Pages: [1]   Go Down
  Print
Author Topic: Festool Mini WIDE BELT Sander  (Read 2036 times)
stairman
Offline Offline
« on: October 13, 2011, 12:27 PM »
There are no thicknessing machines from Festool,  and  -no one makes a portable WIDE BELT SANDER.
how about a 12-13" Portable widebelt sander / abrasive planer?
or even a changeable contact roller that can be exchanged with a planer/moulder head for planing/moulding duty?
I am envisioning a miniaturized version of my 37" Timesaver.   something hefty enough to be solid,  but small enough that it can be transported on site.
this would fill the only HOLE that I see in the entire Festool System.
would you be interested in one of these?
& what would you be willing to pay for such a machine  (considering it would be made to the usual Festool standards)
Kapex on a UG, TS75, OF1400 (x2) OF2000,,HL850,  Domino, RO90, RO125,  LS130, RAS115, MFT3, C12 Set, CXS Set, LR32 Set,  arsenal growing as fast as I can afford it!
Looking to buy: RO150EQ+ ; LR32 guide rails, 3000mm guide rail, parallel guide set   ;  another TS55 to replace the 1 I sold...   OF1010 and additional Festool Routers ;  RS2  ;    and a FESTOOL BS105 BELT SANDER SET
OK, let's face it, I'm always looking for any Festools / accessories.
Alan m
Offline Offline
« Reply #1 on: October 13, 2011, 12:31 PM »
a festool lunch box planer idea has been talked about here before. it is one of the only few tools that festool dont have in their system for site work. i would buy one if they made it.
if you put a changable head in there ( or seperate head after the cutting head) for sanding that would be great. i would like it to ossilate back and forth to minimise head build up  etc.
now
wish list
FulThrotl
Offline Offline
« Reply #2 on: November 08, 2011, 11:21 PM »
we can only hope.....
i'd like to see something that can do both sanding and planing, with an interchangable drum/ cutter head.
failing that, planer before sander.
suspecting it would be expensive, in the kapex price range... 1300 ~ 1500... i'd be interested in something like
that in that price range.....
... it's not good.... my festool dealer
knows me by my first name....
...i'm suspecting i'm his 401K.....
stairman
Offline Offline
« Reply #3 on: November 17, 2011, 12:42 AM »
The Wide Belt sander is my most prized machine that I own.  - besides custom work/cabinets, I build a lot of entry and passage doors, stair parts,  and even for dimensioning rough stock to .001" accuracy,  nothing beats a widebelt, except a BETTER widebelt.
I've used 24" WB Sanders, and they're too big to be anything but stationary,  but not big enough for professional use (unless you're a luthier or for other specific uses)
37" 43" and 52" are the normal sizes and these monsters are always 2500-4000lbs, require massive 3 phase power, an 80 gal 2 stage compressor, and enormous dust collection capability.
however, if a true WIDEBELT,  (not a drum sander, those are a joke) Wide Belt sander were designed with 13" width, perhaps a 36-40" belt length, optical tracking system that was electromechanically oscillated and adjusted,  and typical Festool innovation and design,  I think something truly AMAZING could be achieved,  and once in for all,  the "HOLE" in the Festool system would be filled...
add an optional planer head and "mobility kit" for the machine, and keep it under $3000 and 150lbs (base price) and I would buy at least one
I get the feeling there are some here who don't understand what a widebelt is/does?
Felder are among the finest:
http://www.felderusa.com/us-us/products/wide-belt-sanding-machines/wide-belt-sander-fw-1100.html
Timesavers are the quintessential "timesavers" of most woodworking shops
 http://www.timesaversinc.com/
and believe it or not, Grizzly, provides a very good machine for the money in their wide lineup or WIdeBelt Sanders.
If I could have any 1 new widebelt under $20k, it would probably be another Grizzly...
the 43" single head machine I had in my old shop ran 5 yrs or HARD use without failing with the exception of a $1.77 spring which was fixed in only 3 days...
http://www.grizzly.com/products/category.aspx?key=550000
so...  if planers can be made into "travel size" mobile machines,  -then why can't a widebelt?  with Festools Relentless pursuits of IDEAL form and function, I think they could certainly come up with one.
and again, if it had an optional spiral index cutterhead,  perhaps another moulder head and other standard BRILLIANT Festool accessories (gang rip saw?)
it could really be the core unit of a full millwork shop in a semi portable unit.
at least consider it, Festool!
Pages: [1]   Go Up
  Print
Jump to:
