Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21  All   Go Down
  Print
Author Topic: Fill in the blank: I wish Festool made a ______!  (Read 98731 times)
0 Members and 11 Guests are viewing this topic.
RL
Offline Offline
« Reply #330 on: September 16, 2011, 10:47 AM »
...systainer for all the various bits that go with the OF1400. Bases, edge guides, copy rings, feet, wrench etc. I know most of it fits into the original systainer but a lot does not, and I am tired of everything knocking around and having to empty it all out to reach the wrench etc.
Rant over.
I think I will make myself a French fitting drawer in the bottom of another systainer in the meantime.
I like green.
jonny round boy
Online Online
« Reply #331 on: September 16, 2011, 11:15 AM »
What's that then? Never heard of a 'French fitting drawer'...  Huh?
RL
Offline Offline
« Reply #332 on: September 16, 2011, 11:42 AM »
It's basically where the drawer bottom has an insert which is moulded round all the tools, just like the plastic systainer inserts. It can be made from cork, MDF, etc.
You see them a lot in cutlery sideboards, or gun cases, musical instrument cases etc.
I like green.
woodguy7
Offline Offline
« Reply #333 on: September 16, 2011, 12:16 PM »
Ive never heard it called that either !
Shirt size medium
VictorL
Offline Offline
« Reply #334 on: September 16, 2011, 01:36 PM »
Rant over.
There was SE-KB-SYS systainer package. It's discountinued now. I'm trying to find it without any luck Sad .
http://www.mcfeelys.com/product/489433/Systainer-Foam-Insert-for-Edge-Trimming-Accessories
VictorL
RL
Offline Offline
« Reply #335 on: September 16, 2011, 03:02 PM »
That's basically what I ended up using, but I used the foam insert set.
http://www.festoolcanada.com/products/systainers/foam-inserts/foam-insert-set-487427.html
I used it a couple of years ago to pack some precision tools, and happened to keep all the little squares! I wish festool came out with the 1400 equivalent of the 2200 accessory systainer.
I like green.
NoBreyner
Offline Offline
« Reply #336 on: October 10, 2011, 07:50 AM »
A Festool benchtop tablesaw
EWTHeckman
Offline Offline
« Reply #337 on: October 10, 2011, 10:49 AM »
I wish Festool made a chuck like the Centrotech chuck for 1/4" hex quick connect bits.
Ed "What the" Heckman
Alan m
Online Online
« Reply #338 on: October 10, 2011, 01:14 PM »
not sure i follow what you mean
now
wish list
Ken Nagrod
Restricted
Offline Offline
« Reply #339 on: October 10, 2011, 01:34 PM »
He wants a Centrotec style chuck that will accept standard 1/4" shank hex bits without having to use an adapter.
EWTHeckman
Offline Offline
« Reply #340 on: October 10, 2011, 02:59 PM »
Exactly…
greg mann
Offline Offline
« Reply #341 on: October 10, 2011, 03:24 PM »
Standard hex bits are not made to an accurate enough tolerance, and have no standard beyond the hex. The centrotec relies on a closely held diameter that is slightly smaller than the standard hex bit, which has no diameter specification, just a resulting size across the points. These vary from one manufacturer to another. Festool solved the problem by holding a diameter across the points that extends beyond the hex length, giving them a true running shank. They also changed the detent groove position. All of this was intentional, I would guess, but not to necessarily make it proprietary. I suspect it was their way of improving on a concept that certainly had room for improvement. If they had designed the chuck to hold any traditional hex bit it would have needed a far more open tolerance factored-in to accommodate all of the variability in the market. At that point there would have been an unnacceptable amount of runout in many cases and they would have been accused of making a subpar tool when it was the inherent variability of the bits for which they could not compensate.
Greg Mann
Oakland, Michigan
jtwood
Offline Offline
« Reply #342 on: October 10, 2011, 09:27 PM »
Probably has been mentioned here before, but...
A Domino that has a switch to allow just a straight, round hole for inserting a dowel, as well as being able to cut a mortise.
Some places are just too small for a domino to fit, where a 1/4" dowel is perfect.
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #343 on: October 10, 2011, 10:08 PM »
An upgraded (Benz quality) gate and cord connector to split from one-to-two hoses w/ cords.
« Last Edit: October 11, 2011, 12:15 AM by Tom Bellemare » Logged
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
GPowers
Offline Offline
Metric convert
WWW
« Reply #344 on: October 10, 2011, 10:15 PM »
A upgraded (Benz quality) gate and cord connector to split from one-to-two hoses w/ cords.
This would be great. I already have two hoses on my boom arm, but swapping the hose back a forth is a real PITA.
« Last Edit: October 11, 2011, 07:52 PM by GPowers » Logged
Greg Powers
RL
Offline Offline
« Reply #345 on: October 11, 2011, 12:09 AM »
A drill?
I like green.
jtwood
Offline Offline
« Reply #346 on: October 12, 2011, 05:19 PM »
Yes, to drill a straight hole instead of a wide mortise.  In other words, make the side-to-side motion switchable.  Side to side for mortises, straight -line for dowels.  The ease of lining up holes would make it possible to replace a doweling jig.
EWTHeckman
Offline Offline
« Reply #347 on: October 13, 2011, 01:26 PM »
I can see more precise tolerances being helpful for drilling. Though in my experience, the biggest accuracy problems in drilling come from the hand holding the drill, not the bit setup. For driving screws, I don't see any problems with the hex tolerances. Festool apparently has no problems using that hex for the main connector to the drill. They even advertise using that connector to put a short hex bit in it. Why not use that exact size for a Centrotec style chuck?
As I've been evaluating the Festool drills, there are a couple of issues that come up.
First, I already have a significant investment in hex bits. That means I need to either toss that investment, or continue to use them with the Jacobs chuck on the Festool, which removes one of the significant advantages of those drills.
Second, some bits just aren't available in Centrotec. A prime example is the square drive bits. As with the hex bits, I have a significant stock of square drive screws. I need a bit for those, and being able to use a short chuck can be a significant advantage when space is tight.
Third, I know a short bit can be attached directly to the drive out of the drill. I hate using those things because after driving a screw in, I usually have to take the bit out of the screw and put it back in the drill.
The first two of these issues are ones which keep popping up on this board. In my mind, that means Festool ought to address them one way or another. After all, we've already seen one solution to these issues that isn't far from using duct tape.
I'm pretty sure Festool could even come up with some sort of solution to the tolerance issues in a chuck. (Maybe an internal rotating collar or other mechanism that clamps the bit to remove the slack as it's locked into place?) Even if it was slightly larger than the Centrotec chuck, it would still be a much better solution than using a binder clip.
zapdafish
Offline Offline
« Reply #348 on: October 13, 2011, 07:22 PM »
lawn mower  Big Grin
Mine died and have been browsing Amazon.com for a cordless one  Grin
Ken Nagrod
Restricted
Offline Offline
« Reply #349 on: October 13, 2011, 07:56 PM »
lawn mower  Big Grin
I can't help you with a cordless one, but, depending on the cutting path size you're looking for, mount two TS55's sideways or two TS75's sideways, to your old mower deck (fabrication and design I'll leave for you).  Attach them with a 'Y' connector to a CT and cut your lawn without leaving a green mess.
P.S. - You'll probably want a helper to move the CT while you're cutting unless the mower deck can accomodate everything.
Tom Bellemare
Festool Dealer
Offline Offline
WWW
« Reply #350 on: October 13, 2011, 10:38 PM »
The CT's 26, 36, & 48 can be pulled evenly behind by their hoses...
Tom Bellemare
Customer Svc
Tool Home
www.tool-home.com
512-428-9140
PeterK
Offline Offline
« Reply #351 on: October 14, 2011, 09:07 AM »
To answer zapdafish----
For a modest amount of money Smiley you can fly over to EU and get a pair of battery operated Carvexes. They probably sell some super long blades there as well. Mount them back to back on a wheeled stand and voila a battery operated Festool mower! Be sure to get the vegetation blades. Wink
Oh and mount the new CT 48 to get maximum collection capacity.
For me, I don't want anything new from Festool. I only want what they already sell in the EU!!!!!!
CutsTwice
Offline Offline
Crazy Cabinet Monkey
« Reply #352 on: November 01, 2011, 12:13 PM »
I would really like an imperial set of the new forester bits. I usually use them for doing radius cutouts in templates, so metric doesn't work for me. Are there any plans on making a set some day?
Life is an endless, toiled endeavor... yet tonight, I yearn for rest.
GhostFist
Offline Offline
« Reply #353 on: November 01, 2011, 07:39 PM »
How about a portable thickness planer?Huh? Bet Festool could whip up something amazing.
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #354 on: November 01, 2011, 08:35 PM »
Where have you been, they're working on it.  Didn't you see the leaked rendering images?
VictorL
Offline Offline
« Reply #355 on: November 01, 2011, 09:08 PM »
Festool makes metric bushings (copy rings). Switch to metric Smiley
VictorL
SteveC
Offline Offline
« Reply #356 on: November 08, 2011, 09:15 PM »
How about hose by the foot (or meter) ?
I've been reading that a shorter hose improves Kapex dust collection and would rather buy
a short piece and ends rather than chop my 3.5m - 36mm.
SteveC
Peter Halle
Global Moderator
Online Online
WWW
« Reply #357 on: November 08, 2011, 09:36 PM »
Some dealers will do what you ask.  I think that I read here that Bob Marino has done something similar.  You might want to send him a message.
Alex
Offline Offline
« Reply #358 on: November 08, 2011, 09:44 PM »
In Europe we can buy hoses by the meter. Is that not offered in the USA?
TomLewis
Offline Offline
« Reply #359 on: November 08, 2011, 09:59 PM »
Agreed. Though I do like brousing through German tool stores...
Festools ---
AT65 EB/1 Plus plunge saw
OF1000 EB/1 Plus router
OF2000 E/1 Plus router
CT33E dust collector with hose garage
D36 UNI-RS-Plus dust collector kit
RO125 FEQ-Plus sander
T15+3 Li2,6 Set cordless drill
MFT/3 table
5 tracks, both FS and FS/2 versions
parallel guides, extentions, misc clamps and accessories
Centrotec Installers Kit
Festool tape measure, beer mug and watch!
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21  All   Go Up
  Print
Jump to:
