« Reply #15 on: July 15, 2018, 05:50 PM »
Peter:I’m sure that you’re - As is the old quote: “Right on the ‘money’”.
I’m also - As you say: “sadly mistaken”. Very.
BTW... A “rabbit trail”: I see that you’re located in Central VA.
We lived 20+ years in Chesapeake, VA.
My backyard neighbors - Bill and Heather - Owned/operated the Norfolk, VA Woodcraft store.
A fellow that worked for them - Learning the business - Now owns/operates the Colorado Springs, CO Woodcraft store. Small world.
![Smile [smile]](http://festoolownersgroup.com/Smileys/default/smile.gif)
The COS Woodcraft store sells Festool - And has a normal “Woodcraft” Festool display.
Austin Hardwoods in Denver - Has a MORE THAN COMPLETE (much more) Festool display.
I’ll speak to both next time I’m there.
« Last Edit: July 15, 2018, 07:38 PM by Joe Felchlin »
FESTOOL: CT26 and CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides and Extensions, OF1400 EQ Plunge Router, OF1010 EQ Plunge Router, HL 850 Planer, RO125 FEQ Rotex Sander, LS 130 EQ Linear Detail Sander, DX93E Detail Sander, C12 Cordless Drill, CXS Cordless Compact Drill Driver, SYS-Centrotec-Set, Domino XL DF 700 EQ Plus Tenon Joiner Set, Domino DF 500 Tenon Joiner | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIGS: D4R 24 Pro Dovetail Jig, FMT Pro Mortise & Tenon Jig | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
