2017, 04:52 PM »
I switch often between C and T drills, but prefer T.
I’ve got way too many Festool drills. Favorites are TSX and T18. The T18 is a great drill.
Birdhunter
Offline epicxt
« Reply #7 on: November 09, 2017, 06:20 PM »
One consideration is the bit storage is much more secure on the C series.
n = number of Festools I've got.  (n + 1) = Festools I want
Offline Mismarked
« Reply #8 on: November 09, 2017, 06:37 PM »
How does everyone except me know which finger to use on the C drill and the CXS?
Offline Birdhunter
« Reply #9 on: November 09, 2017, 06:44 PM »
Gee. Never thought about it.
Birdhunter
Offline mrB
« Reply #10 on: November 09, 2017, 07:21 PM »
Ha!  [big grin]
Obviously I think anyone can use as suits them, but if you try using the 'correct' finger for 5mins+,  you'll probably start to feel it was obviously designed to be used like that. . .
Index Finger - CXS
Ring Finger - C18
Offline jobsworth
  • Burger Babe Says: I Even Buy Green Bananas
« Reply #11 on: November 09, 2017, 08:20 PM »
I have a C12 and C 18 love them both.
Loving the Calif sun....
Offline Jmacpherson
« Reply #12 on: November 10, 2017, 08:12 AM »
It seems the scores are tied  [big grin]
I spoke to my dealer earlier, they don't have stock of the T or C but their supplier does.
Will do some more research over the weekend and make a final call on Monday.
Thanks for all the input and advice.
Offline SRSemenza
« Reply #13 on: November 10, 2017, 10:38 AM »
I use which ever finger works best for the drilling position. Sometimes even with hand position  sideways/reversed and pressing the trigger with my thumb.
Overall I like the C. I like having my hand more in line with the bit when driving screws. I like that I can hang the drill on a finger or my wrist or on any protruding object (like a clamp bar) because the handle is a loop. I do get that it can be a bit front heavy with the jacobs chuck but I use the Centrotec most of the time and I don't have any front heavy issues with that.
There is a lot of personal preference on this.
« Last Edit: November 10, 2017, 10:41 AM by SRSemenza »
« Reply #14 on: November 10, 2017, 02:40 PM »
One thing I always forget until I need it, is the advantage of the C-Series when climbing a ladder. You can just slip it on your hand and still have some sort of „grip“ on the ladder with both hands.
A huge safety plus for me. YMMV...
Offline ScotF
« Reply #15 on: November 10, 2017, 07:43 PM »
Just get one of each and have the best of all worlds... [tongue]
Offline Birdhunter
« Reply #16 on: November 11, 2017, 05:11 AM »
ScotF had the best input. Buy them all!
I tumbled for CSX, TSX, C12, TI5, and T18. The two SX drills get the most use, then the T18. The C12 rarely gets used. The CSX was my first Festool purchase.
Birdhunter
Offline Jmacpherson
« Reply #17 on: November 11, 2017, 04:55 PM »
 [laughing] was about to ask if anyone owns or uses both and then I read ScotF's post.
The thought crossed my mind about both of them.
Offline yetihunter
« Reply #18 on: November 15, 2017, 11:59 PM »
I love the T18.   And I have a PDC (that I love) and gave away my CXS (that I love).
Power wise, it's been eclipsed by other brands... but... I don't like other brands's drills.   I really dislike the C18.
Offline yetihunter
« Reply #19 on: November 16, 2017, 12:00 AM »
I almost forgot:  get the right angle and offset chuck....and get ball detent bits for the offset chuck.
Offline Jmacpherson
« Reply #20 on: November 17, 2017, 02:46 AM »
Probably going the basic route for now instead of set version since I already have the angle adapter for the PDC and CXS.
The offset chuck is the one though that is "missing" from the arsenal.
Festool rep dropped off demo units of the T18 and C18 at my local dealer I always use so I can re-demo both units again before I make my final decision.
Hopefully that can help me make a decision between the two or maybe it can't  [big grin]
Offline yetihunter
« Reply #21 on: November 17, 2017, 07:47 AM »
Fair enough: in the most cases that I've used the eccentric chuck, I'd rather have still had the CXS to use, instead.
In that ultra rare occassion that you're swapping out chucks at a rapid pace, however, the fitting for the T18/C18 (and 15 and 12..and earlier models) allows for ridiculously quick attachment/removal/adjustment.
« Reply #22 on: November 19, 2017, 06:52 AM »
I couldn't really decide between the C or T18. But, I think I still prefer the C version. I have both and use the T18 more - when they are next to each other and you pick both up there is no question that for my hands the T has a nicer grip. Also when the drill chuck is on it is better balanced.
However, the C18 with the Centrotec chuck (which is 90% of my use, with drill bits and bits) is great in handling and has that bit/scew garage up front that has helped out many times. In actual use I prefer the C18. If they had made the C18 with the same shape grip as the T18 that would be even more awesome but as soon as I start using the C18 I "forget" about the grip and it works tremendously well. For those pesky moments where I need the drill chuck I just suck it up and get it done - it is not that often.
I did have the DRC which was "ok" but in reality not that strong on the more useful speed gears - and getting it in third gear was an exercise in futility... It has been replaced by a Mafell A18m which takes the Centrotec chuck and does all my outdoor work with ease. Grip is a little to thick for my taste so I still use Festool drills for indoor projects.
If I could just have ONE drill the Mafell A18m would be the very best and sensible choice for me. But, I think that if I was in that situation I would still go with the C18 - despite the quirks. If Festool makes good on that Impact next year I think the pairing of a C18 and an Impact will be the bees knees for me. (With the CXS of course...)
Next indoor build (starting tomorrod) is a little more demanding with larger dimensions for studs etc so the Mafell will be the go-to drill for the whole project with the CXS as a sidekick for the gentle stuff. I would normally use the T18/C18 and I am most tempted to actually bring the C18 as there will be a lot of finicky screwdriving involving the right angle chuck and I have one for the Mafell but the odd chucks are Festools forte.
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
Offline Jmacpherson
« Reply #23 on: November 22, 2017, 04:37 AM »
Finally made the time to get to my dealer and play with the C18 and T18 again.
Tried with the 5.2ah and 3.ah AS battery.
My experience and opinion...
With or without a Jacobs chuck the C18 is not a CXS as many have said. Now I get it.
Without the Jacobs, the C18 is a lot nicer to handle and I can see how it has been designed around centrotec/kitchen fitting/cabinet making?
If you hold the C18 in the wrong manner it just feels off and weird. I tried the correct way and it was more comfortable to a certain extent but my brain said NO.
Secondly I found that holding it correctly the weight of the drill is absorbed by the bottom/outside of my wrist which is where my RSI is and I could feel the pressure/irritation so C18 would not work for me.
The 3.0ah batter made the biggest difference on the C18, I could feel the weight change the most.
The T18 felt better in my hand in terms of balance and the weight being more evenly distributed over my hand and wrist etc.
I think if I recall correctly it is why I went for the PDC originally over the T.
The 3.0 battery  makes a difference on the T18 but I didn't notice it as much as I did on the C18.
I ordered the T18 Basic along with the #493648 centrotec brad point set. I have the short stubby set. Figured I'm committed now so might as well commit to centrotec too while I am it.
I will get the Off Centre chuck at a later date.
« Reply #24 on: November 25, 2017, 03:07 PM »
Always good with an informed decision followed by some "hands-on".
I think you will be pleased with your choice - now you know you won't be thinking "should I have gotten the C18 instead?".
Neither drill is perfect for me so I kind of like both. I agree with your assesment of the drill with and without chucks and since I seldom use jacobs/drill chucks I have a preference for the C18 - which is gone the instant the drill chuck comes on. I have a spare 10mm CXS chuck I use for the C18 as well, it helps out a little but can't handle hole saws so both chucks are in the SYS.
Offline Jmacpherson
« Reply #25 on: November 25, 2017, 04:01 PM »
Collected the T18 yesterday and used it today for the first time. Feels even better in actual use than in the demo.
Very nimble with the 3ah AS battery, really enjoyed it and I was just drilling 4.8mm pilot holes for 6x100 spax screws in an outdoor planter I just started. PDC for the 12mm counter sink hole/driving the screws, T18 for the pilot. Tomorrow I'll reverse the rolls and see how the T18 feels with the spax screws.
Enjoyed using it so much I am almost tempted to get another one [big grin]. However will wait to see if that Impact driver makes an appearance in 2018 as per the info you posted Henrik.
« Reply #26 on: December 07, 2017, 04:38 PM »
Re: Das Impakt - you and me both. :)
Offline yetihunter
« Reply #27 on: December 09, 2017, 12:38 AM »
Stop it @Henrik R / Pingvinlakrits don't you know that I figured
out that I can order the A18 as a bare tool?
There's a compact battery and charger set that says Metabo on it
at the store down the street.  Stop tempting me, you demon!
:D
Oh yeah, and those Metabo drills really are annoying with their electronic
whirring/whizzing.   It's like importing a Mafell drill is the sane version of an irrational
purchase.
Does it have soft start?  Tell me it has soft start so that I will not want to buy one.
« Reply #28 on: December 09, 2017, 05:40 PM »
 [big grin] A18m has no soft start - unless you activate the Impuls Mode.
I am using the A18m as my "main" drill together with the CXS - a slightly odd pairing but very effective. I do miss the C18 at times but everytime I use the A18m for driving larger screws in high speed I remember how I could not do that with the Festool offerings.
For refinement the Festool C18/T18 is still on top. With the A18m in second gear it is easy to overshoot the medium sized screws - they just sink down so fast... Good thing is that some Centrotec gear fits really well in the A18m so I use the depth stop chuck from Festool so I can keep zipping through medium sized screws in second gear with the A18m.
Very gentle screwing can be achieved with the A18m too, in first gear or in second with Impuls mode but there is no denying that Festool is a little bit nicer. If I had to shrink down my whole outfit to just ONE drill I would have to "settle" for the A18m. There is sometimes no substitute for power and Impuls mode is not a gimmick.
Offline yetihunter
« Reply #29 on: December 11, 2017, 04:19 AM »
Darnit! :0
Plus, you know that the day I order one, the 3 speed will come out. :D
