Pages: 1 ... 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21  All   Go Down
  Print
Author Topic: Fill in the blank: I wish Festool made a ______!  (Read 99313 times)
Tom Gensmer
Offline Offline
Residential Remodeler in Minnesota
« Reply #390 on: February 06, 2012, 01:48 AM »
... made a module so I could turn my cordless drill into a corded one, and it would also work on the carvex when it is released in the US.
C15/18 impact driver
and a hammer drill.
DeWalt used to offer an adapter like this for their old 24v NiCad line. I was told it was for rescue crews, one guy would run out with his cordless 24v recip saw and start cutting, while another would get a generator or inverter running and start stringing extension cord.
Kapex, CT-26, CT-Midi, RO-150, RO-90, OF-1400, EHL-65, DTS-400, Domino (WITH PINS!!), MFT/3, Sprinter full of Systainers
bonesbr549
Offline Offline
I'd rather be woodworking
« Reply #391 on: February 06, 2012, 10:24 AM »
Oscilating spindle sander.  I know the DC would be great.
andvari
Offline Offline
« Reply #392 on: February 06, 2012, 11:02 AM »
A universal locking chuck for the drills - accepting Centrotec, wire detent and ball detent bits.
Jesse Cloud
Offline Offline
Festooling at the end of a dirt road in New Mexico
« Reply #393 on: February 06, 2012, 11:28 AM »
+1 on this.  There are two levels out there: 1)"darn near trash" that sells for $100 or so at the big boxes and 2)industrial models that sell for $1,000 or so from the big boys.   I think there is a good market here for something in the middle!
Nick C
Offline Offline
« Reply #394 on: February 06, 2012, 11:42 PM »
Rubber or soft plastic clamp pads to slip over the metal clamping arm on the Festool standard and quick-release clamps. Then they wold be more useful for general light-duty clamping tasks. Although the clamping foot is padded, it's not always possible to orient the clamp so that the padded foot is on the finish surface, owing to interference from the clamp screw. For exmple, when clamping a workpiece to a drill press table, the only practical orientation is to have the clamping foot under the table, which puts the unpadded arm on top, in contact with the workpiece.
ART at WORK
Offline Offline
Buy less Recycle more
« Reply #395 on: February 07, 2012, 08:09 PM »
Nice idea,
I remember seeing someone suggesting a length of plastic tubing to slip on to the metal arm for this purpose.
A quick and cheep solution. Festool would probably charge 15 bucks a go.
Kapex 120 + UG Set, ETS 150/3, DF 500, RO 90, MFT/3, CTL 36 AC, RO 150, 0F 900, CDD 12, TS 55, A5 Router table, First Aid kit, LR 32 SYS, FS 800, FS 1400, FS 1400 LR32, CTL Midi + Cleaning Set, Clamps, Parallel Guides, Centrotec drills, Zobo Forstner set and countersinks, Routers, Systainers, Sys Cart,
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #396 on: February 07, 2012, 09:23 PM »
Nice idea,
I'm someone. Tongue Out
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #397 on: February 07, 2012, 09:27 PM »
Nice idea,
Hey someone!
Welcome to the FOG  Poke
jacko9
Offline Offline
« Reply #398 on: February 08, 2012, 09:37 PM »
I wish that Festool would make a sander with the capability to use different diameter sanding heads from the small RO 90 3.5 inch right up to the 6 inch diameter of the larger machines.  A universal sander with a variable speed motor to provide the ideal sanding speed for the size head selected.
Kev
Offline Offline
« Reply #399 on: February 09, 2012, 02:16 AM »
How about a CT unit with the boom arm support telescoping up out of the chassis itself. 4 telescoping sections on a CT36 chassis should do it. Vacuum and power in the tube. Short head piece (say 30cm) so that you wouldn't need a clumsy outer frame for support. Then you'd only need a short hose and a short pluggit at your table (say 2m).
Another potential ... Alter the WCR so that one of the supports is a hollow boom arm ...
I love Festool and I'd like some overhead Vac capability (needs to be mobile for my workspace) - but I look at the Ikea quality tubing exoskeleton and inwardly groan. C'mon Festool - you can too so much better that that clumsy boom arm. I know it fits a couple of different model Vacs and you can still snug the Vac under the bench ... but I just saw a picture of one of the forum members with a CT and boom arm in the back of his truck and thought "YUCK".
jmbfestool
Offline Offline
« Reply #400 on: February 10, 2012, 11:14 AM »
Just been cutting some Oak piece with my TS75!    Well I have had to clamp the rail not using the tracks  just clamp the down like a you would if it was just a sheet of metal!   This was because the rail over hung the oak piece and so the tracks where the clamps go normally where useless!     Untill recently due to a FOG post I found out Maffel guide rails have a track closer to the splinter guard where your clamps can go!
Well I wish Festool did the same thing or better because that would be a very usefull feature especially for this job I am on now!  AND many jobs I have done and jobs in the future hopefully will be doing!
JMB
Ken Nagrod
Restricted
Offline Offline
« Reply #401 on: February 10, 2012, 11:17 AM »
JMB
I agree.  I've had that issue too.
Nigel
Offline Offline
« Reply #402 on: February 10, 2012, 11:23 AM »
Yep,can be right pain in the rear that.
Alan m
Offline Offline
« Reply #403 on: February 10, 2012, 03:13 PM »
im sure some kind of bracket could be made up . if there was a L shaped piece sticking down  with another L shaped piece going back under the timber. then clamp the end of the second L piece to the timber
now
wish list
jacko9
Offline Offline
« Reply #404 on: February 11, 2012, 12:01 AM »
I posted this on our Facebook fan page recently and there were a lot of responses.
Obviously, we've had many threads here with various "wishes" but in a word or two, let's hear what you wish Festool would offer that it currently doesn't.
PS - Please keep it clean.  Embarassed
Shane,
My son is a construction foreman in California and right now they are building three hospitals.  The inspectors are adamant about there being no dust in the holes that they drill for anchors and if Festool could provide a Rotary hammer drill with dust collection they would sell a whole lot of them to the construction trade.  I envision a drill with a sleeve that goes around the drill bit and retracts into the drill body as the drill bit progresses into the concrete.  A dust system could be around the drill flutes inside this sleeve.  It would take some engineering but, the payoff would be very lucrative.
Jack
Ken Nagrod
Restricted
Offline Offline
« Reply #405 on: February 11, 2012, 12:47 AM »
Jack,
Protool is the division that handles hammer drills/rotary hammers in the Festool family.  Let Festool know that you would like to see some of the Protool construction tools here.
Nigel
Offline Offline
« Reply #406 on: February 11, 2012, 02:18 AM »
Shane,
Jack
Like these?
http://sdsdrillexpert.co.uk/drills/metabo-bhe201dr-110v
jmbfestool
Offline Offline
« Reply #407 on: February 11, 2012, 08:53 AM »
Yes!  but your thinking like a Workshop joiner again!   Gotta think like a site joiner!   Dont want to be carrying jigs around OR making up jigs  if festool can just make a rail which avoid this problem that would be great!   But yes your solution would work!
JMB
Brice Burrell
Offline Offline
WWW
« Reply #408 on: February 11, 2012, 09:24 AM »
Jack,
I'd like to see some Protool construction tools here.  How's that Ken.  The drills, grinders, cordless correlated screw gun and that's just off the top of my head.
Ken Nagrod
Restricted
Offline Offline
« Reply #409 on: February 11, 2012, 10:26 AM »
Not enough, Brice.  Say it with more feeeeeeling.  Groveling may help.  I think you should do a video.
zapdafish
Offline Offline
« Reply #410 on: February 11, 2012, 01:34 PM »
laser cross hairs built into the base of the routers so I know exactly where to plunge. I've used lines to center the base but it still takes time to get everything just so.
Brice Burrell
Offline Offline
WWW
« Reply #411 on: February 11, 2012, 01:48 PM »
Ken, I was groveling when I had the big man's ear last summer. Big Grin
ART at WORK
Offline Offline
« Reply #412 on: February 17, 2012, 07:19 PM »
I was looking at the 3 M Ear Protectors with built in Radio the other day and thinking, Everything is going digital soon here in Germany in Britain its already digital as far as I know.
So I will just have to wait till I can get a Digital version.
So Festool I would like better Ear Protection lighter in weight, less noise getting through, and a digital radio receiver, WiFi,
MP3 etc.
Even a model with built in Eye Protection, like those Australian Eye Muffs - (can one say muff on here)
http://www.eyemuffs.com/
This year would be a good launch date please
Peter Halle
Global Moderator
Offline Offline
WWW
« Reply #413 on: February 17, 2012, 08:13 PM »
[ ERROR: SPECIFIED ATTACHMENT MISSING ]
MP3 etc.
They could even have a subliminal message that plays.  No.  never mind.  We as FOG members send out that message all over the world every day.   Big Grin
For those who get here thru a search engine, this was in jest.
« Last Edit: February 17, 2012, 08:15 PM by Peter Halle » Logged
woodguy7
Online Online
« Reply #414 on: February 18, 2012, 11:24 AM »
Anybody know if those eye muffs are available in the UK ?
Shirt size medium
GPowers
Offline Offline
Metric convert
WWW
« Reply #415 on: February 18, 2012, 08:15 PM »
they were designed by and australian company
Greg Powers
Alan m
Offline Offline
« Reply #416 on: February 18, 2012, 08:17 PM »
im sure you could find one of your family or friends  etc that has moved there to send you one.
now
wish list
Kev
Offline Offline
« Reply #417 on: February 18, 2012, 09:18 PM »
I haven't tried to get any myself, but I'm in Sydney ... so if push comes to shove I can give them a call and see if I can organise a price + shipping deal for FOG members.
Let me know guys.
harry_
Offline Offline
« Reply #418 on: February 18, 2012, 11:39 PM »
I know of at least 5 various tradesmen that were sold on the cordless drills until they were told that there was no matching cordless reciprocating saw. The guys just don't want to add another flavor of battery/chargers to their kit. I have a 18V Bosch cordless and it is a beautiful tool for what it is. Is it the tool for all day long demo work? Certainly not. But it is great for when it will take longer to string the cord than cut the hole type stuff.
As for myself, along with seeing a cordless version, I would like to see a corded one. One designed from the ground with dust collection in mind AND a headlight! It seems that 1/2 the time I use a reciprocating saw it is over my head and I just LOVE the way the dust rains down on me and everything else.
This business of "Festool won't introduce a tool unless they can make it 7 ways better" seems ludicrous in the case of a reciprocating saw as I am sure that Festool could:
1) make one more ergonomic.
2) better power to weight ratio
3) better balanced
4) WITH DUST COLLECTION
5) with a blade holder mechanism that doesn't seize, jam or otherwise act retarded
6) comes in Festool green
7) that doesn't crap out after a few uses.
So there's 7  Tongue Out
If the folks at Festool can't make a better reciprocating saw than what's already out there, then I think their engineers are over-rated and lack imagination. Since we all know that the latter is not the case............
And I really think NA is a vast untapped market for the Protool line-up. If Germany doesn't think so then they are selling themselves short.  There is a funny phenomenon with Festools as one tool in the line-up sells yet another and another. I believe the same would be true for Protool line.
Steve R
Offline Offline
« Reply #419 on: February 18, 2012, 11:54 PM »
3) better balanced
Harry,
I like your thinking.
Cheers
Steve
Pages: 1 ... 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21  All   Go Up
  Print
Jump to:
