Author Topic: Fill in the blank: I wish Festool made a ______!  (Read 469916 times)
Offline Bob D.
Re: Fill in the blank: I wish Festool made a ______!
« Reply #1020 on: June 27, 2017, 08:41 AM »
"That does not stop people from complaining."
Is complaining the correct term? Maybe desire
or want or request would better describe their
request for such a tool compatible with the
power available in their country or region.
Offline Holmz
« Reply #1021 on: June 27, 2017, 07:49 PM »
Well I suppose it is in the ears of the beholder.
When NAINA is mentioned the tone is often toward frustration rather than hope.
If they were actually complaining, then their countenance could be made glowing with a transformer.
While that is a good solution to fix the issue of power, it is not the solution that they want, and often results in a further sourness upon their countenance.
The obvious long term solution is to head to DC brushless motors. Either batteries or a transformer that goes into a DC slot from the wall.
If they can buy a similar tool that does the required task, but do it like the colour or cost, then they are truly complaining.
Offline Naildrivingman
« Reply #1022 on: August 13, 2017, 08:41 AM »
Nothing new!  I'm going broke!
Dance with who brung ya...
Offline Woodwork Wizard
« Reply #1023 on: August 13, 2017, 12:53 PM »
I wish Festool made splinter guard tape that stayed stuck to the guide rail. Makita can.
Offline pettyconstruction
« Reply #1024 on: August 13, 2017, 02:13 PM »
I , like a lot of people here,went with the  Makita splinter guard. Works better
Charlie
Sent from my iPhone using Tapatalk Pro
Offline Dovetail65
« Reply #1025 on: August 13, 2017, 10:28 PM »
I wish Festool made upgraded routers.
It's time to update the complete line of routers. They all need LED rings, Festool should come out with the best LED lighting system made for routers with no shadow and pure white light, even dimmable on/off switching.
The turret system on OF1010 and OF 1400 leave some to be desired. The OF 1010 can use some more power too. My little DeWalt in use seems truly more powerful.
The OF 2200 plastic shroud plastic over the years became very difficult to see through, change the plastic type. Make the 2 point contact clamp a 4 point system for the attachment rods.
Heck, I prefer the OF 1010 and OF 1400 design be scrapped altogether and just make them look identical to the OF 2200. Shrunken down small OF 2200 style routers would be awesome.
« Last Edit: August 13, 2017, 10:32 PM by Dovetail65 »
Offline WilliamO
« Reply #1026 on: August 27, 2017, 03:40 AM »
4.5 inch (114 mm) trim saw
Offline jobsworth
  • Does Anyone Know What Time It Is?
« Reply #1027 on: August 27, 2017, 09:05 AM »
I wish they made a sawmill but then it would cost 3xs the cost of a milwaukie
Offline dastueve
« Reply #1028 on: September 22, 2017, 08:34 AM »
I would like Festool to make a drill attachment to emulate a drill press in a portable way.  This would provide a straight drill platform with repeatable drilling.  I use my router regularly, but would like a simple mobile solution.
Offline Euclid
« Reply #1029 on: September 22, 2017, 05:36 PM »
Do you mean something like this…?
https://www.festool.co.uk/products/timber-construction/drilling-guide-systems/768768---gd-320#Overview
I think they are intended, principally, for long holes in timber construction work; though there are much smaller (and less expensive) items (from Wolfcraft, for example) which work in the same way.
Or are you thinking of something different?
Offline rst
« Reply #1030 on: September 22, 2017, 08:46 PM »
Not Festool but very interesting...youtube.com/watch?v=LDa2bSWLvcE.
Offline Al-Breit
I posted this on our Facebook fan page recently and there were a lot of responses.
Obviously, we've had many threads here with various "wishes" but in a word or two, let's hear what you wish Festool would offer that it currently doesn't.
PS - Please keep it clean.  [embarassed]
Offline abt
« Reply #1032 on: October 28, 2017, 03:50 PM »
On the MFT tables, the same registered stops in place on the long sides, put in on the short sides.  I currently use a combo square (and longer track of course) to align the track supports, but built in stops would be quicker.
Like others on the FOG group, registration jigs (short and long) and matching head for the Domino's like the other German 'Brand X' has (ya know, the guys with the red colored logo), which would make working with wider boards a lot easier.
Offline Peter Halle
« Reply #1033 on: October 28, 2017, 04:01 PM »
You can order extra Festool Feather keys for the MFT/3 extrusions.  That is what the part is called.
Offline woodbear
a taller hose garage for the CT SYS vacuum. is anyone else with me on this? it could have been 1-2"  taller so the hose will fit easily instead OF SHOVING IT INTO THE CORNERS TO GET IT ALL TO FIT. I am seriously thinking of getting a systainer 2 to handle the hose and on board accessories ( which you have to unplug the hose to get access to)
Offline Gregor
Yes, a SYS2 sized hose garage would be nice, as an option.
Offline Jim_in_PA
« Reply #1036 on: November 23, 2017, 01:20 PM »
I've been asking for years for Robertson/Square Drive support from Festool for drill/drivers. I have the Snappy Centrotec square drive bits, but they are not as good quality as I would prefer.
ETS 150/3, Rotex 150, OF1010, OF1400, Trion PS 300, TDK-12, CT-22, MFT 1080, TS55, Domino XL DF 700, 8' track, (2) 55" tracks
SCM MiniMax S315WS, FS350, MM16, Camaster Stinger II SR-44 CNC
Offline Alan m
« Reply #1037 on: November 23, 2017, 02:02 PM »
I would like an edge sander. something like the ls130 or dts sanders but with an attachment that hold it square to the edge like the laminate trimmer attachment for the of1010
Offline Holmz
« Reply #1038 on: November 23, 2017, 08:50 PM »
That Sir... seems like it would be pretty brilliant thing to have.
« Reply #1039 on: November 23, 2017, 10:13 PM »
Unfortunately, the square drive bits were only offered in a limited edition installer set for the USA that was offered 2-3 years ago. They are also not available as replacement parts.  [mad] [mad]
Offline Jim_in_PA
« Reply #1040 on: November 25, 2017, 08:17 PM »
I've been asking for them for about ten years. I made a few of my own that fit in the Centrotec setup by chucking in my lathe and employing some files and about a year ago bought the Snappy bits that are designed for Centrotec. The last answer I got was "...we can't get them with the quality we want..." (paraphrased) which makes no sense to me. I've had plenty of great quality  1/4" "standard" bits over the years! Oh well...all I can do is ask. And ask again.  ;)
Offline Shawnm75
« Reply #1041 on: November 28, 2017, 04:40 PM »
Belt sander w/dust  collection Chambers that don't clog. Makita 3×21 hooked to CT is good but not great when using 50grit paper
Kapex, Domino 500, Barrel Grip Trion, ETS 150, RO 90 DX, TS 55, CT Midi, CT 26, CT 36, ShopBot PRS 96x48
Offline CSOrtner
« Reply #1043 on: December 06, 2017, 10:20 PM »
I wish Festool made a 12 inch compound mitre saw. This is probably the most dust creating tool in my shop. I like the way the 10 inch one works, and would buy it if it could cut a table leg!
Offline Master Carpenter
« Reply #1044 on: December 07, 2017, 01:10 AM »
A handsaw that cuts the exact width as a ts55. I had to finish some angled plunge cuts into a corner and the thin blade on my pull saw likes to go off on it's own course. Bonus points if it cuts on the pull stroke and fits in the systainer. limited edition is fine.
Ts 55, Ts 75, of 1010, lr 32, mft, mfs 700, RO 150 x2 + paper asort, RO 90 + paper asort, pro 5, df 500 + dom asort, hl 850 e, ti 15, t18, cxs, centrotec set, ct48, ct sys, vac sys, 32;55x2;118 tracks, a stack of sys and an og festool first aid kit. Kapex, planex, carvex, conturo.
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #1045 on: December 07, 2017, 02:24 AM »
I have had to tackle similar challenges.
Get a small Japanese pull saw. I use the cheap and cheerful ones made by Irwin. You can follow either edge of a kerf line very easily. I am sure that I have shown this in some of my videos but have not a clue which ones.
Offline Peter Halle
« Reply #1046 on: December 24, 2017, 06:55 PM »
An electric computer controlled gift wrapping machine!
Happy Holidays!
Offline mrB
« Reply #1047 on: December 25, 2017, 11:17 AM »
They have jigsaw blades the same size/kerf. One of the gold/yellow ones. Can find one of mine and post more details if you like ..
Offline Kai
« Reply #1048 on: January 09, 2018, 12:25 AM »
Bench saw TS 55 R insert for CMS table for USA
Offline rp127777
« Reply #1049 on: January 09, 2018, 02:35 PM »
I added in Facebook as well, but Festool should add a built-in light to their routers.  Attached is my low budget solution until they do.
« Last Edit: January 09, 2018, 02:39 PM by rp127777 »
