Author Topic: Fill in the blank: I wish Festool made a ______!  (Read 441418 times)
Offline Goz
Re: Fill in the blank: I wish Festool made a ______!
« Reply #990 on: November 17, 2016, 10:56 AM »
NAINA = not available in North America
Sent from my SM-G930R4 using Tapatalk
Offline zapdafish
« Reply #991 on: November 17, 2016, 10:57 AM »
This coffee maker should be in a systainer.
Offline Dovetail65
« Reply #992 on: November 21, 2016, 05:37 PM »
I would gladly allow the CT SYS to be 3" taller if it has a retractable CORD AND HOSE.
From the design it appears I could make a retractable cord and add nothing to the size, this should of been the design from the start.
Again, I would gladly allow the unit to be  3" taller if they could find a way to make the hose retractable, heck maybe even 6" because as it is that space is used with the hose and cord flopping around on top anyhow because I don't have time to  wrap it up neatly. I just let cord and hose sit on top any old way.
Offline HarveyWildes
« Reply #993 on: December 16, 2016, 08:48 AM »
Granat sandpaper for the DTS 400 in grits > 400.  Does anyone know if any third parties make such a thing?  Klingspor maybe?
Offline pixelated
« Reply #994 on: December 16, 2016, 01:11 PM »
Spiff, even worse it would probably be NAINA  [mad]
Okay, I'll bite - what's a NAINA?  [smile]
Not Available In North America.
Offline Mort
  • World's Tallest Midget
« Reply #995 on: January 13, 2017, 06:20 PM »
In lieu of a full line of small tools running off the CXS/TXS batteries, how about just a flashlight? Also, a redesigned systainer insert so you can store it with your drill.
Please and thank you.
I hate signatures.
Offline stoufferc
Re: Fill in the blank: I wish Festool made a Dado Track Saw
« Reply #996 on: March 06, 2017, 08:28 AM »
My idea is simple.  Make a circular saw that is specifically designed to cut dados and would ride on a track.  The saw could be equipped with a 6" Fraud Dial A Dado type blade and would only have to cut up to an inch deep.  The dado track saw would be used to cut perfect dados anywhere and to any length your track will allow.  Having a dial a dado type blade would allow the perfect fit to any thickness material or plywood.  Yes a router can be used to cut dados and I have used that process but a circular blade that scores the veneer with the outer teeth would leave a cleaner cut and would cut faster and could be completed in one pass.  Yes router bits come in undersized plywood thickness but they are never perfect. And yes you can make two passes with a smaller router bit and a jig.  I'm just saying that a track saw equipped with a blade make specifically for cutting dados would be really really cool!
Thoughts?
Craig
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #997 on: March 06, 2017, 09:58 AM »
Thoughts?
Craig
The HK85 will do your dados with the optional groove cutter.
Offline DrD
  • I might not be fast BUT I sure am slow
« Reply #998 on: March 06, 2017, 10:22 AM »
Is the HK 85 with dado and optional groove cutter available in the USA?
DrD
KS12 EB Kapex with Delta Folding Table & FastCap Best Fence; TS75 EQ with Parallel Guide Rail Set (FS-PA 495717 & FS-PA-VL 495718) and FS 800/2, 1080/2, 1400/2 LR32, 1400/2, 1900/2 Guide Rails, and Betterly SLC23 Straight Line Connector; DF500 Q with Assortment Systainer; OF1010 EQ with Fine Adjuster for Guide Stop, WA-OF Angle Arm, UP-OF Edging Plate and SF-OF Chip Deflector (486242); OF1400 EQ with OF1400 Dust Hood x 2, OF 1400  Edge Guide x 2, OF 1400  Guide Stop; LR32 Set; PSB399 EQ; EHL65 E; RAS115.04 E; RS2 E; ETS150/3 EQ; RO150 FEQ; Hand Sanding Block Set; CT26 with assortment of AS and Non-AS Hoses; MFT/3 Table x2; SysLite; Assortment of Quick & Screw Clamps, Consumables, Dogs.
Offline Gordon Bombay
« Reply #999 on: March 06, 2017, 10:28 AM »
Belt sander that was available in NA.
I do a lot of tabletops, and would really like the belt sander available here.
MFT; CT Midi; ETS 150/5; Domino 500; Kapex; TS55
@YetmansGallery
Offline Holmz
« Reply #1000 on: March 07, 2017, 04:27 AM »
Not a lot of options for decent belt sanders, so I am with you conceptually.
There is always the 110v->230v transformer... and then you use a Euro version.
Offline drdabrown
« Reply #1001 on: March 17, 2017, 09:12 PM »
Why doesn't Festool make an accurate square that could be used to set up their MFT instead of having to depend on Woodpecker bringing back their MFT one-time-tool square someday?
TS55, KAPEX 120, RO90, RO125, ETS 150/3,RTS400, LS130, RS2, Carvex PS420, PS300, CT MIDI, CT26, CT33, TXS, CXS, C12, T18+3, DOMINO DF500, HL850, MFK70, OF1010, OF1400, MFT/3, MFT/3 Mini, LR32, SYSLITE
Offline Gregor
« Reply #1002 on: March 18, 2017, 10:32 AM »
It exists, it's called MFS 700.
Offline JakobProgsch
« Reply #1003 on: March 18, 2017, 10:23 PM »
I wish Festool made a very short plug-it cable for the CMS.
Offline bkharman
« Reply #1004 on: March 18, 2017, 11:56 PM »
+1
Also, I wish that the CMS had aluminum router rings held in place with magnets.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline Dundee99
« Reply #1005 on: April 17, 2017, 03:07 AM »
I am not an expert on plastics, but a 'sys-chem'...
A systainer, and set of bottles to fit inside, made of plastic to resist all heavy chemicals eg metho, turps, thinners, brake cleaner and the like! Any spilling could be contained.
Offline Bob D.
« Reply #1006 on: April 17, 2017, 05:47 AM »
If they make a belt sander include a frame like the one on the DeWalt DW433 which is great for
controlling the aggressiveness of a belt sander and helps to ensure a flat surface.
Offline pstout11
  • Stout Woodwork & Design LLC
Re: Fill in the blank: I wish Festool made a ___pneumatic nailer!
« Reply #1007 on: June 11, 2017, 03:52 AM »
I posted this on our Facebook fan page recently and there were a lot of responses.
Obviously, we've had many threads here with various "wishes" but in a word or two, let's hear what you wish Festool would offer that it currently doesn't.
PS - Please keep it clean.  [embarassed]
Offline Bob D.
« Reply #1008 on: June 11, 2017, 06:58 AM »
DrD
I wish it was.
Offline DTSaskatoon
« Reply #1009 on: June 26, 2017, 03:35 AM »
I wish my new Festool Syslight Duo had a small bracket with a cylinder to fit the light that I could mount to the wall (or shelf) of my garage. I have the tripod but I'd rather store the light on a permanent mount so I can use it and leave the tripod folded up and stored away. I suppose that I could build something but it would be so much better if it was an accessory. Ive seen some online reviewers mounting their lights in a way that is clearly in conflict with the instruction manual warnings. Thanks for considering my request...
Offline LooseSox
« Reply #1010 on: June 26, 2017, 04:32 AM »
Thoughts?
Craig
Seeing dado stacks aren't exactly legal in most parts of Europe, will never happen from any Euro tool company. Not to mention the inertia of a dado stack is somewhat higher than a normal blade, I wouldn't want a hand held version in the event of kickback
Offline Bob D.
« Reply #1011 on: June 26, 2017, 05:05 AM »
Thoughts?
Craig
You mean the HK85 will be discontinued and not be available in Europe? I was hoping it would appear in the USA.
« Last Edit: June 26, 2017, 05:15 AM by Bob D. »
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #1012 on: June 26, 2017, 09:36 AM »
If I'm not mistaken Tyler already said the HK85 will not be coming to N. America.
Offline antss
« Reply #1013 on: June 26, 2017, 09:48 AM »
HK85 doesn't take a standard dado blade.  It will only work with Festools grooving unit.
And it's not a big seller.
Offline Bob D.
« Reply #1014 on: June 26, 2017, 04:45 PM »
That's a shame since there is nothing like that here. I don't care if it's a grooving unit or a dado blade as long as it can cut a dado or rabbit while guided by a track. Actually I like the grooving unit better than a dado setup.
Offline antss
« Reply #1015 on: June 26, 2017, 05:08 PM »
It's pretty much just a proprietary dado balde in a housing that couples to the saw.
If you really want one, you'll need to look into importing it. Chances are slim to none that FT brings it stateside.
BTW, there is no 110v version available.
« Last Edit: June 26, 2017, 05:15 PM by antss »
Offline Holmz
« Reply #1016 on: June 26, 2017, 05:40 PM »
That does not stop people from complaining.
We all know that anyone can get the tool imported in 230v and use a transformer... But many hold onto a fairy tail belief that somehow a limited number of 110v tools will get the UL approval process to make sense. That will not happen.
Offline Svar
« Reply #1017 on: June 26, 2017, 06:11 PM »
Mafell sells their 120V 2200W KSP85 in the US through an authorized dealer. So, either UL approval is a) optional, or b) not that difficult to get. Regardless, it's a marketing decision which has little to do with the UL.
Offline antss
« Reply #1018 on: June 26, 2017, 10:03 PM »
UL approval is not difficult to obtain.
It is costly.
And when amortized over a product that has little sales potential it becomes a non - starter.
Offline kdzito
« Reply #1019 on: June 26, 2017, 11:53 PM »
It's probably already been said in this thread but a cordless trim router like Ridgid's!
Building one day at a time.
