Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 ... 21  All   Go Down
  Print
Author Topic: Fill in the blank: I wish Festool made a ______!  (Read 98537 times)
Ken Nagrod
Restricted
Offline Offline
« Reply #240 on: February 13, 2011, 10:24 PM »
Brice,
I've got an easy solution for that.  Just double my drywall labor rate.  Grin Grin Grin
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #241 on: February 13, 2011, 10:26 PM »
Brice,
Why didn't I think of that. Doh!
fdengel
Offline Offline
« Reply #242 on: February 14, 2011, 01:18 PM »
Nice job!
But not that extreme lol!
Im on about just simple dummie frames for normal house which are very wide and low profile which I would use my jigsaw to cut not a router lol I would have two pieces of ply and then stick some 2x1 inbetween.  Your circumference is small enough for you to use your Festool Mfs but if you had much lower profile 80 mm at 1metre or more thats a very large circle. You would need a longer mfs.
JMB
If the sizes tend to be reasonably consistent, you could carry pre-cut patterns and trace them with a pattern bit (or flush cut bit) using a router.
dharmon
Offline Offline
WWW
« Reply #243 on: March 13, 2011, 01:31 AM »
A dust-free drywall router with templates to cut accurate "old work" holes and improve my techniques for cutting holes for new work.
GPowers
Offline Offline
Metric convert
WWW
« Reply #244 on: March 13, 2011, 02:50 AM »
I wish Festook made a Dust extractor that integrated better with the boom arm. like moving the vacuum port the top back instead of front and centered. The current routing the vacuum hose from the front over the handle etc just does not look will engineered . Look like an after thought.
Greg Powers
davidbrac
Offline Offline
« Reply #245 on: March 15, 2011, 04:34 AM »
I wish they made a 2 inch rotary pad for the RO90, l have used this sander on items on my lathe and its excellent, but a smaller pad would help
woodguy7
Offline Offline
« Reply #246 on: March 15, 2011, 09:30 AM »
Another brit, welcome  Smile
Woodguy
Shirt size medium
jmbfestool
Offline Offline
« Reply #247 on: March 15, 2011, 12:44 PM »
Woodguy
Yes! We will take over Fog soon!
JMB
James Watriss
Offline Offline
« Reply #248 on: March 16, 2011, 11:09 AM »
I can't see lugging a drill press to and from the site.
For a few years I've been using a cheesy drill guide. It works-ish. Kinda.
My proposed refinements:
-Hooks to drill via fast-fix collar. I feel like chucking up to the pin on top of the guide's chuck makes for un-necessary wear and tear. Also, locking the drill handle at a specified angle feels like it would cut down on the flopping around and make it easier to line up.
-Uses centrotec chucks. No point in adding a costly chuck to the thing when we already have good ones in the kit. Also, no chuck key to lose.
-I've screwed a board onto my guide's base, so I can clamp it up to things, to try to keep it accurate. I'd like a base that bolts to MFS rails, both for clamping, and for repeatable positioning in the middle of a field. Also, hooking to the edge of short MFS rails would give it the ability to clamp it to an edge. Thinking door latches, alignment pins for table tops and other pieces, etc.
-Theoretically, I'd also like a fine-adjustment slide built in to the base, similar to the guide stop blocks for the router, so that I can fine-tune the drill bit's point of entry after everything's clamped up. That, or a fine adjustment "nudging" knob that bolts onto the MFS rail, next to the base, to enable "nudging" of the base. Lastly, some sort of calibrate-able indicator that works with the measurements that are already on the MFS rails.
-Beefier angle adjustment mechanism, with a SOLID 90 degree stop. Also folds to 0 degrees to fit inside big sortainer-4 drawer.
-Compatible with LR 32. The ability to drill regularly spaced holes for alignment pins or dowels would be huge. All that would be required here are similar bolt holes to the 1400.
-darn well better be AINA.
I think that's the bulk of it...
« Last Edit: March 16, 2011, 11:14 AM by James Watriss » Logged
Tom Bellemare
Festool Dealer
Online Online
WWW
« Reply #249 on: March 16, 2011, 11:15 AM »
Great idea, James!
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
James Watriss
Offline Offline
« Reply #250 on: March 16, 2011, 11:38 AM »
My second big idea.
A recent job has really brought home my need for over-head routing. Plywood is getting less and less regular these days, and the ability to get it to fit into dados, or to leave an accurate thickness after a router pass is just a hassle. I'm thinking something similar to the router bridge for the MFS, but beefier, open on both ends, and more versatile. Dig it:
-Brackets to mount MFS rails to the sides of the MFT, such that one side edge is resting on the MDF panel. One rail on each side of the table.
-No-sag bridge that spans the whole table, resting on the MFS rails, slides easily, resting on plastic bushings or roller bearings. The router mounts in the bridge, and is able to be positioned and fixed anywhere along the bridge, or to slide along the bridge. This is basically the unit they'd have to produce, along with the brackets mentioned above.
This would enable overhead routing of dadoes or rabbeting of plywood edges to make cleaner joints when inserted into dadoes. Given that I've had to run plywood on edge between a straight bit and router table fence to make this happen, an MFS mounted version of an overhead router would be much easier. I'm envisioning the ability to work on pieces longer than the table, cutting rabbets and grooves either in line, or perpendicular to the piece. Think of it as a full, x-y axis overhead guide rail.
The big deal:
-With some thought put into clamping elements, and a height-adjustable mounting attachment for the power planer, we would also now have an MFT-based thicknessing system. We've been bragging for years about how it's easier to slide the saw over plywood than to slide plywood over a saw. This isn't much different. Given the ability to determine the height of the cut above the table, I think it'll be easier to slide a power planer over the wood at a specific height, than to lug a lunchbox planer to the site. AND this system would have a width restriction of the width of the MFT. For those of you shop guys who are trying to figure out how to plane down that plank that's 16" wide, and you only have a 15" planer, you're in luck. This should be able to surface tabletops if need be.
-Same deal with the belt sander. You now have a job site version or shop version of a time saver. Flattening out frame and panel doors anyone? Slab tables? Wide figured woods?
-Again, since it's my idea, and I'm in the states, if this isn't AINA, it really won't be fair. But we'd need to work more seriously to get the belt sander over here.
« Last Edit: March 16, 2011, 04:50 PM by James Watriss » Logged
fdengel
Offline Offline
« Reply #251 on: March 16, 2011, 12:20 PM »
Hmm, a "straight-drilling" add-on chuck/attachment for the Festool drill line...  maybe one that fits between the drill and another chuck the way the right-angle adaptor does, but this one had sides that go down to some sort of ring/base that rests against (or optionally gets clamped to) the workpiece?
What will people think of next?
(I'd buy one if the price was reasonable).
Timtool
Retailer
Offline Offline
WWW
« Reply #252 on: March 16, 2011, 03:20 PM »
this may have been posted before, but i would really pay anything for a small tiny little sander that fits in your palm, and who's only task is to sand edges!
take the sharp  edge off planed and sanded wood, i just really hate doing that by hand and i always end up tearing the paper.
there is already a large oscilating sander with a concave V shape, but im thinking of something way smaller, the size of a pc mouse.
sancho57
Offline Offline
« Reply #253 on: March 27, 2011, 04:34 PM »
I wish festool made some intructional DVDs.  Just showing various types of popular projects setting up ad using the products.
Also I really wish festool made a MFT3 kit. so if someone wanted a longer /wider or both MFT3 thay could order the table parts and maybe some pattern paper so we can make our own tops to fit.
or sell a solid wood MF top.
Ive been thinking about making one taking the top to a cab shop with a huge drum sander and pay them to sand it flat and to size….
a standard repair for the top …..
Just a few I wish festool has a….  wishes :>D
Shhhhhh Dont tell the wife butttttt I bought another…….
ThomasC
Offline Offline
Custom Cabinetry & Built-In's
WWW
« Reply #254 on: March 27, 2011, 07:20 PM »
I'll admit I haven't looked at all the posts in this thread, so maybe this has already been mentioned, but I wish Festool would offer a 75"/1900mm LR-32 guide rail. I like this size rail for cross cutting sheets, especially angled cuts. I think the 95" LR-32 would be way too long for this. Personally, I think it's too long to be useful for built-in's with the LR-32 system too. I build a lot of cabinets that are 8-10" high, but very seldom do I require a full run of shelf pin holes 95" high. My shorter (I don't remember - 42", maybe?) rail is often too short. I think the 1900mm would fill the void well. I have, I think, 6 or 7 rails and I would love to scale back. I've been making an effort to only haul around the minimum amount of equipment. It still fills up my truck, and occasionally more, but at least I'm more efficient than I used to be.
TC
builderbob
Online Online
WWW
« Reply #255 on: March 28, 2011, 12:00 AM »
I just saw on Bob Marino's site a LR-32 rail joiner. I haven't heard of or seen it anywhere else, but that could help for those of us that need to get extra length outta the LR rails!
http://www.bobmarinosbesttools.com/lr-32-guide-rail-connector/p/496938/
Bob
Kapex, TS55, Domino, MFK 700, OF 1400, OF 1010, RAS 115, RTS 400, ETS 150/3, ETS 125, CT 22 (2), C 12 (2), T-15+3, T-12+3, PSB 300 & more MFT's than i can count!
worknfool
Offline Offline
If you can't use a hammer, it must be electrical.
« Reply #256 on: March 28, 2011, 10:52 AM »
I tried to address this from the stand point of what I still own that's not Festool, and that I use frequently. The belt sander is a no brainer. My best flat work unit is m Porter Cable locomotive. It's an antique worm drive pig that will destroy a project in a second of inattention, but once you get the hang of it there's nothing plastic and new that comes close IMO. For quick and light I'm constantly grabbing my Bosch 3x21 or 4x24. The Multi-tool thing is cool but my Fein sits for weeks at a time without being looked at.
As for recip saws, although I don't do field work or many installs any longer, mainly just in shop, my Porter Cable Tiger Cub I think it's called is slick as seal snot. The articulations allow it to go places that nothing else will fit. A Festool variant that incorporated a brushless E.C. - lighter duty motor, cordless w/ LiOn batteries, and some sort of off-set attachment that gave it the flush cutting capability of my Bosch fine cut 1640VS while keeping the articulation of the Porter Cable. Don't care for their blade changer though. It's very positive and Ive had better longevity from it than the DeWalt/Rigid style but getting a hot blade out is a test of your tolerance for pain.
How about a panel cart that worked with everything. Something that lifted panels from vert. to horiz. and visa-versa, and/or fed them onto my MFT (I use the old profile on my bench with 2 meter rails). The panel cart would also of course be height adjustable, handle multiple sheets, have locking wheels actuated by a single stomp down pedal, also adapt to hauling a mess of systainers into a job, and maybe even work as its own cut table or Kapex stand. Oh yeah, and when not in use it would fold up and store in a Systainer I.  Wink
The impact driver would be awesome. I brutalized my little Bosch LiOn compact for several years before finally wearing it out. It's repairable but a new one costs about the same and my Festool cordless drills do just about everything else that it did just as well...just a few spots where the impact is still a nice go to. The Rigid Rt. Angle junk I burned up two in the same day, (never, ever, never would I ever buy another tool of theirs). Something of Festool quality w/ the Bosch size and function and nothing in common w/ the Rigid.
A larger adjustable bed for the 850 planer to convert it to a portable joiner. Some mechanism for thickness planing would also be trick.
The mini CNC idea is cool, but I tremble at the thought of the price.
How about a band saw. Since ditching my table saw and going all Festool in my new closet sized shop, my Mini Max, thickness plane, joiner, drill presses and lathe are the non-Festool gear I have left other than some sanding equipment. Festool needs to get on the ball or send me some friggin' green paint. Smiley
What about a Systainer based HVLP finishing system?
A larger dust evac system that would adapt to a central design? (or handle my planer)
A portable dust collector/air cleaner for the airborne bits that aren't already gathered up.
A lay flat tape measure with metric/std. markings.
Something smarter than the pocket multi-tool torx/hex set (it always makes me curse).
A combo square set like my Starretts', but something that won't make my heart stop if it gets dropped or knocked on the floor.
How about a multi-spindled head that would allow my 2200 to drill five or seven shelf pin holes at once instead of one at a time with the 1010.
A hard case for storing/transporting guide rails.
An offset base to trim right up to a wall, and a seaming base for the 700 so I can sell my old Bosch installers kit.
Low draw LED flashlights that use existing batteries (this is my personal crusade - all manufacturers should be forced to adopt a standard battery and stick with it for the next decade - this battery scam is drivin' me the short distance that I had left to be totally nuts). The flash light could extend  and articulate, and have a couple of different attachment bases (magnetic, clamping, etc.) that would allow it to be used on a tool or rooting around the back of a dark work truck.
How about a convertible step ladder/stool/work stand that folds and fits with the Systainers?
Modular half height Sysports that could integrate with the Basic System modules and maybe different MFT profile rails to create custom benches/work areas. Work areas could be tied together to allow pieces to slide from station to station (alright maybe that's a little out there).
Systainer job site sound system w/ multi-charger, I-Pod dock, power distribution w/ GFCI, etc.
Panel/box clamping system that allows stacking multiple glue-ups and efficient clamp storage.
Sell the articulating arms here in the States (as long as you bring the belt sander).
O.K., that's about enough fantasizing. Back to reality. My local dealer had none of the vacuum or jig saw accessories that I needed yesterday, so it's back to making due with something less.
Tomorrow's project...adapting a Kegorator to work with my Systainers.
Oh yeah...I did read somebody's idea about an over arm or overhead type router. How about some kind of improved radial arm saw type set up?
Maybe it's time to start building Gibbets in front our rulers' castles? Perhaps they'd get the hint.
sancho57
Offline Offline
« Reply #257 on: March 28, 2011, 11:31 PM »
How about a systainer insert for the kreg jig?Huh??
SRSemenza
Global Moderator
Offline Offline
« Reply #258 on: March 29, 2011, 12:30 AM »
[/quote]
Wow , big list !!
The smaller add on Sysports already exist. You will just have to put up with Tanos color instead of Festool color.
http://www.systainerworld.com/Tanos_Small_lockable_Systainer_strongbox_empty_wi_p/115-004.htm
The MFT profiles used to be available in a longer length for the older version.
I thought ProTool , Festool sister tool company made impact drivers but I can't seem to find a pic. NAINA (Not Available In North America)
ProTool also makes a flashlight that works with Festool batteries. Not sure about NiCd / LiOn versions. NAINA
http://festoolownersgroup.com/festool-tools-accessories/new-protool-torch-that-uses-festool-batteries/
A lay flat tape would be a good promo item.
A hard case for rails would be nice. What I really wish is for a Mafell type roll up guide rail , because it fits in a regular Systainer.
Do a search on here for ..  systainer radio... you will find a bunch of nicely done conversions.
Hope that helps.
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
tiudic
Offline Offline
« Reply #259 on: March 30, 2011, 01:41 AM »
a systainer  air compresor...i am not kidding...everybody who owns festool is gonna buy...this guys are pros and they use pin nailers and they will not come cordless soon(at a respectable quality)...the brad nailers i already have them cordless in systainers,i would ...please make one...honestly i wish festool made all tools..but this is a must
tiudic
Offline Offline
« Reply #260 on: March 30, 2011, 01:51 AM »
i broke many compresors not buy using them but transporting them (porter and cable red pancake ones)...so please a compresor in systainer even if it is sys V Tlock Wink
Mettes
Online Online
« Reply #261 on: March 30, 2011, 02:01 AM »
All you have to do is ask, it's not Festool but it's a compressor in a Systainer.
Prebena Aerotainer 200
jmbfestool
Offline Offline
« Reply #262 on: March 30, 2011, 06:52 AM »
I have looked at them for a while! now been very tempted to buy one.  I have managed to stop my self!  1. cus my current batterie nailer still works so why replace something which still works 2. I cant seem to find a angle brad for that system only a first fix 1.  I dont like straight they always restrict me where I can nail.   I have asked the company if they will be making them in T-locs I am awaiting a reply.
JMB
woodguy7
Offline Offline
« Reply #263 on: March 30, 2011, 09:56 AM »
Something like this ?
http://www.axminster.co.uk/axminster-axminster-da65-angle-finish-nailer-prod21881/
Shirt size medium
jmbfestool
Offline Offline
« Reply #264 on: March 30, 2011, 11:48 AM »
Noooo silly!    For the Airosystainer!  The free air guns.  lol  I know you can get angled air guns attached to the compressor but I mean the hose less ones with a compress canister I cnt find n angled one.
JMB
MTRANGER
Offline Offline
« Reply #265 on: March 30, 2011, 01:07 PM »
I wish festool made the of1400 with the same design as the of2200
Shane
Size XXXL
jonny round boy
Offline Offline
« Reply #266 on: March 30, 2011, 03:36 PM »
...cus my current batterie nailer still works so why replace something which still works...
OK, who are you, and what have you done with JMB? Scared
 Tongue Out
Mavrik
Online Online
« Reply #267 on: March 30, 2011, 03:46 PM »
I have a 1010.
Touched an of1400 for the 1st time on Saturday.
Oooohh ... I liked it
TS55, MFT 1080, PS300, EHL 65, Domino, OF 1010, CTL 22, RO 125, BS75
jmbfestool
Offline Offline
« Reply #268 on: March 30, 2011, 04:02 PM »
 Tongue Out
Yes who wrote that? That does not sound like me! Some one must of logged into my account.  They also did a few bad spellings and grammer to make it more believable lol Tongue Out
JMB
Mac
Offline Offline
A Scotsman living abroad
« Reply #269 on: March 30, 2011, 04:52 PM »
JMB
HAHA, I loved this! Brilliant, JMB  Big Grin Thumbs Up
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 ... 21  All   Go Up
  Print
Jump to:
