Author Topic: Deck Sander  (Read 7157 times)
Offline tedrin
    • Eco Star Painting
Deck Sander
« on: May 23, 2018, 02:21 PM »
Festool should come up with a deck sander. That is, a deck sander with a handle where you stand up to do the stripping. I'm a painting contractor and would love to own a smaller deck sander that is easy to transport to job sites.
I think a smaller deck sander would be more beneficial than one of those large ones. You'd be able to use it in tighter sections. I wonder if there is one (with a handle) that is 9" and similar in size to a Festool Planex? Imagine having a 9" deck sander with the stripping power of a Festool R090! Hauling it around would be a breeze.
Regards,
Ted
Eco Star Painting
« Last Edit: May 23, 2018, 03:17 PM by tedrin »
Offline tedrin
    • Eco Star Painting
Re: Deck Sander
« Reply #1 on: May 23, 2018, 02:43 PM »
Festool,
Here's an idea. How about building a long handle for the R0150 so you can stand up while sanding a deck floor? Have an on/off switch built into the handle somehow. You might have to add some weight or something so it doesn't fly around. Maybe add some guard rails surrounding the sander. I'm just brainstorming here. Your welcome.
« Last Edit: May 23, 2018, 03:18 PM by tedrin »
Re: Deck Sander
« Reply #2 on: May 23, 2018, 03:21 PM »
Hei,
How would Mirka Leros work on this?
https://www.mirka.com/mirka-leros/
BR Simo
Offline tedrin
    • Eco Star Painting
Re: Deck Sander
« Reply #3 on: May 23, 2018, 03:34 PM »
Hei,
BR Simo
Wall sanders don't have the paint stripping power of a rotex.
 I own a Porter Cable 7800 and hook it up to my ct26 for walls. I'm waiting for that Mirka Leros to be made available in Canada because I want to buy their 9" abranet mesh pads.
Online Cheese
Re: Deck Sander
« Reply #4 on: May 23, 2018, 06:45 PM »
Why wouldn't a Planex with 24/36 Saphir or 40/60 Granat work?
Offline tedrin
    • Eco Star Painting
Re: Deck Sander
« Reply #5 on: May 23, 2018, 07:12 PM »
It's not made for stripping paint on a deck floor.
 It's like comparing the two different modes of a Rotex sander. When in RO mode it can strip paint with ease. The other mode is less aggressive and is meant for finishing.
Offline leakyroof
Re: Deck Sander
« Reply #6 on: May 23, 2018, 08:47 PM »
. Another issue is that Weight can be your friend with floor sanding. The Planex is so light compared to even a smaller Floor Sander, so you’re not generating that heavy footprint that I hear Floor Sanding people write and talk about.
I’m also not sure I’d want to try and handle a Rotex Mode Sander way up from the machine while standing.
Rotary Sanders are more predictable for me since they aren’t jumping around like a Geared Sander when sanding a floor. I’ve used my Planex in tight spots for this and predictably the material removal rate is slow.... [big grin]
I have seen a Video on YouTube some years back where a guy modified an Edger Floor Sander, probably a 7” model, to be used Standing Up.
It was interesting and looked like he had fairly good control over it too.
Offline Bob D.
Re: Deck Sander
« Reply #7 on: November 29, 2018, 04:46 PM »
I had a 1200 sf deck at my house which I stained every other year along with minor maintenance and refinished about every 6 years. Those 6 year sessions were repairs such as replacing deck boards, dealing with fasteners that have popped up, etc. then sanding with a floor sander, vacuum and staining with a semi-transparent stain.
The sander I used had four 9" discs that counter-rotated and was a breeze to use over one of the big single disc floor sanders.  I think something like this made with 3 or 4 150mm sanders would be a nice size. Maybe even some sort of frame that would hold current model sanders in a group and they could all be plugged in to one power cord running down from the handle where all of the sanders are operated by one switch. A single hose could be incorporated into the handle (maybe made from a appropriate size tube) and then from a manifold branch out to each sander.
When not used ganged together as a floor sander you could break out the individual sanders for normal use.
Offline Whatever
Re: Deck Sander
« Reply #8 on: January 11, 2019, 08:14 PM »
It's called a RAS 180
