Author Topic: lets help design the new kapex  (Read 35003 times)
Offline Brice Burrell
  • Remodeling Contractor
    • The Green and Dark Blue blog
Re: lets help design the new kapex
« Reply #90 on: December 18, 2011, 09:26 AM »
How about a trade in program. :)  I would like to get rid of my Bosch and move to a Kapex.
You mean sorta like the cash for clunkers. [tongue]
Offline Peter Halle
  • Another Avatar Coming Soon
« Reply #91 on: December 18, 2011, 09:33 AM »
 [thumbs up] [thumbs up]
Offline Kev
« Reply #92 on: December 18, 2011, 05:30 PM »
I'm getting a mental image of big used mitre saw lots on the side of the main road ... salesmen in safari suits, etc ...
Father: c'mon son - let's get you your first mitre saw ...
Son: but daddy, why can't I have a KAPEX like you?
Father: you've got to learn to appreciate a KAPEX son ... now that blue one over there looks ok ...
Offline Alan m
« Reply #93 on: December 22, 2011, 02:02 PM »
how about some dog holes in the top of the base part so that you could use the clamping elements to hold the stock
Offline Steve R
« Reply #94 on: December 22, 2011, 08:49 PM »
+1 on that. I now use the crown wings all the time and use the blocks to hold the stuff against the fence.
Cheers,
Steve
Offline Steve R
« Reply #95 on: December 22, 2011, 08:53 PM »
How about adding measurement marks on the fixed fence..... and yea they should be both imp and metric...... [2cents]
Cheers,
Steve
Offline Chadster
« Reply #96 on: March 03, 2017, 11:18 PM »
1. Some sort of area LED light... XPS type or whatever.  Keep the lasers however, they are quite valuable.  Also keep the on/off laser switch.
2.  Some type of one handed top handle.  It's not easy to try to carry the saw through a door when you have to open it and close it and you have to have Both Hands on the Saw!!
3.  A slightly longer trigger would be helpful.  Many times during a cut my hand just slides off the trigger enough to have to have the saw stop momentarily.
4.  An option for an extended dust shroud similar to bristles or curtains that could easily be snapped on and off if doing steep compound bevel cuts that could interfere with it.
Power if fine with me...a few more RPS couldn't hurt though?
Keep the rail forward design.
Keep the weight down.
Maybe and option for hanging the fences off of the saw when they are removed?
Make the fences actually lock in square and not wiggle...at all.
Just bought my Second Kapex.  [eek] First one is in for service.   [unsure] Its much much smoother more refined and compact than my 10" dewalt slider with xps.
« Last Edit: March 03, 2017, 11:24 PM by Chadster »
hmm,  lucky numbers today?  27 36 50.....mm of course ;)
Offline DiscoStu
« Reply #97 on: March 04, 2017, 02:41 AM »
Offline Holmz
« Reply #98 on: March 04, 2017, 05:58 AM »
A Cuprex motor on it is all is really needs.
Offline Chadster
« Reply #99 on: March 04, 2017, 08:35 PM »
...yeah [wink]  maybe I'm a little late to the design party...haa
Offline DiscoStu
« Reply #100 on: March 05, 2017, 02:13 AM »
Personally resurrecting old threads never bothers me. It's also quite timely with the new Kapex 60 having just been launched.
« Reply #101 on: March 12, 2017, 01:42 PM »
So... ...how did the forecasting pan out from 2011? Is the Kapex KS60 "it"? [smile]
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
