James Watriss
Offline
« on: January 19, 2010, 09:53 PM » |
I was responding to the thread about the under-lid pictures, and finally figured out what I think I want:
The OF 1400 has a lot of bits and pieces, and they all rattle around, or have to all be unpacked to get to the one thing I always need... the wrench... And I think i have a solution.
An accessory insert/ container set that holds the router in its upright position, but allows for two (well-made) upright containers that would slide in on either side of the router, to hold all of the bits and pieces.
It's possible that the bottom of the insert would need to also have room to hold the bars and the fence. But the myriad of dust shrouds, the wrench, the rail blocks, base inserts, as well as all the OTHER stuff, like guide bushings and bits... they all are left to crash aimlessly into and around a $500 router. As the saying goes, it's not the fall that kills you, it's the sudden stop. Likewise, it's not the moving around that will add wear and tear, it's the crashing into each other of all the bits and pieces.
So far, I use a separate systainer to hold some of the smaller stuff, and I need a sortainer 4 to go with my 1010... but it really is a hassle when i need to take either of the routers somewhere... did I remember ______? Do I have room in the truck for one more box? On the one hand, it's all part of the game, and not something to complain about idly. But in reality, the genius of the systainer system to me is that it allows me to keep everything with me, where I need it. But the routers are a special case, because they are so accessory-heavy. The systainer setup as currently offered does a reasonable job of holding the required stuff. But I think it would be nice to have the option to do it a little more gracefully, and not have to rummage through the systainer like a 5 year old through his toy chest.
« Last Edit: January 19, 2010, 09:56 PM by James Watriss »
James Watriss
Offline
« Reply #1 on: January 19, 2010, 10:02 PM » |
Alternate idea for the OF 1010:
We have inserts for systainers. How about exserts for sys minis? Becuase the 1010 lies down in the systainer, and because the mini systainers can sit in a regular systainer sideways, a mini systainer with a lid modified to act as an insert would do a great job of holding the small bits and pieces, while supporting the router in transit.
Just an idea.
harry_
Offline
« Reply #2 on: January 26, 2010, 01:46 AM » |
James,
That is a great idea!
I find that no matter where or what it is, I hate digging for (or even having to easily move) something to get at something else.
I have the OF1010. If I am reaching in the box for the router there is a 50/50 chance of needing to change the bit. I hate digging for the wrench! Especially when I can look into the systainer and see all kinds of room to have put it some place else in the insert.
A cool wish for me would be to have cord storage on the systainer lids. It is very rare for me to have more than one cord out at a time even though I may be using 3 tools.
joiner1970
Online
« Reply #3 on: January 26, 2010, 05:40 AM » |
i have only had the of1010 a few months and this really gets on my nerves. You have to move everything just to get to the spanner (wrench) everytime its a real pain , you listening Festool ?
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #4 on: February 17, 2010, 12:54 AM » |
I bought my OF 1400 when they were first introduced in USA, and several accessories to go with it. Everything goes into the original Systainer together with 5 collets (I separately purchased a 3/8" and 10 mm collet), Edge Guide, Guide Stop, Chip Guard, VS 600 Dust Extraction Hood, Whiteside brass set up bars and inlay kit, Extra Dust Hood. It's a bit crowded and yes, I have to take out a lot of items to use the router, but you have to remove a lot anyway to access the collet wrench and Guide Rods. I keep the extra collets in the packaging in which they came from Festool because the insert does not have enough molded locations for 4 extra collets. I keep my bits in a separate Router Bit Systainer which works fine for most excepting some that are longer than what Festool sells.
I agree that Festool could do a better job of providing an insert for their OF 1400 and OF 1010 routers.
A bigger problem for me is keeping handy and not losing the small parts needed for the small LR Hole Drilling Set (no Systainer) more so, my MFS. What do other owners of these router accessories do for storage of these small parts?
Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
jonny round boy
Offline
« Reply #5 on: February 17, 2010, 04:52 AM » |
OK, just been to take some pics of my OF1400 systainer... This is the systainer, with all the accessories in their relevant locations. Note the dust shroud for the parallel guide in the top left-hand corner:  Now, if you remove this, you can place it loose in the bottom right-hand corner:  Which now leaves room for:  A Mini-Systainer 1!!! You have to tip the router very slightly forward to get it in, but once it's in the router sits correctly in it's location. The back edge (now at the bottom) of the mini-sys sits onto the parallel guide. I use the mini-sys with the moulded tray & foam liner. This is used to store additional collets, the wrench, and quite a few router bits:  I think it is pure coincidence, but it fits so well you could be forgiven for thinking it was designed that way...
William Herrold
Offline
"failure is imminent"
« Reply #6 on: February 17, 2010, 07:01 AM » |
You're going to end up with chipped carbide allowing them to rattle around loose like that.
"I don't believe anything, but I have a lot of suspicions" R.A.W.
Brice Burrell
Offline
Remodeling Contractor
« Reply #7 on: February 17, 2010, 10:29 AM » |
That's exactly what I was thinking. I know Tanos sells a router bit insert for router bits. I don't there'd be much room for anything else.
jonny round boy
Offline
« Reply #8 on: February 17, 2010, 11:22 AM » |
Yes, I know!  The bits in the 6 small compartments don't move about - once the lid is closed they're held by the foam & don't move. The bits in the long compartment at the front are either in plastic tubes or are wrapped in cotton to protect them. The bits that are loose in the top right are old bits that I don't care about... OK, I'll be honest - I am aware that the bits could chip, but I've just gotten lazy, and since they mainly just stay in the shop now I haven't bothered. I will go and have a word with myself immediately.  But the original question was about finding storage options for spare collets, MFS hardware 'bits', etc., not router bits. That's my excuse & I'm sticking to it!
William Herrold
Offline
« Reply #9 on: February 17, 2010, 11:59 AM » |
I only commented because I've made the same mistake myself. That's the quality of carbide- the harder it is, the more brittle it is.
Wood_Junkie
Offline
Location: Madison, Wisconsin - USA Member Since: Dec 2009
« Reply #10 on: February 17, 2010, 07:16 PM » |
Just put some adhesive velcro on the side-wall and on the wrench, and just stick it there. Looks like there's plenty of room on all sides of the router. Or even better, afix it to the lid.
I don't have a Festool router yet, but I suspect its in my 2010 future...
RL
Offline
« Reply #11 on: May 20, 2010, 12:22 PM » |
Does anyone know if there a dedicated spot in the OF1400 systainer for the guide stop (492601) and support foot (438608)?
Thanks Richard.
I like green.
Deansocial
Offline
« Reply #12 on: May 21, 2010, 04:41 PM » |
after seeing how you keeps your router cutters jrb, i bought this today
TomGadwa1
Online
« Reply #14 on: May 26, 2011, 01:02 AM » |
There is a place for the guide stop to fit. It needs to be in two pieces. Then the guide stop can be placed on top of the edge guide. One piece with the micro-adjuster fits near the front of the systainer and near the lefthand side of the edge guide, the other part fits over the middle of the edge guide near the center of the systainer.
TS55 EQ OF1400 EQ DFQ 500 Q RO 125 LR32 SET Guide Rail Acc Kit Parallel Guide Set MFK 700 EQ Set MFS700 ETS 150/3 EQ Domino Cutter Assortment T15-3 Drill Set RO 90 EQ Workshop Cleaning Set CT36 Kapex 120 MFT/3 LR32 1080 FS 1400 FS 1900 WCR1000 PSB300 Boom Arm Set Clamping Elements RS 2 E Kapex UG Set Zobo Forstner Set Centrotech Installers Set OF1010 OF2200 ZS-OF 2200 SYS1000 Syslite CT MIDI FS 800
There Are Those That Can Do, There Are Those That Can Not Do, Those That Can Not Do Have Those That Can Do Do The Things That They Can Not Do So That They Feel That They Have Done Something.
There ain't no something for nothing machine.
Ken Nagrod
Restricted
Offline
« Reply #15 on: May 26, 2011, 01:27 AM » |
If this helps anyone, here are a few pictures of the OF1400, the MFK700 with all the accessories packed in. Someone also mentioned recently that they didn't know how the edge guide went in for one of the TS saws so here are the TS75 and TS55 with the guides.
Tom Bellemare
Festool Dealer
Offline
« Reply #16 on: May 26, 2011, 01:29 PM » |
I don't quite understand the issue with the OF 1400 wrench location. If I need the wrench, the router is not in the systainer and the wrench is easily accessible.
I like it down there, especially for transport, because it is trapped underneath the router.
Brice Burrell
Offline
« Reply #17 on: May 26, 2011, 06:00 PM » |
You're looking at it all wrong Tom. The problem is I sometimes forget to put the wrench in I have to take the router back out, doing so usually dislodges something in the process so there's another thing to get back into place......
Frank-Jan
Offline
« Reply #18 on: May 26, 2011, 06:21 PM » |
At least it's better than the location of the wrench for the of1010, underneath the edgeguide.
fritter63
Offline
« Reply #19 on: May 26, 2011, 06:24 PM » |
Interesting that this thread got revived.
One of the things I planned on doing, if my "3D printing of systainer inserts" approach ever takes off (ie, becomes affordable) was to build just such a set of inserts that mold around the OF 1400 in those empty corners and hold router bits, etc.
