Pages: [1]   Go Down
  Print
Author Topic: Rail Deflector  (Read 1508 times)
SRSemenza
Global Moderator
Offline Offline
« on: October 01, 2011, 03:48 PM »
I would like a redesigned rail deflector. One that has taller flanges, and make the flanges flair out more to the sides so that the hose /cord feeds better when not coming straight in. It would also help if the deflector covered the full width of the FS/2 rails. And eliminate any openings or gaps between the flanges and the flat portion.
I have a standard deflector that I modified years ago, so that it can be mounted in the other channel. This allows it to work better  when the hose is coming from the left.
http://festoolownersgroup.com/festool-jigs-tool-enhancements/guide-rail-deflector-modification/
Seth R. Semenza
S. R. Semenza Woodworking
Festool Service 800-554-8741
Brice Burrell
Offline Offline
Remodeling Contractor
WWW
« Reply #1 on: October 01, 2011, 04:42 PM »
I'm with you on this one Seth.  I'd also like to see the it wrap around the bottom of the rail some to reduce snagging the hose.
ScotF
Offline Offline
WWW
« Reply #2 on: October 01, 2011, 11:31 PM »
A guide rail connector fills the void in the slot and you can leave it slightly protruding out of the end - this helps keep the cord and hose in the deflector.  I agree that one the covers the entire rail would be nice and also a little narrower in width to give more room for the TS.
Scot
TomLewis
Offline Offline
« Reply #3 on: November 04, 2011, 11:30 PM »
The rail deflector didn't change when they redesigned the rail to have two t-slots. My older rails only have one slot for an extension bar, not two, so this is a hold over from the previous version of rail.
It would be nice if it was more 'funnel' like.
Festools ---
AT65 EB/1 Plus plunge saw
OF1000 EB/1 Plus router
OF2000 E/1 Plus router
CT33E dust collector with hose garage
D36 UNI-RS-Plus dust collector kit
RO125 FEQ-Plus sander
T15+3 Li2,6 Set cordless drill
MFT/3 table
5 tracks, both FS and FS/2 versions
parallel guides, extentions, misc clamps and accessories
Centrotec Installers Kit
Festool tape measure, beer mug and watch!
Pages: [1]   Go Up
  Print
Jump to:
