SRSemenza
Global Moderator
Offline
« on: May 01, 2012, 10:16 AM » |
I'll peface by saying I don't know much about oil finishes (actual oils not oil based like Poly). For those who have used the SurFix , how do the oils themselves compare to other brands on the market? Would you choose them for reasons other than the application method?
Festool Service 800-554-8741
Kev
Online
« Reply #1 on: May 01, 2012, 10:55 AM » |
Unfortunately ... In my view you need a decent amount of time to assess in the various target environments and I don't believe the SURFIX oils have been out long enough to make a call. To me the consistency of the SURFIX oils do feel a bit different to what I'd normally expect (thicker? More viscous?), but I'm not broadly experienced with oils. Maybe have a peek at Tutorwood's blog. http://tutorwood.com/page/2/
SRSemenza
Global Moderator
Offline
« Reply #2 on: May 04, 2012, 11:43 PM » |
Anyone have any thoughts on this?
Ken Nagrod
Restricted
Offline
« Reply #3 on: May 05, 2012, 12:05 AM » |
Seth, I will let you know after my hot oil massage. Maybe I'll do a review.
ScotF
Offline
Location: Southern Orange County, CA, USA Member Since: Jul 2009
« Reply #4 on: May 06, 2012, 12:48 AM » |
I am interested in hearing from anyone on this topic too -- thanks for posting it, Seth. The applicator looks slick (no pun intended) and if the finish holds up well to various work, then I would be inclinded to give it a go. I pretty much only use oil finishes on my work so this is pretty appealing.
Scot
Timtool
Retailer
Offline
« Reply #5 on: May 06, 2012, 03:15 AM » |
I made a review of it on my site, i can't really tell how it compares to other oils though. Before using the surfix i used my own homemade oil based on linseed oil and turpentine. If it has one thing going for it, then it is the fact that it's a complete package. So far i haven't used the outdoor oil in over a year, but i do often use the one step oil. With only difference to the heavy duty oil that you can get away with one coat and no polishing.
promhandicam
Offline
« Reply #6 on: May 06, 2012, 05:05 AM » |
I wasn't at all impressed and sold my surfix kit on ebay probably to some other sap who, like me, was taken in by the festool name. As timtool pointed out in his review, which I have just skimmed through, you need quite a lot of oil just to load the sponge and it is useless for anything other than a large flat surface. Try doing the sides or top of a carcase or the edges and you get into all sorts of mess. Also as timtool noted, after anymore than 24hrs you have to replace the foam pad as the metal box to store it in isn't airtight. In fact the tin is so flimsy - of similar thickness to a coke can - it distorts just opening and closing it. I've also heard of people having trouble with the festool oil not going off fully and leaving a tacky mess. Don't be taken in like I was thinking that you were getting a quality piece of German engineering - I will stick with osmo polyx applied with a brush or 4" microfibre roller and ragged off with paper wipes as this is a more tried and trusted method.
Scott B.
Magazine/Blog Author
Offline
Paint contractor and freelance writer.
« Reply #7 on: May 06, 2012, 08:27 AM » |
The oil applies and dries. It is a pentrator, in the spirit of Watco, I guess would be the closest comparison for me. I have been testing the surfix for months, on a variety of tasks, including dozens of pieces of teak outdoor furniture. It can be used beyond the realm of large flat surfaces.
I will know more about the performance of the exterior oil after I see it through a chunk of spring and summer. The interior oil is doing well, as you might expect. Will be writing a review soon, just a couple more flagpoles to run it up.
sancho57
Online
« Reply #8 on: May 06, 2012, 11:36 AM » |
Im curious how long/ effective the Exterior Surfix oil lasts before recoat. I got a out door project to do ( a gate) and want a easy oil finish that I dont have to fool with every year or so.
Shhhhhh Dont tell the wife butttttt I bought another…….
Joseph C
Offline
Location: Los Angeles, California Member Since: Jan 2008
« Reply #9 on: March 21, 2013, 01:07 AM » |
Does anyone have any further experience using other oils in the Surfix applicator? (It's been almost a year since anyone posted in this thread, and no one had yet ACTUALLY tested other finishes.)
I am interested in others' experiences using different brands/types of finish in the Surfix applicator system.
Indoor work, I often use OSMO hardwax oil, and sometimes Woca brand. I ball up a bit of rag soaked in oil, layer with white scotchbrite, and wrap the whole business snug in another rag. Dip in the can as necessary. Buff in, and buff dry again a half hour later.
Outdoor work, I prefer Penofin penetrating oil. We brush on a soaking coat (sometimes initially apply with garden sprayer for complex surfaces), and rub all surfaces "dry" 1/2 hour later.
Has anyone tried using either of these oils with Surfix applicator?
Can you "buff in" the surface? Does it save you from mess/drips?
I have a potentially large clear cedar siding job coming up, and would love to streamline the process.
TS75, OF1010, Domino500, MFT/3, CT22 + WCR, CT MIDI, RO150, ETS150, DS400, Grex 2" micropinner (festool green), and packing everything else into systainers, too.
Peter Parfitt
Offline
« Reply #10 on: March 21, 2013, 02:18 AM » |
Festool make the very best woodworking tools in the world - they do not make oil. Osmo make the best oil finishes in the world - they do not make woodworking tools and f they did make just one tool it would be rubbish.
The Surfix concept is brilliant but it would be better if Festool did a deal with Osmo and dropped their current oils. In the meantime, keep buying the fabulous Festool tools and get your oils from Osmo.
Kapex 120, OF 2200, OF1400, TS55, TS55R, CMS-TS55R, PSC420, Domino 500, MFT3, Rotex 90, Rotex 150, CTL26, 1400 & 2700 Guide Rails and a lovely watch Wish List: C15, HL850, BS75, DF700, Second Extractor, new secretary
Joseph C
Offline
« Reply #11 on: March 21, 2013, 02:26 AM » |
Thank you Peter; perhaps my question isn't clear? I am specifically interested in using Osmo and Penofin oils in a more efficient way, and wondering if others have had experiences (positive or negative) using these products within the Surfix applicator system.
Timtool
Retailer
Offline
« Reply #12 on: March 21, 2013, 08:44 AM » |
I stopped using the surfix system, for me it doesn't fit in my workflow as well as a regular can of oil applied with a brush. The applicator in my eyes was the weakest point of it all, the sponge is basically for 1 use and then throw away because it hardens. So that is the first part i abandoned, then i just used the bottles to squeeze the oil out and wipe with a rag, very messy. Now i'm just using osmo oil with a brush, goes faster and works cleaner. And if you put the brush in spirits you can can keep using it forever.
The surfix is ideal for those oiling kitchen worktops on site and such, it's not for big jobs or frequent use i think.
RL
Offline
« Reply #13 on: March 21, 2013, 11:18 AM » |
I am sure Festool are rebranding someone else's oil for their Surfix kit in the same way they rebranded Stabila levels (I think it was Stabila). Since Osmo are German, it is even possible that they are Osmo oils in the surfix kit.
I like green.
TurnagainD
Offline
« Reply #14 on: March 21, 2013, 12:16 PM » |
I don't see why other oils couldn't be used with the surfix applicator. I have tried out the Surfix on a number of projects and found the applicator specifically likes flat surfaces. I also found three light coats works best for me.
Kevin
johninthecamper
Online
« Reply #15 on: March 21, 2013, 12:26 PM » |
festool how about a smaller sponge and or brush tip
jeep jake
Online
« Reply #16 on: March 21, 2013, 12:33 PM » |
i pretty much only use oil, i really like the one step oil. The applicator is killer it really makes it very easy and clean
leakyroof
Offline
« Reply #17 on: March 21, 2013, 04:50 PM » |
. I did not experience this problem with the applicator sponge at all. I will leave it for weeks at a time, and return to find it still very useable . I primarily was using the Outdoor Oil. My feelings on using the SurFix oil system do not take Osmo into account as I've yet to use it.
Festoolfootstool
Offline
The trouble with Bob is its all about Bob
« Reply #18 on: March 21, 2013, 05:34 PM » |
if the sponge is kept in a ziplock type bag and the air excluded the sponge will be good for six months plus
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Timtool
Retailer
Offline
« Reply #19 on: March 21, 2013, 06:51 PM » |
Maybe they changed something from the time i was using it, because i kept mine in a sealed plastic bag with as few air as possible, and that would keep the sponge for a week or two max. I didn't use the metal container because the dimples would seal the bottom of the sponge and render it impermeable. Keeping it as intended in the metal containers would keep the sponge just for 24 hours, but even then it would get hard. I almost exclusively used the heavy duty oil, which i suppose hardens more.
Peter Parfitt
Offline
« Reply #20 on: March 22, 2013, 02:18 AM » |
Have you tried this for a long period - my experience with oil finishes is that they will damage a plastic bag if left in contact for a long time. Peter
Festoolfootstool
Offline
« Reply #21 on: March 22, 2013, 06:18 AM » |
Have you tried this for a long period - my experience with oil finishes is that they will damage a plastic bag if left in contact for a long time. Peter Peter when there was a lot of talk about the surfix last year I used it on a job and then put the sponge in a quality freezer type resealable bag and excluded all the air the sponge was still soft afer six months of storage the key is excluding the air
Peter Parfitt
Offline
« Reply #22 on: March 22, 2013, 06:46 AM » |
This is brilliant - I will do this from now on. About a year ago I experimented by putting my brushes in some snappy wrappy (cling film to ordinary mortals) and also in a plastic bag from a supermarket. Neither method worked beyond a few days and the plastic bag (which I forgot about) had deteriorated and after 3 months I had to throw the whole lot away. Great - many thanks. Peter
leakyroof
Offline
« Reply #23 on: March 22, 2013, 08:44 AM » |
Maybe they changed something from the time i was using it, because i kept mine in a sealed plastic bag with as few air as possible, and that would keep the sponge for a week or two max. I didn't use the metal container because the dimples would seal the bottom of the sponge and render it impermeable. Keeping it as intended in the metal containers would keep the sponge just for 24 hours, but even then it would get hard. I almost exclusively used the heavy duty oil, which i suppose hardens more. Ahhh, THAT'S probably the key thing. I haven't used the Heavy Duty Oil at all, only Outdoor and One Step. I bet you're right, different formulation. I'm about to build some storage shelves for my shop, and wanted to finally try the Heavy Duty Oil. This will be a good test of sponge life when using it.
panelchat
Offline
« Reply #24 on: March 22, 2013, 04:28 PM » |
i've put a little plastic sheet as a liner in the base of the can and had the Surfix oils last a few weeks, no problem. the same trick with osmo did not work as well (maybe i got a day or two?), the problem is that the osmo just dries too quickly. i guess i could try a ziplock... in my experience linseed oil, which is the primary ingredient in the surfix, takes a particularly long time compared to other oils to dry/cure, so this helps with storage.
i use osmo in the empty surfix applicators and it works fine, you just might use up a few more sponges due to storage. there's quite a bit of pushing the applicator around for large wood surfaces and this can get tedious, so i plan to change up to a very large sponge or similar for jobs with a lot of surface area. but for medium, small jobs the surfix thingy works great and quickly, with either oil. nice for inside corners and panel edges too. when its about 3/4 empty, it can get very hard to squeeze the finish out- i refill early and it makes it much easier.
