Author Topic: MFT/3 Guide Rail Support System  (Read 2794 times)
Offline monkeysimple
« on: February 15, 2017, 07:34 AM »
I am new to the MFT/3 world.  I would like to be able to cross cut full width 4x8 sheets.  Has anyone seen a way to add on an expansion (maybe with 80/20) to use the existing guide rail supports with pivot and switch out to a 1400?  Thanks.
Offline DrD
  • I might not be fast BUT I sure am slow
Re: MFT/3 Guide Rail Support System
« Reply #1 on: February 15, 2017, 09:07 AM »
I took 2 MFT/3s and joined them long side to long side using Bosch Rexroth profiles, and spanned them with a FS1900 rail, allowing me more than enough room to cross cut a full sheet of ply.  By raising the rail and dropping the non-pivot side rail support down to just below table height, and placing some shop-made support tables at the rear, I can rip the full sheet as well by connecting 2 FS1400 rails utilizing a Betterley alignment aid.
Hope this helps.
DrD
KS12 EB Kapex with Delta Folding Table & FastCap Best Fence; TS75 EQ with Parallel Guide Rail Set (FS-PA 495717 & FS-PA-VL 495718) and FS 800/2, 1080/2, 1400/2 LR32, 1400/2, 1900/2 Guide Rails, and Betterly SLC23 Straight Line Connector; DF500 Q with Assortment Systainer; OF1010 EQ with Fine Adjuster for Guide Stop, WA-OF Angle Arm, UP-OF Edging Plate and SF-OF Chip Deflector (486242); OF1400 EQ with OF1400 Dust Hood x 2, OF 1400  Edge Guide x 2, OF 1400  Guide Stop; LR32 Set; PSB399 EQ; EHL65 E; RAS115.04 E; RS2 E; ETS150/3 EQ; RO150 FEQ; Hand Sanding Block Set; CT26 with assortment of AS and Non-AS Hoses; MFT/3 Table x2; SysLite; Assortment of Quick & Screw Clamps, Consumables, Dogs.
