Pages: [1]   Go Down
  Print
Author Topic: Spare Parts Diagrams  (Read 17329 times)
Matthew Schenker
Offline Offline
WWW
« on: January 31, 2007, 11:17 AM »
For anyone looking to reference part numbers on Festool tools and accessories, check out the parts diagrams: Click Here
« Last Edit: January 31, 2009, 01:20 PM by Matthew Schenker » Logged
FOG Designer and Creator
http://www.schenkerstudio.com
John Langevin
Offline Offline
Springfield, MA
« Reply #1 on: February 01, 2007, 11:06 AM »
I've posted this question before with no luck. I am trying to buy some extra MFS Rail Connector Screw Assemblies which are used to fasten the rails at right angles to one another. The MFS is only suppied with (1) per rail which makes it difficult to make a T-Square arrangement since the rail is only fastened on (1) side. This allows the rails to go visibly out of square. I've spoken to David (I think?) at Festool in California and both times received the wrong parts. I just looked at the exploded parts drawing/list from your supplied link and do not see these parts listed. I am referring to the set screw with two flats on the outside thread with an internal thread for a small head diameter cap screw and the nut that slides inside the adjoining rail. Any help will be appreciated. By the way Matthew I just noticed it says you are in Western Mass. where are you? I live in Springfield.
« Last Edit: June 10, 2008, 12:00 PM by Matthew Schenker » Logged
Practicing Mediocrity Never Begets Perfection
Ned
Offline Offline
« Reply #2 on: February 01, 2007, 11:36 AM »
Hi John,
Try this link.
It looks like simply a scan of a sheet I received in the box with the MFS 400.
I'm sure that one of the part numbers you want is 493 094--that's the screws and little joiners for right angle connections.
The externally threaded tube that those screws go through, that I'm not so sure about.  I'm sure you need it for what you want to do though.
Spare parts have to be ordered directly from our service department. Please call
800-554-8741 and talk to David or Lester.
Hope this helps.
John Langevin
Offline Offline
Springfield, MA
« Reply #3 on: February 01, 2007, 11:45 AM »
Ned, I tried your link and got an error message in German.
Les Spencer
Offline Offline
« Reply #4 on: March 04, 2007, 02:54 PM »
John,
Try this link http://www.mtmc.co.uk/prodtype.asp?PT_ID=14381&strPageHistory=cat.
Les (near Indy) XL
Dave Rudy
Offline Offline
Coloroda Front Range, in the lee of Pikes Peak
« Reply #5 on: March 06, 2007, 11:59 PM »
John,
Use ekat.festool.com (without the www).  Go to accessories at the bottom of the page and you will find the MFS listed there.  Clicking on it brings up the parts list.
Dave
Frank-Jan
Offline Offline
« Reply #6 on: January 31, 2009, 05:46 AM »
I noticed the link in the start post isn't working anymore. Since this thread is sticky: here's the current link: Link to the us version of the ekat-site
I also noticed that the partnumbers that John Langevin were looking for aren't included in the US version. But if you go to the Ekat site via a European festool site, you can find those partnumbers.
For example: link to Dutch version of ekat site
To get to the mentioned numbers: select "routing" in the left column; then "routers", then "accessories for routers", then "MFS400/700...", then "extension profile" (the option in bold is not available via the us ekat). Here you find that the part John was looking for is number 466353 (the number is for all 3 pieces (the threaded insert, the bolt and the sliding nut)
(It is not possible to link to a specific drawing in the ekat site, that's why I wrote out the "route" to get there)
« Last Edit: January 31, 2009, 05:51 AM by Frank-Jan » Logged
Matthew Schenker
Offline Offline
WWW
« Reply #7 on: January 31, 2009, 01:20 PM »
Frank-Jan,
Thanks for noticing that.  One of the problems with posting a link like that is, of course, if the link changes!
I updated my sticky post to reflect the new address.
Stay in touch,
Matthew
Pages: [1]   Go Up
  Print
Jump to:
