JimB1
Offline
« on: January 17, 2012, 08:31 AM » |
Any chance Festool will make a 90 degree adapter for the 36mm hose so you can use it with the mini/midi while still being able to stack systainers on top without hitting or crimping the hose? Not sure if this will work but something like this for the 36mm hose : http://www.festoolusa.com/products/dust-extractors/reducing-hose-sleeves/hose-sleeve-antistatic-angle-adapter-456806.html Not sure if this is just a replacement for the 27mm hose since they don't have the specs for what size hose it is for... -Jim
OF 1010, RO 150, ETS 150/3, RTS-400, Pocket StickFix Sanding Block and a CT Midi
Shane Holland
Festool USA Employee FOG Administrator
Online
« Reply #1 on: January 17, 2012, 09:17 AM » |
Jim,
The part you've referenced is designed for the 27mm hose. There is no right angle for the 36mm.
Shane
JimB1
Offline
« Reply #2 on: January 17, 2012, 09:28 AM » |
Jim,
Shane
OK, then add that to the wish list I can't be the only person wanting this. Same part they make for the 27mm hose just in a 36mm size... Thanks -Jim
PeterK
Offline
« Reply #3 on: January 17, 2012, 10:25 AM » |
If you go to the shop vac section of a big box store - Lowes if my old memory is any good - they sell an accessory that is a combo 90 degree adapter with a detachable small brush on the end. It is what I use. Think it was about $9.
VictorL
Offline
« Reply #4 on: January 17, 2012, 10:44 AM » |
I do use CT-mini with 36mm hose for house cleaning. Mini's housing hose opening is not designed for 36mm hoses, it's too small you have to squeeze hose. Another thing is that Mini's/Midi's housing is too small for keeping 36mm hoses on board. So I have to keep it off vac.
VictorL
Steve R
Offline
« Reply #5 on: February 19, 2012, 12:15 AM » |
The other part is of this is....is it AS?
Cheers, Steve
Cableaddict
Offline
« Reply #6 on: February 23, 2012, 07:37 PM » |
Jim,
If you search on the net, you can easily find a 2.25" 90 degree adapter, even anti-static.
Just use this, and plug your current Festool hose into it.
Dave Hale
Offline
« Reply #7 on: June 20, 2012, 08:36 PM » |
Jim,
I'm not finding any hits. Anyone find one at a reasonable price (with a link)?
