Author Topic: Vlies for DTS 400?  (Read 1096 times)
Offline Midnight Man
Vlies for DTS 400?
« on: September 11, 2017, 10:03 AM »
Thank you to anyone who can help - and a "heads up", I am posting from Australia (but am very happy to have product from overseas if this is the only option).
I have a DTS 400 sander, and because it's nice and compact, and can get into corners etc, I am keen to get some Vlies pads for this machine to clean up metalwork and so on.
Truly, I had simply assumed these were available (wouldn't have stopped me buying the sander anyway), but a look on Festool site here in Australia says there isn't such a product (or I missed it somehow).  I've had a Google, and found a thread here saying "discontinued", but that was contradicted.
Anyone know if Festool make Vlies for the DTS 400?  And if so, where I might be able to buy some (USA dealers, I'm happy to buy from you if it won't get you in trouble with Festool)?
Offline Shane Holland
  • Festool Dealer
Re: Vlies for DTS 400?
« Reply #1 on: September 11, 2017, 06:17 PM »
No Vlies for the DTS here in the U.S.
Fast, Free Shipping - Festool Trained Experts - Unparalleled Customer Service - No Sales Tax Collected (Outside NY/VA/KY)
Offline Holmz
« Reply #2 on: September 11, 2017, 06:23 PM »
You might be better off with Viles on a round Bosch, Flex, Ryobi, or even the lucky-starfish brand from Bunnings?
It is not like you need magical vacuum and dust control, so the first cheaper sander with velcro would work as well as any other.
What are you doing with it?
I have had mixed results... outside= not so great, inside is ok so far.
« Reply #3 on: September 12, 2017, 04:53 AM »
Initially, I want to use it to clean some surface rust from a cast iron table top... and the only reason I'm seeking it for the DTS 400 is because I'm still putting aside coin to buy an ETS 150 ;)  (I'm still setting up, and getting the workshop and tools together, hence no beefier "normal" sander yet)
Offline Chris Wong
  • Festool Dealer
  • I make sculptural furniture.
    • Flair Woodworks
« Reply #4 on: September 12, 2017, 08:53 AM »
Buy the 150 mm Vlies and cut it to fit the DTS.
Chris Wong, http://FlairWoodworks.com
The thoughts and ideas expressed here are my own and do not necessarily represent those of http://UltimateTools.ca.  But Dan does say "hello".
Offline Holmz
« Reply #5 on: September 12, 2017, 08:57 AM »
A wire wheel or some 240 would work too.
I use a makita grinder for some of this sort of stuff with a flap wheel.
Or any sander with 240, and if that doesn't cut it then more down to 180, etc...
I thought you were using the viles with the surfix, so ignor the inside/outside point.
« Reply #6 on: September 12, 2017, 10:59 AM »
Now there's an answer from outside the box - please don't ask why I didn't think of it myself - thank you!
Thanks Holmz, I didn't realise that using actual sandpaper on cast iron tops was OK (I assumed it would ruin the surface)!
Seems I now have two good solutions, thank you all :)
Offline Bert Vanderveen
« Reply #7 on: September 12, 2017, 01:38 PM »
It is even simpler… lay down a piece of vlies (or scotchbrite or whatever) and put the sander down on it. Start and off you go… : )
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400
Offline Holmz
« Reply #8 on: September 12, 2017, 04:25 PM »
It is already ruined with the rust, you are not goign to ruin it more.
And under the patina it is still good metal.
Once you are done, then either wax it etc, or use Birchwood Casey(TM) gun blue. (which is not great, but looks nice).
Bert's suggestion is good. Or just use scotchbright by hand. There sell scotchbright flap wheels which fit the 5" grinder...
« Reply #9 on: September 13, 2017, 09:49 AM »
Thank you again, another product I wasn't aware of!
I was considering either Silverglide (https://www.carbatec.com.au/machinery-and-accessories/lubricant/surface-lub-and-protection) or Camelia oil (https://www.carbatec.com.au/handtools-and-handplanes/accessories/oils/camellia-oil-240mm-bottle)... looks like I am off to do some more reading, thank you! :)
Offline Holmz
« Reply #10 on: September 13, 2017, 06:17 PM »
The gun blue actually can rubs off but it looks nice for a bit.
I would something else, even just a paste wax, or a paste wax over the blue.
I would be trying the camellia oil myself.
