Pages: [1]   Go Down
  Print
Author Topic: More dust control for domino xl  (Read 964 times)
cgraham
Offline Offline
« on: April 22, 2013, 08:46 PM »
Not being known for having the cleanest shop, festool has definitely helped me in that area. Putting tools back in their systainers and superior dust control are two things festool has helped me with.  That being said, I think the domino could have better dust removal from the mortise pocket. This could be accomplished by the bit having a hole in the center. The hole would be the entire length of the bit. The vac would pull the last bit of sawdust out of the mortise.  I am not a design or engineer type so I don't know how it could be built but it sure would be nice to not have those little piles of sawdust when you are finished
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #1 on: April 23, 2013, 10:43 AM »
My observation of the Domino is that with proper dust extraction, CT w/ 27mm hose, it gets virtually all of the dust and leaves none in the mortise(s).
Maybe you have a partial plug?
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #2 on: April 23, 2013, 04:06 PM »
Tom, I don't have the Domino XL but I remember other members mentioning that there is dust left in deep mortises.
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #3 on: April 23, 2013, 04:32 PM »
I'll have to check it out more carefully next time. Thanks for pointing that out, Brice.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
ccarrolladams
Offline Offline
« Reply #4 on: April 23, 2013, 05:39 PM »
We now own 3 of the Domino 700 XL in addition to many Domino 500. One of my Domino 500 was the first delivered by my local dealer the minute that was legal.
Never in all those years has dust removal with 27mm AS hose and CT22s been an issue with either Domino machine.
Was the problem a kinked hose? Or the vac being turned to low suction?
As for a radical redesign of the bit, I will follow the opinion of Festool engineers. Considering that the bit rotates ate high speed while oscillating, it would be fascinating to lear a proposed engineering solution to hooking a hollow bit to the suction and moving dust through such a small hole.
Alan m
Offline Offline
« Reply #5 on: April 23, 2013, 06:12 PM »
i think you would be better off blowing air down the bit that trying to suck the dust through it. the air would blow the dust back to where the dc can suck it up
now
wish list
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #6 on: April 23, 2013, 06:51 PM »
You just described a gun drill, Alan, except a gun drill uses cutting fluid down the center of the bit. They can drill incredibly deep in quite hard metals, depending on how high the fluid pressure is. Machine shops that specialize in drilling deep and straight use specially designed pumps because the fluid pressure stiffens otherwise relatively flacid bits.
The air pressure would have to be incredibly high (it's a gas) to mimic the characteristics of a gun drill filled with cutting "fluid". Oil well drill bits also have drilling mud running down the drill pipe and into the bits but I don't think it would be very practical in the case of a Domino bit. A Domino bit is a router bit and that requires a lot more structure than even a twist drill, much less a gun drill.
I also don't think it's necessary or of any significant value.
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
cgraham
Offline Offline
« Reply #7 on: April 23, 2013, 08:06 PM »
I originally wrote this post as more of a " wow, wouldn't that be cool" than as a serious problem with the domino.  I get a kick out of the responses to various posts about how important dust control is to people. That is why I commented on how much dust is left in the domino mortises. Just finished a cedar table and the mortises were 50mm deep and the pile of sawdust left in each mortise was very substantial.  Not a big deal. Just flipped the posts over and knocked it out.
ScotF
Offline Offline
WWW
« Reply #8 on: May 09, 2013, 11:26 PM »
At the Festool Road School Allen kept the Domino 700 in place fully plunged for a couple of seconds on each cut and that cleared virtually all of the chips and dust from the mortises.  If you go quickly I think that it leaves more in the holes.
Scot
greg mann
Offline Offline
« Reply #9 on: May 10, 2013, 01:53 PM »
Scot
Good advice here. Just dwell a bit at the bottom of the cut to give the suction time to work. The physics of trying to get dust down the middle of the tool would require extreme levels of negative pressure and would be defeated by the far easier flow of air external to the tool, not to mention the vacuum would somhow need to be connect to the opposite end of the spindle which is oscillating back and forth at a good clip. I get the tongue in cheek part. This is somewhat like suggesting the use of skyhooks in place of a boom arm.
Greg Mann
Oakland, Michigan
jacko9
Offline Offline
« Reply #10 on: May 24, 2013, 08:45 PM »
I agree with Tom and I have a lot of experience with gun drilling and the center hole is very small which would necessitate high pressure gas to get the desired results and I'm not sure that can do that in wood machining.
Jack
Pages: [1]   Go Up
  Print
Jump to:
