Chuck Kiser
Offline
Location: Palos Park, IL (Chicago south sider) Member Since: Jul 2007
Finish Carpenter in the Southside of Chicago
« on: September 29, 2012, 05:56 PM » |
Had some small issues with my well used Kapex that were easily solved with some cleaning and lubrication. This last issue is a little troubling and a safety issue as well. The saw head wants to stay in the down position after a cut. In most cases I have to lift it up after a cut. Since the blade cover lowers as the saw head raises this can be a problem when I'm running material quickly. Do I need to adjust something or disassemble something to get this back to normal operation? Thanks for any advise, good OR bad, I'll listen to all of it.
Life is too short for bad wine or cheap tools.
FS2700, FS1400(2), TS55, TS75, CT Midi, CT 22 w/ boom, ETS150/5, RO150, DF500, OF1400, OF1010, MFT1080(3), PS300, DX93, LR32, MFS700, MFS400, MFK700, ETS125, RTS400, RS2E, KAPEX, MFT/ KAPEX
Alan m
Offline
« Reply #1 on: September 29, 2012, 06:07 PM » |
its probably either crap built up around the pivot(remove and lubricate) or spring issue. if its in warrenty i would send it in for a medical.
johnnyinnb
Offline
« Reply #2 on: September 29, 2012, 07:25 PM » |
Its not the pivot pin, its the spring, as it coils it rubs on itself and they bind, blow the dust off it and a little lube on the spring will let the coils slide past each other
« Last Edit: September 29, 2012, 07:43 PM by johnnyinnb »
Thanks Johnny
He`s a block off the old chip
Shane Holland
Festool USA Employee FOG Administrator
Online
« Reply #3 on: September 29, 2012, 07:37 PM » |
I definitely recommend that you give the service department a buzz on Monday. They are in the best position to tell you what the cause might be. It'll cost you nothing more than a few minutes to make the call. Their number's below in my signature, M-F, 8a-5p ET.
Shane
tjbnwi
Online
Cedar Tucky Indiana
« Reply #4 on: September 29, 2012, 10:07 PM » |
Chuck,
Get a can of GDL (garage door lube). It is designed for the redundant coil springs on overhead doors.
ccmviking
Offline
« Reply #5 on: September 29, 2012, 10:18 PM » |
It actually looks as if the spring is wound around like a plastic tube or something. Either way this is common and very easy to fix. Just drop some 3 in 1 or air tool oil onto the spring and then you'll have to hold the head to keep it from bouncing up so quick. Festool really should address the conflict in parts here. Surely a coating or something would fix it. Like I said it's easy to fix and pretty long lasting with a little lube. And no I haven't had it cause an excess in sawdust build up. Just put some lube on the spring and you'll be happy again.
Chris...
Chuck Kiser
Offline
« Reply #6 on: October 01, 2012, 06:21 AM » |
The lubrication on the coil spring worked like a charm, thanks for the tip. The spring was clean, it never occured to me the coils would bind up.
