Author Topic: lets help design the new kapex  (Read 33864 times)
Offline SRSemenza
Re: lets help design the new kapex
« Reply #30 on: July 03, 2011, 08:31 PM »
You think U.L. approval isn't bad enough, let's see them going for this.  I would say this is something for a FOG member to come up with that others on here could reasonably implement.
So when will the prototype be ready, Ken?
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #31 on: July 03, 2011, 09:11 PM »
Most horizontal mortisers have a pneumatic hold down, not new technology...
Even if the vacuum idea doesn't fly, there ought to be a way to clamp a small piece without getting your fingers anywhere near the blade.  That would sell a lot of saws.
Offline Ken Nagrod
  • Restricted
« Reply #32 on: July 03, 2011, 09:26 PM »
Hey if I'm getting my fingers dirty, so are you.  Guess we'll have to put the systainer entertainment system on hold.  [big grin]
Offline dharmon
« Reply #33 on: July 04, 2011, 12:11 PM »
I'd like to see a micro-adjust when the piece is clamped down, so I have the ability to move a lever or a screw thread or something to keep the piece clamped, yet be able to sneak up on my pencil line.  Additionally, it would be great to have some better side extensions, or a better stand, than they have now.
Offline Alan m
« Reply #34 on: July 04, 2011, 12:25 PM »
this is what i like about forums . some one makes a sugestion and some one else improves it. great idea on the fine adjuster
Offline jmbfestool
« Reply #35 on: July 04, 2011, 03:46 PM »
I would like the suction pads to be on the base but also on the Rear fence on both sides.    When you pull the trigger half way the vacuum kicks in  but their is a second delay between the fence suction pads and the base!
This is because the fence pads would Pull the timber against the fence before the base suction pads kick in holding it in place.
Also the Micro adjustment Idea is great love it!  The suction pads can move 5mm +/-  with a turn knob on the front but they still hold the timber down while your adjusting!
Oh I wish I was loaded Alan! If I was loaded!  I would create my own tool range with ideas mentioned! Unique! Wont mater if I didnt sell alot as I have money to waist lol!  Sadly Im not so I will have to stick with buying Festool tools!  [tongue]
JMB
*********************************************************************** [thumbs up]UK members click me
Offline Laminator
« Reply #36 on: July 08, 2011, 10:12 AM »
I would like for the dust port to point straight up which would beat any position that it will adjust to as it is now.  Also some kind of center handle (like makita) to lift the saw with one hand.  I use the rod that has the bevel control as it beats nothing but the saw is not balanced for this method.    A  longer trigger would be way awesome  as would a longer cord.    Let there be light! Please!
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
« Reply #37 on: July 08, 2011, 11:05 AM »
Yes, I can't believe I forgot this one. [thumbs up]
Offline Ken Nagrod
  • Restricted
« Reply #38 on: July 08, 2011, 11:22 AM »
This was thought out by Festool's designers.  Lifting the saw with one hand leads to poor posture.  Look at what happened to this poor carpenter after just a handful of times lifting the saw with one hand.
« Last Edit: July 08, 2011, 11:24 AM by Ken Nagrod »
Offline Steve R
« Reply #39 on: July 08, 2011, 11:43 AM »
I like getting DC into bottom tack... it is hard to clean out as it is.
I would like a light but not over power the great lasers.
I would like something like the the fastcap sawhood and build in mounts for it to get the last 3% of the dust. Also would help to see the lasers in daylight.
What is important to me is that it stays light and easy to transport.
Adding weight to it would not be good.
I would not want a longer trigger. I have Dewalt saw with a long trigger and you can't get it to shut off most of the time as you have to have two or three fingers on the trigger to get balance and then you can't hold it or move it with just your little finger.
Maybe a case Not a systainer....is the Festool God going to smite me?.... that fits close so you could protect it in transport and not take up the whole vehicle. it would be nice to carry if one handed but I don't agree with lifting the unit by the the motor handle or shafts that do all the precise adjustments. It works well today to lift by the base...just has to be a two handed thing.
If it didn't change any I would still love that saw!
Cheers,
Steve
« Last Edit: July 10, 2011, 12:40 PM by Steve R »
Offline speed
« Reply #40 on: July 10, 2011, 12:29 PM »
3 things for me
1 bevel lock on the front, you cant lean over and just flip the lever you have to pull the saw forward on the rails and makesure the hose is out of the way
2 the vac kicks in on lowering the head so its upto full suction before you start the saw
3 the trenching mode to be better as i fw times when ive cut a trench the cut got a little deeper if i apply too much weight
has made the change. now 100%  T-loc :)
Offline MrMac
    • Laurie's Custom Finishing Carpentry
« Reply #41 on: July 10, 2011, 11:32 PM »
I don't have a kapex- yet :D but it's high on my list. From what little I know having used it briefly at the dealers, I would really like that digital readout. I have that on my Milwaukee saw now (12") its really nice, 1/10th deg readout. Problem is that this saw is a huge boat anchor! oh, it's got lights built into the head, so that's good.
Smoother "swing" on the table, anyone tried the new Makita? super smooth! Up front bevel controls? not sure about that, I rarely need the bevel feature, so that's not an issue for me.
Lasers! can't see them. red/green color blind issues, ya I'm defective so sue me! LOL I'm so used to not using them I don't know if one would be an advantage.
That shadow light that someone mentioned on the Dewalt? I've used a Dewalt with one on. It is a good sharp line, but it moves as you bring the saw head down close to the wood - sometimes that's a pain to do, three hands needed.
Re-design of the crown stops, if you use the festool stand, the stops can't go on.
Oh, and if business continues to be good, I'll need this new designed saw by mid October :D please?
MrMac204
serving the greater Vancouver area.
Offline jobsworth
  • Burger Babe Says: I Even Buy Green Bananas
« Reply #42 on: July 12, 2011, 06:20 AM »
Has anyone mentioned a pneumatic version of the Kapex?
 Maybe include and beer opener attachment er ah I mean a bottle opener
Loving the Calif sun....
Offline Laminator
« Reply #43 on: July 13, 2011, 03:40 PM »
I didn't mention it before but the reason for a straight up dust chute is so the hose would not interfere with the bevel clamp control.   A straight dust chute would be a simple part to make (for Festool) and easy to change out from the stock one.
Offline stairman
« Reply #44 on: October 13, 2011, 12:08 PM »
1st, I'd like a double systainer for the saw. this will have some decent size casters on it, and will allow a double stack of regular systainers to latch onto it.  -I'm sure more than a few of you can appreciate where I am coming from with this,  but in any case, being able to roll ALL your tools in on the first trip would be a Godsend!  (I think it would be,   -I can only imagine)
Next, the clamping issue...
there are clamps which you set to the workpiece thickness,  then as you pull the saw head down, it clamps the workpiece
if enough tension isn't created, the trigger locks out...      You need only 1 small clamping fence on each side of the blade, and the entire mechanism is purely mechanical,  however it could be easily removed and the trigger reverted to normal operation with minimum effort.
-but with this system installed,  as you pull the head DOWN,  it CLAMPS   -simple as that...
Kapex on a UG, TS75, OF1400 (x2) OF2000,,HL850,  Domino, RO90, RO125,  LS130, RAS115, MFT3, C12 Set, CXS Set, LR32 Set,  arsenal growing as fast as I can afford it!
Looking to buy: RO150EQ+ ; LR32 guide rails, 3000mm guide rail, parallel guide set   ;  another TS55 to replace the 1 I sold...   OF1010 and additional Festool Routers ;  RS2  ;    and a FESTOOL BS105 BELT SANDER SET
OK, let's face it, I'm always looking for any Festools / accessories.
Offline Festoolfootstool
  • The trouble with Bob is its all about Bob
« Reply #45 on: October 13, 2011, 01:31 PM »
One word......weight and one smily [unsure]
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Offline stairman
« Reply #46 on: October 14, 2011, 08:18 AM »
I don't think so...  I have a Triton Metal Cutting saw which has a clamping system like this and there is very little to it...  this is a very simple mechanical system that takes advantage of the force used to pull the head down.  if I removed the system from this Triton saw,  enlarged it another 60-75% it MIGHT weigh 1.5 -2lbs...
the retractable throat plates idea from earlier in this thread could use a mechanical system that is fundamentally identical .
Offline awdriven
« Reply #47 on: October 14, 2011, 08:54 AM »
I think the UG cart is their solution to transporting the Kapex. It's better for moving from truck to site because you can more easily pull it up curbs, door thresholds, etc than you could with something like a double-width 'syscart'. The saw is also usable quickly after you arrive on site because you don't have to take it out of a case - AND it is already mounted to it's table-height stand, so you don't have to also carry and set up horses.
The disadvantage is that you can't really carry any systainers with/on the UG and you can't tie together a couple systainers in your truck for a more secure carry. The UG also doesn't provide as much protection for the saw as something like a systainer would.
I need to start saving pennies, either for someone's used Kapex or a Kapex Zwei when it comes out.
Offline Alan m
« Reply #48 on: October 14, 2011, 09:00 AM »
not sure what your talking about. hopefully its a new tool that we have yet to see.
maybe you should make a  syport trailer for the ug stand
Offline Guy Ashley
  • Furniture & Cabinet Maker/Joiner
« Reply #49 on: October 14, 2011, 09:37 AM »
Alan
Zwei is German for 2, so he means the Kapex 2 or Mk2 or second edition.
DIPLOMACY:
Offline awdriven
« Reply #50 on: October 14, 2011, 10:04 AM »
Exactly, thanks ;)  Don't run out to check and see if that domain name has been reserved or anything, it was just my made up name for the next miter saw.
Offline Alan m
« Reply #51 on: October 14, 2011, 11:51 AM »
sorry . stupid mistake. ne spragan ze doitch. (sorry my spelling is worse than my pronounciation)
Offline Kev
« Reply #52 on: November 22, 2011, 08:50 AM »
Get creative guys ... how about an off centre blade drive, something that'll let a 10 inch blade cut about 6 1/2 inches or more. This could incorporate a quick change blade mechanism. Take the technology then to the plunge saws - more compact with greater cutting depth. Sure there'll need to be a drive tooth pattern on one face of the blade and there'll need to be some serious alignment capstans, etc.
Another option would be massive refinement of the chainsaw principle, for a fine accurate cut. CHAINEX ? KAPPACHAINO ?
Offline zapdafish
« Reply #53 on: November 22, 2011, 10:13 AM »
Remove the spinning blade and up the power of the lasers, waaaaaay up  [thumbs up]
No more sharpening and no more dust collection problems  [big grin]
Offline fritter63
« Reply #54 on: November 22, 2011, 11:41 AM »
A 12", er uh, 304 mm blade capacity.....
Should be called the "Kapex 305"
Offline CutsTwice
  • Crazy Cabinet Monkey
« Reply #55 on: November 23, 2011, 04:35 PM »
I'll put in another vote for a built in work light. I've installed one from a Makita onto my Kapex, and it was heavenly......until the transformer died a year later.
I also really like the idea of switching to continuous run on the vacuum from the saw for repeat cutting.
Life is an endless, toiled endeavor... yet tonight, I yearn for rest.
Offline Kev
« Reply #56 on: November 24, 2011, 05:42 AM »
Why does everyone have a thing about continuous run on the vac via the KAPEX?? I'd like the vac to have a variable overrun timer ... that way the feature would be available for all of the Festool tools.
And the lights ... Festool got it right by creating a highly effective battery powered light. For the rest, the work site should be well lit.
Really ... does anyone expect a floodlight on the end of their hammer?
Offline CutsTwice
« Reply #57 on: November 24, 2011, 12:51 PM »
A couple of things Kev,
No matter what anyone says, the Kapex is the weakest link in Festool's dust collecting tools. If the vacuum would run constantly during a cutting session, it would reduce the amount of fine particles that you breath in. Of course I could walk around the saw stand, bend over, and turn my van on manually, just to shut it off three minutes later... but I don't want to.
We cannot get the work light in North America yet. Even if I could, I don't want to rig up some stand to hold it over my saw. People such as cabinet installers aren't usually on a job site for more than a day or two, and much of the time the light fixtures aren't even installed yet. This means that if I have pack, plug in, and place one less light in a kitchen during an install, I would pay extra to have one built into my saw.
When I make a cut for...let's say crown molding...I want it to be precise. If it's overcast outside while working in a kitchen with little light other than a picture window that has plastic stretched over it for the painters I have a hard time cutting to within a 32nd. Maybe my eyes aren't so great, but I would still pay for a built in light on the Kapex. After trying one, I'll tell you that in my opinion, any other option is silly.
Offline Alan m
« Reply #58 on: November 24, 2011, 01:23 PM »
the xps light on my dewalt 718 is one of the best deatures
Offline Kev
« Reply #59 on: November 24, 2011, 02:48 PM »
No matter what anyone says, the Kapex is the weakest link in Festool's dust collecting tools. If the vacuum would run constantly during a cutting session, it would reduce the amount of fine particles that you breath in. Of course I could walk around the saw stand, bend over, and turn my van on manually, just to stuff it off three minutes later... but I don't want to.
I'm not suggesting people dance arounmd the KAPEX, constantly turning the vacuum on and off - an adjustable overrun timer on the vacuums that have a power out would give flexibility for any power tool - not just a KAPEX.
I would still maintain lighting is a wider issue - also i'd hate to see the results where painters were working in relative darkness! Good all round lighting also increases safety.
