Pages: [1] 2  All   Go Down
  Print
Author Topic: lets design the next track saw  (Read 6710 times)
Alan m
Online Online
« on: March 24, 2012, 03:33 PM »
hi there
given the reaction to the new ts55r
what features would you think the next one should have
now
wish list
fortrout
Offline Offline
Bench dog
WWW
« Reply #1 on: March 24, 2012, 03:42 PM »
It needs to stay on the track when cutting on 45 or its no better than the saw they have sold us already.
duburban
Offline Offline
« Reply #2 on: March 24, 2012, 04:26 PM »
I keep thinking the new ts55 features are exactly what makita is already offering. Tilt lock, more power...
ts75, ts55, ro150feq, ets150/3, trion, ct26, mft1080, estension wings, of1400, parallel guides, dts400, df500,
jmbfestool
Offline Offline
« Reply #3 on: March 24, 2012, 04:43 PM »
Are you Bored Alan?! Starting all these random topics which you know will be most likely start a massive debate lol
Well
I would like to see A new rail system to be honest but the New TS55 would still be backwards compatible to the old rail.
This would allow for more features to be added LIKE!
1. Anti tilt so you dont have to worry once you let go the saw drops of the rail!
2. Using your CT vac to create suction on the rail so no clamps need for certain applications.  Once you stop cutting vac shuts down and rail can be lifted off
3. A second track closer to the splinter guard for clamping smaller stuff when needed
4. Markings along the rail would be handy.   You can have a couple stops front and back you place where you want!     So you marked out your cut out like a sink on a work top......  You place your rail on it you can see the markings near the splinter guard which run across the rail you can place your stops on the marks start and finish of the cut and you then just simply cut.   Pick the rail up place it on the other side on the marks and cut again.
Few more things but gotta go add them in a bit!
JMB
« Last Edit: March 24, 2012, 07:22 PM by jmbfestool » Logged
andvari
Offline Offline
« Reply #4 on: March 24, 2012, 05:06 PM »
Now that all of the blades have the same kerf I'd like to see a cutting guide mark for the off side of the blade.
neth27
Offline Offline
« Reply #5 on: March 24, 2012, 05:51 PM »
Here we go  Big Grin
JimRay
Offline Offline
« Reply #6 on: March 24, 2012, 07:16 PM »
4. Markings along the rail would be handy.   You can have a couple stops front and back you place where you want!     So you marked out your cut out like a sink on a work top......  You place your rail on it you can marking near the splinter guard which run across the rail you can place your stops on the marks start and finished and you then just simply cut.   Pick the rail up place it on the other side on the marks and cut again.
JMB
Now that is a great idea! In the meantime, maybe I'll add one of those sticky backed measuring tapes to one of my tracks and give your idea a test run.
Jim Ray
Jim Ray
Alan m
Online Online
« Reply #7 on: March 24, 2012, 09:31 PM »
Well
JMB
bored . a bit i suppose.
a debate, yes but not the usual mafel is better stuff.
i like some of those ideas jmb
id like a bendy rail , like the mafel .
now
wish list
duburban
Offline Offline
« Reply #8 on: March 24, 2012, 09:58 PM »
i find this discussion curious from an industrial design point of view. what would does it cost festool to develop this technology and how much would you pay for it? perhaps some are brand loyal enough to stick with festool as the technology and prices climb but there has to be a price point that keeps it in the realm of justifiable. perhaps there could be levels of technology offered or add on's available after purchase for those that value those upgrades.
Charimon
Offline Offline
Tool and Tile Junkie
« Reply #9 on: March 24, 2012, 10:46 PM »
Incra Nylon rules slide in and stay in place and allow you to place stops at defined distances,  If you have the rapid clamp set use the front stop to make a "0" stop on the underside of the rail
I originally put the rule in to make fluted trim
« Last Edit: March 24, 2012, 11:02 PM by Charimon » Logged
"The existence of the flame thrower proves that at one time, somewhere, somebody said, " You Know, There's a group of people over there that I'd like to set on fire right now but they're too far away."
jmbfestool
Offline Offline
« Reply #10 on: March 25, 2012, 05:20 AM »
Yes Like that but I would like the markings to correspond with markings near the splinter guard also so  if you cant use the quick stops as a ''0''stop    you can just place the rail on the marks.
 At the moment what I do is I tick a line with a pencil the position of the rail with he markings on the piece im cutting I then  Plunge the saw then I place my first stop while keeping the saw in position so I know the start of the cut  then I cut along untill I get to the end and stop leave my saw in position and place the end stop then for the rest of the cuts I just place the rail on the mark where I ticked on the rail and I can just cut  simples.
JMB
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #11 on: March 25, 2012, 11:59 AM »
I hear people bringing up the Makita anti-tilt feature quiet often. What many of them don't realize is that this feature serves a purpose only when you are not using the saw. It stops the saw from falling over if you walk away from it. It doesn't serve a purpose during the cut. That's because if you let the saw ride against the anti-tilt rib, your bevel angle will be off. The absence of downward force on the rail will make this worse in the middle of a long cut. Knowing the way that Festool engineering thinks, I suspect that this is the reason why they have never incorporated an anti-tilt feature.
Deansocial
Offline Offline
« Reply #12 on: March 25, 2012, 03:15 PM »
yeah but i wonder how many people have droped a saw due to the lack o this feature, i know i have and it cost me a new bevel gauge as a result.
Quercus
Offline Offline
« Reply #13 on: March 26, 2012, 03:02 PM »
Excuse my ignorance but why the fascination with anti-tilt, just hold the machine while the adjustment is made. I tried the new TS55R at eco-build and it is good.
jmbfestool
Offline Offline
« Reply #14 on: March 26, 2012, 03:24 PM »
+1     I dropped mine because of the lack of anti tilt once when I first tilted the saw for the first time.
jmbfestool
Offline Offline
« Reply #15 on: March 26, 2012, 03:32 PM »
I know what the anti tilt is for to stop my saw from falling of  nothing more
 but your basically saying Festool thinks we (TS users) are idiots and are unable of knowing what the anti tilt is for so to avoid people calling up saying the saw doesnt cut at the correct angle unless I hold it down my self etc....
so  Festool thought to avoid TS users (idiots) calling!  they decided not to bother adding the anti tilt to avoid this hassle.
umm... yeah thats the reason why festool didnt stick the anti tilt on.
jmbfestool
Offline Offline
« Reply #16 on: March 26, 2012, 03:34 PM »
....  not just while the adjustment is made  you have to hold it even after you have adjusted it to the angle you want.    You have to hold it untill you remove of from the rail  unless you want it falling onto the floor.
Alan m
Online Online
« Reply #17 on: March 26, 2012, 05:41 PM »
maybe the next ts caould tilt in wards so that the weight is still over the rail.
now
wish list
jmbfestool
Offline Offline
« Reply #18 on: March 26, 2012, 05:48 PM »
Funny you say that!  I needed that feature to day!
I was making 80mm rips   2400mm long        18mm MDF with a 45 degree cuts on both edges   but cus it only tilts one way I had to place the rail on the off cut which isnt ideal.    Any way after cutting two I quit!  Even though my TS55 had a decent blade in wasnt too worn but after cutting them first two pieces it was very worn lol  Black!!! my TS stopped working and needed cooling down  Embarassed
I changed tactic!  I decided to just cut 80mm strips square  then using my CMS module with OF2200 router and my large 45 degree cutter   made a much better job and quicker and no burning and less hassle.
JMB
Alex
Online Online
« Reply #19 on: March 26, 2012, 05:51 PM »
Where do you leave the motor?
Alan m
Online Online
« Reply #20 on: March 26, 2012, 05:59 PM »
if the motor come out and when back at 90 degrees it would free up some space for it to tilt in.
maybe mount the motor at 45' and higher  and use a few gears to bring the power down.
im sure they could come up with something.
while we are at it i would like it to tilt both ways
now
wish list
Ken Nagrod
Restricted
Offline Offline
« Reply #21 on: March 26, 2012, 06:02 PM »
Then maybe you should just ask them to make it worm drive with the motor facing backwards towards the user like a Skil saw?
Rick Christopherson
Retailer
Offline Offline
WWW
« Reply #22 on: March 26, 2012, 06:29 PM »
I didn't call you or anyone else an idiot. I said that the anti-tilt feature works only when the tool is not being used. Most people that do not have the Makita saw don't realize this. They think it functions while the saw is in operation. As you said previously, you dropped your saw once. If you had said that you repeatedly dropped your saw, then maybe I might have called you....ummm....spatially challenged?  Big Grin Big Grin
Ken Nagrod
Restricted
Offline Offline
« Reply #23 on: March 26, 2012, 06:39 PM »
No Rick.  Butter fingers.  Big Grin
ART at WORK
Offline Offline
Buy less Recycle more
« Reply #24 on: March 26, 2012, 07:52 PM »
I very much Like the ideas JMB. Especialy the vacume rail.
I would like the saw to have a LED light on it to light up that little mark on the side.
Also to help you see the marks on the wood to line up the rail in low light places.
It of course can be turned on or off.
Kapex 120 + UG Set, ETS 150/3, DF 500, RO 90, MFT/3, CTL 36 AC, RO 150, 0F 900, CDD 12, TS 55, A5 Router table, First Aid kit, LR 32 SYS, FS 800, FS 1400, FS 1400 LR32, CTL Midi + Cleaning Set, Clamps, Parallel Guides, Centrotec drills, Zobo Forstner set and countersinks, Routers, Systainers, Sys Cart,
fdengel
Offline Offline
« Reply #25 on: March 27, 2012, 07:13 AM »
Resulting in the blade pointing toward the user?
Reiska
Online Online
Hackers build things, Crackers break them.
« Reply #26 on: March 27, 2012, 08:18 AM »
How about laser lines that dynamically adjust to the depth of the plunge and mark where the front and the back end of the blade run at any given plunge depth?
This would blast away the static markings on the side of the saw (like Mafell has) that define where the blades extents are at full depth plunge while doing holes in the middle of a table top.
The sky's the limit in my workshop, literally. Big Grin
fdengel
Offline Offline
« Reply #27 on: March 27, 2012, 09:28 AM »
At the top or the bottom of the workpiece?
Or maybe use different colors of lasers to show the extents at the top vs. the bottom?
Reiska
Online Online
« Reply #28 on: March 27, 2012, 09:49 AM »
Well, I would presume that the top width would be most beneficial. Of course more the merrier =)
andvari
Offline Offline
« Reply #29 on: March 27, 2012, 10:22 AM »
hi there
A slightly longer standard guide rail. The 1400 guide rail isn't long enough to cross cut a 4x8 sheet of plywood without the guide gibs coming off the rail.
Pages: [1] 2  All   Go Up
  Print
Jump to:
