Author Topic: Holy Rails  (Read 9011 times)
Offline Drich
Holy Rails
« on: May 15, 2016, 09:58 PM »
I think all the track saw rails should come with the holes for the LR 32 system. It would be very handy that way.
Offline T. Ernsberger
Re: Holy Rails
« Reply #1 on: May 15, 2016, 10:02 PM »
Most dealers will swap out rails if you ask them.
Offline blaszcsj
Re: Holy Rails
« Reply #2 on: May 16, 2016, 12:19 PM »
Toolnut did for my TS55 order!
OF1010 EQ Router | MFT/3 | DF500Q | Carvex 420 | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB
Offline ear3
Re: Holy Rails
« Reply #3 on: May 16, 2016, 02:25 PM »
Agreed.
Offline dutchie
Re: Holy Rails
« Reply #4 on: May 16, 2016, 03:26 PM »
It would also make more sense to me to have the holes in all the rails in the way Festool is supposed to be a system. Where all parts and tools of the system work together.
It doesn't seem very 'system like' to have two versions of the same thing where the first version can be used to do fewer things then the second version, but adding this functionality to the first would also have no negative impact on how the first functions.
Offline SoonerFan
Re: Holy Rails
« Reply #5 on: May 16, 2016, 09:23 PM »
I wish the rail that comes with the TS had LR32 holes or better yet all rails had holes like the others have mentioned.  I did not know about the LR32 and did not join FOG until after my Festool journey began.  Now when I buy the LR32 I will need to spring for a new rails which is money I could put toward the VAC SYS I used at the roadshow.
Offline Drich
Re: Holy Rails
« Reply #6 on: May 16, 2016, 09:23 PM »
Very well stated. Maybe they will take this idea.
Offline SS Teach
Re: Holy Rails
« Reply #7 on: August 01, 2016, 12:28 PM »
Great idea. Why make two separate models when one holey rail will answer both needs.
RTS 400, LS 130, Sandpaper Systainer, Profile Systainer. ETS 125, Sandpaper Systainer, Ro 90, Sandpaper Systainer,  Ro 150, Sandpaper Systainer, OF 1400, TS 55 REQ, CT36, CXS Li 1.5 Set, Centrotec Wood-Drill-Set/8pcs, CT Wings, Surfix Set. Domino 500, Domino Systainer, Parallel Guide
Offline PreferrablyWood
Re: Holy Rails
« Reply #8 on: August 01, 2016, 01:08 PM »
I do not want holes in all my rails personally I will just use a 1400 for the LR32 system if and when I get it. I have the MFS which Can be used to extend the Holely rail to any length I need.
« Last Edit: August 04, 2016, 04:18 AM by PreferrablyWood »
RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline Shane Holland
  • Festool Dealer
Re: Holy Rails
« Reply #9 on: August 01, 2016, 01:13 PM »
 [thumbs up]
877-866-5688
Offline Holmz
Re: Holy Rails
« Reply #10 on: August 02, 2016, 06:09 AM »
A thread about "Holy rails" and not a single...
Amen Brutha
Re: Holy Rails
« Reply #11 on: August 04, 2016, 04:19 AM »
Amen Brutha
Without the Holy Rails the rains will not come..
Offline mwahaha
Re: Holy Rails
« Reply #12 on: September 22, 2016, 03:35 AM »
Probably because the holy rails are more expensive and the perks you folks enjoy are not repeated around the world. Here in NZ a 1400 holy rail is an extra $70 or so, and the 2424 holy rail is $826.
It would be nice though.
5m holy rail anyone?
Makin' chips since ages ago
Offline pettyconstruction
Re: Holy Rails
« Reply #13 on: September 22, 2016, 06:01 PM »
A employee of a Festool dealer told me that they make most of their money on the accessories , so Festool will probably stay with the way it is.
Sent from my iPhone using Tapatalk Pro
Offline Holmz
Re: Holy Rails
« Reply #14 on: September 23, 2016, 04:29 AM »
Wow...
Offline ben_r_
Re: Holy Rails
« Reply #15 on: December 28, 2016, 04:44 PM »
Yep, ToolNut.com swapped mine too. In the US the two 55" rails are the same price, so yea it makes no sense not to go with the holey rail.
  • Festool Dealer
Re: Holy Rails
« Reply #16 on: December 28, 2016, 04:46 PM »
 [thumbs up] [thumbs up] [thumbs up]
877-866-5688
