Same concept as a retractable air hose reel. How much larger would the charger housing actually have to be. This could be integrated into either the bottom or the side of the battery charger case/housing. Need to provide a recess to house the plug end as well. You extract the length you need to reach power source
(most times I only need 18-20" of cord). When done a quick short pull on the cord and it retracts back into the case.
It's an integrated cord garage for your battery charger
You know when that new battery powered tool arrives and the battery charger cord is tightly coiled and contained with a twisty of some sort from the factory. Once you uncoil that cord for use you know you're not going to coil it back that tight again. Most times if not neatly coiled and contained she don't fit too good in the case that shipped with the tool.
