Pages: [1]   Go Down
  Print
Author Topic: Indexing jig for the Domino tool  (Read 1833 times)
Sparktrician
Offline Offline
Location: Northern Virginia (That's in the USA, Pilgrim!)
« on: December 03, 2010, 09:49 AM »
I'd like to see a clamp-on guide/indexing jig for use with the Domino tool, much like the Mafell device shown late in the video here - http://festoolownersgroup.com/other-tools-accessories/mafell-erikca-pull-saw/?topicseen.
 Smile
- Willy -
MFT/3 x2, TS 55, Guide Rails x5, Parallel Guide Set, CT 22 w/Boom Arm, CT Mini, RO 90, RO 125, ETS 125, RTS 400, RAS 115.04, C 12 + Centrotec Imperial Bits, CSX Set, TI 15, DF 500 Domino Set, SCG-10, Domino Plate from RonWen, MFK 700 Set, CMS-GE, OF 1010, OF 1400, OF 2200 Set, LR 32 System, MFS System, Syslite, Systainers, Sortainers, clamps.
Coming attractions: Carvex, Kapex, more "Stuff"-tainers...
Rob-GB
Offline Offline
« Reply #1 on: December 04, 2010, 01:33 AM »
I think Michael Kellough got it right when he posted the following in that thread...
Quote
"The wide mortises available with the Domino eliminate the need for precise lateral spacing. Just one of the reasons the Domino is better. Mafell and Hoffmann had to make such a positioning template because dowels have no tolerance for misalignment in any direction.
You can use the dowel template intended for the VS 600 with a Festool router (with the appropriate guide bushing and plunge bit) to drill 32 mm spaced holes (or multiples of 32 mm) across a panel. "
I recently had to join a lot of 12mm boards to make panels for doors and the ability to quickly adjust from one setting to the next and back again was a huge help. No need for another expensive attachment and no set up time required.
Rob.
Problem? No such thing! Only a solution waiting to be found:- RJ
"A $2 guppy swims......" Deke
Pages: [1]   Go Up
  Print
Jump to:
