Steve Rowe
Offline
« on: March 11, 2007, 01:50 PM » |
One thing that I would like to see is square drive bits for the Centrotec chuck. I suspect the demand for these in the US would be large. Steve
Jim Becker
Offline
Think twice...write once...
« Reply #1 on: August 19, 2009, 01:57 PM » |
I've asked about this a number of times and the answer to-date has been "too expensive to produce in the quality that Festool owners would accept", more or less. I really do want "native" square/Robertson drive bits as I use those fasteners exclusively when I have the choice. I've "made" some from off-the-shelf bits using my lathe and a file to make do, but it's just not the same as a native solution. Very frustrating.
“Never raise your hands to your children, it leaves your groin unprotected.†- Red Buttons
PeterK
Online
« Reply #2 on: August 19, 2009, 02:10 PM » |
Not sure where to place the blame here - McFeelys for convincing me to convert to all square drive?  Festool for not adopting and adapting the bits?
bionicus
Offline
« Reply #3 on: August 19, 2009, 03:37 PM » |
This is odd to me. I won't even consider Festool drills until they adopt Robertson bits. In Canada they're the standard for wood screws, and for good reason.
Brice Burrell
Offline
Remodeling Contractor
« Reply #4 on: August 19, 2009, 04:52 PM » |
Problem solved.  I don't get all the fuss and certainly don't get why you'd let this prevent you from owning a great product like Festool's drills.
Alex
Offline
« Reply #5 on: August 19, 2009, 05:13 PM » |
Why would it be too expensive, and who exactly told you so? I can't see why a Robertson bit would have a different cost than a Pozidrive, Torx or a Philips. And if you're desperate to have one, what so difficult about making one yourself? As far as I know, the square is one of the most basic geometric forms. All you need is a steady bench grinder. Take an existing Centrotec bit and grind it down to a square. Easy as pie. In Canada they're the standard for wood screws, and for good reason.
What exactly is so fantastic about Robertson bits over others? Here in Europe, I NEVER encountered one. I knew they existed because I had to learn about them when I was in college for mechanical engineering, but I never saw them in practice. Here Pozidrive is the standard for wood screws and Torx is slowly but surely becoming the standard in industrial applications. ------ But guys, keep mentioning it here on the Forum and perhaps one day Festool will come to realise they need to expand the spectre with one more bit.
bionicus
Offline
« Reply #6 on: August 19, 2009, 06:30 PM » |
Those holders aren't really the perfect solution. In my experience, at least with Robertson heads, the bits will often enough pull out, remaining stuck in the screw once you've driven it into the wood. Given that probably 95% of the screws I drive have Robertson heads, this tends to become a bit aggravating. I believe Festool might also make a holder with a quick release chuck to use with standard 2" bits, but again, you're adding to the length and space required to maneuver your drill into position, which is sometimes a commodity. I'm nitpicking, I know, but I think that's allowed if we're talking about a premium product here.
As for why I prefer Robertson over Phillips heads, the only other widely available option around here, basically it comes down to how well they grab onto each other before you've even set your screw against wood. With the recessed square in the screw you can pretty much get away with doing things one-handed and don't have to worry so much about gravity interfering. Assuming your bit hasn't rounded over too much with use, the screw sort of locks on. Pozidrive may be the same way, I don't have nearly as much experience with them.
At any rate, I'd just like to see centrotec Robertson bits made available. Make things tempting for me, that's all.
Tom Bellemare
Festool Dealer
Offline
« Reply #7 on: August 19, 2009, 07:24 PM » |
I know a lot of people over here like Robertson heads but I'm partial to torx...
Phillips was intentionally designed to torque out so the screws can't be broken, which has its value. They make assembly more difficult since they won't stay on the driver. With modern drivers using good clutches they should become extinct or relegated to hand tool applications only.
« Last Edit: August 19, 2009, 07:24 PM by Tom Bellemare »
woodshopdemos
Inactive Member
Offline
« Reply #8 on: August 19, 2009, 07:46 PM » |
Jim, Try thte other way around. Get some of the larger Centrotec bits and file down end to make square.
In memory of John Lucas (1937 - 2010)
Brice Burrell
Offline
« Reply #9 on: August 19, 2009, 08:35 PM » |
Bionicus, I use being bit facetious in my reply. You're right the dive tips do come out often on square drive screws and it can be a hassle.
Alex
Offline
« Reply #10 on: August 19, 2009, 08:50 PM » |
If Philips is the only alternative then I can understand the popularity of Robertson. I don't like Philips at all, the grip is very bad. Only thing worse than Philips is the plain old groove. Pozidrive has an excellent grip on the other hand. You can get away with a lot of things one handed, even though it does require some balancing sometimes. It is not as good as Torx. But then again, Torx was developed to be used in automated assembly lines, so that the screws would stick on the robot drill bits. I guess Robertson is more or less the same as Torx, when you look at the grip. But you're saying you hardly got Pozidrive in America? Didn't know that. There's still so many differences in the small things, between our cultures.
Brice Burrell
Offline
« Reply #11 on: August 19, 2009, 09:27 PM » |
Alex, the only thing we have Pozidrive for here in the US is Euro hinge hardware, we really don't see it anywhere else. Phillips and slotted were pretty much all we had here, in the last 5-6 years the popularity of square and torx has grown tremendously. Phillips is by far the most used type used and for years that was the only option. When that's all you know it works out fine, I don't have a problem with them at all.
kdzito
Offline
« Reply #12 on: August 20, 2009, 11:22 PM » |
I prefer the Apex brand bits. Hey, most of all I prefer the quick change bits. I use the adapter and also have a non-Festool driver with the quick change chuck. Although I have many Festools, I'm not familiar with their drill/drivers. The Apex bits seem to last a little longer without losing grip. I just used Apex #1 and #2 square bits on square drive #6 & #8 trim screws.
To build with my two hands is a creative outlet.
EcoFurniture
Offline
« Reply #13 on: August 21, 2009, 12:24 AM » |
If Philips is the only alternative then I can understand the popularity of Robertson. I don't like Philips at all, the grip is very bad. Only thing worse than Philips is the plain old groove. Pozidrive has an excellent grip on the other hand. You can get away with a lot of things one handed, even though it does require some balancing sometimes. It is not as good as Torx. But then again, Torx was developed to be used in automated assembly lines, so that the screws would stick on the robot drill bits. I guess Robertson is more or less the same as Torx, when you look at the grip. But you're saying you hardly got Pozidrive in America? Didn't know that. There's still so many differences in the small things, between our cultures. hey Alex, I'm from Germany, moved to Canada 8 years ago. Woodworker/Cabinet maker for more then 20 years... Let me tell you, everything is different here when it comes to wood working! The designs, materials building method, tools, hardware, standard dimensions... just everything! The first little while I thought I have to learn everything again! Anyhow, I'm so glad we can get German tools here! I even drive a VW Eurovan Cargo.... I tried to become friends with North American vehicles and supplies, couldn't believe that anyone is buying that stuff.... I now own my own little company and make my own rules on how stuff gets build
alanz
Offline
« Reply #14 on: August 21, 2009, 07:09 AM » |
If the bits sometimes pull out of the extension/adapter... why not just glue the bit into the adapter? The only downside (or is it an upside) is that the bit with the extension is longer than a native bit.
Triton 2.25 router; CMT Industrio table; Jointech fence; SC planer; Dewalt miter; Delta 14" bandsaw; Festool TS55, MFT/3, CT22, ETS150/3, OF1400, PSB300EQ; Dewalt Scrollsaw; Nova DVR XP lathe, JJ-6CS jointer, Ryobi OSS; Grizzly 1023s cabinetsaw
Daniel_n
Offline
« Reply #15 on: August 21, 2009, 08:43 AM » |
If Philips is the only alternative then I can understand the popularity of Robertson. I don't like Philips at all, the grip is very bad. Only thing worse than Philips is the plain old groove. Pozidrive has an excellent grip on the other hand. You can get away with a lot of things one handed, even though it does require some balancing sometimes. It is not as good as Torx. But then again, Torx was developed to be used in automated assembly lines, so that the screws would stick on the robot drill bits. I guess Robertson is more or less the same as Torx, when you look at the grip. But you're saying you hardly got Pozidrive in America? Didn't know that. There's still so many differences in the small things, between our cultures. hey Alex, I'm from Germany, moved to Canada 8 years ago. Woodworker/Cabinet maker for more then 20 years... Let me tell you, everything is different here when it comes to wood working! The designs, materials building method, tools, hardware, standard dimensions... just everything! The first little while I thought I have to learn everything again! Anyhow, I'm so glad we can get German tools here! I even drive a VW Eurovan Cargo.... I tried to become friends with North American vehicles and supplies, couldn't believe that anyone is buying that stuff.... I now own my own little company and make my own rules on how stuff gets build  What do you think about the square drives and bits? I understand that they are quite common in Canada (perhaps the US as well?), but they are rarely used in Sweden (torx and to some extent Pz are moste common, and of course Ph for drywall). However, I don't know what you usually use in Germany? Perhaps you were already familiar with square drivers?
ForumMFG
Offline
« Reply #16 on: August 21, 2009, 08:51 AM » |
In my shop all we use are square drive bits. Thats all I use at home as well. In fact, you would find the sqaure drive screw & bits are the most commonly used screw in central ohio. I have not ventured out to other shops outside of central ohio but I'm sure it's pretty common in ohio. The screws stay in the bit, they torque down great. I buy #8 square drive flat head w/ nibs, Type 17 thread w/ auger point
Alex
Offline
« Reply #17 on: August 21, 2009, 06:07 PM » |
I now own my own little company and make my own rules on how stuff gets build   Ah yes, since we got no army of our own, this is how we set out to conquer the Americas, one man at a time.
EcoFurniture
Offline
« Reply #18 on: August 21, 2009, 09:35 PM » |
EcoFurniture
Offline
« Reply #19 on: August 21, 2009, 09:38 PM » |
What do you think about the square drives and bits? I understand that they are quite common in Canada (perhaps the US as well?), but they are rarely used in Sweden (torx and to some extent Pz are most common, and of course Ph for drywall). However, I don't know what you usually use in Germany? Perhaps you were already familiar with square drivers?
Well, there not that many other options... you go to your supplier and all there is are square and + screws. That's it. I don't hate them but also don't like them.
Les Spencer
Offline
Location: Plainfield, Indiana USA Member Since: Jan 2007
« Reply #20 on: August 21, 2009, 10:04 PM » |
Those holders aren't really the perfect solution. In my experience, at least with Robertson heads, the bits will often enough pull out, remaining stuck in the screw once you've driven it into the wood. Use this holder and the driver bits won't pull loose. Personally, I use torx drive screws from Screw Products. heck of a screw. Rarely is pre-drilling required. Especially if you lube with bees wax.
Les (near Indy) XL
KorDes
Festool Dealer
Offline
« Reply #21 on: August 22, 2009, 07:51 PM » |
Over here in New Zealand I've been using square drives since I left school. About 13 years ago now. And thats all we use in the furniture trade apart from small pozi screws for metal runners/hinges.
I don't see what the big deal is, just buy the adapter Les Spencer has recommended and you can use any bit you want without them pulling loose.
As for torx screws, they are alot darer than square screws over here so its more economical to use square screws.
HowardH
Offline
« Reply #22 on: August 25, 2009, 09:08 PM » |
I recently got a T15 and it is indeed aggravating not to have a centrotec square drive bit. I hate phillips  screws. They always strip out when you least need them to. It's difficult to find PZ screws in the US so that leaves Torx if you want to go the Centrotec route. They also are hard to find. The big box stores still only carry phillips or slotted screws for the most part. I ordered quite a few different sizes from McFeeley's a couple of years back in the square drive and they worked fine. If I can get my hands on a good selection of Torx, I'll order em get a Centrotec bit to match.
Howard H The Plano Texas Festool Fanatic!
Shelby Metcalf, basketball coach at Texas A&M, recounting what he told a player who received four F's and one D: "Son, looks to me like you're spending too much time on one subject."
mft1080, T15, RO150FEQ, TS55, RTS400, ETS 150/3, OF1400, CT22, CT33, MFS 400 & 700, Boom Arm, 800, 1080, 1400, 1900 rails CSX drill Qwas dogs
Steve-CO
Offline
« Reply #23 on: August 25, 2009, 10:47 PM » |
Rockler carries a variety of Torx screws, http://www.rockler.com/product.cfm?page=21415
Martin Johnson
Offline
« Reply #24 on: August 26, 2009, 12:10 PM » |
If you already have your favorite square drive bits...this might work.
WarnerConstCo.
Offline
« Reply #25 on: August 27, 2009, 08:21 PM » |
GRK, best screws out there. All Torx head. Torx is the only way to go. Personally, I hate #1 and #2 square drive screws, with a passion.
GRK, they are made overseas, do you people not get out much?
Dan Rush
Online
Trim carpenter
« Reply #26 on: August 27, 2009, 08:34 PM » |
Hey Warner,
I made the jump to square drive a few years ago. I now hate Phillips with a passion. Is the jump from square to Torx the same leap? Keep in mind I install cabinets, so I don't need heavy torque, but I'm thinking of moving up, so any thoughts would be appreciated.
Thanks, Dan
Jimhart
Offline
« Reply #27 on: August 27, 2009, 09:21 PM » |
I wonder if Festool would be unhappy with McFeeleys if they had a bunch of Centrotec compatible square drive bits custom ground. Seems like a marriage made in heaven, considering they probably sell as many square drive screws as anybody in the US, and they're a Festool dealer as well.
Bundle them with the screw filled systainer packages.
Jim
Les Spencer
Offline
« Reply #28 on: August 27, 2009, 09:46 PM » |
Jim,
Good thought and was discussed by Jim McNeeley when he was a member of this forum. At that time he couldn't get Festools blessing. He has since sold the business and nothing more has been mentioned. Not sure if it ever will be. It would be nice if someone from Festool would chime in.
Les (near Indy) XL
WarnerConstCo.
Offline
« Reply #29 on: August 28, 2009, 12:07 AM » |
Hey Warner,
Thanks, Dan
http://www.grkfasteners.com/en/CAB_1_information.htmAll I use for cabinets. Actually, they are the only screw I use besides drywall screws for drywall. Find some, try them, never look back.
b_m_hart
Offline
« Reply #30 on: August 28, 2009, 01:21 AM » |
Why are the GRK fasteners better than square?
TS 55 EQ, ETS 150/5, RO 150 FEQ, OF 1010 EQ, DF 500 Q, C12, CT Midi, OF 2200 EB, MFT/3s, DTS 400 EQ, parallel guides, and seemingly growing by the day...
ForumMFG
Offline
« Reply #31 on: August 28, 2009, 07:05 AM » |
Check out this Tip Magnet from Fast cap. It's a like cylinder that you slide on your bit. You slide it all the way down to the chuck or where ever you want and it turns your bit into a magnet. It's so strong that it transfers into the bit and holds the screw on. It's really nice. I figured since we are talking about bits this would be a good place to post this. Click here for the link or http://www.fastcap.com/tip-magnet.aspx-Dave
WarnerConstCo.
Offline
« Reply #32 on: August 28, 2009, 10:57 AM » |
You guys need to look at Wera's stuff.
The thing with the GRK's is they can be used anywhere in any material.
ForumMFG
Offline
« Reply #33 on: August 28, 2009, 11:10 AM » |
Stainless steel screw drivers and bits, Nice..
ForumMFG
Offline
« Reply #34 on: August 28, 2009, 11:22 AM » |
Warner, I just checked out their site. Looks like some good stuff. Do you use them? What do you think?
-Dave
Update: Who sells them? I couldn't find pricing on the stainless steel ones.
« Last Edit: August 28, 2009, 12:28 PM by ForumMFG »
WarnerConstCo.
Offline
« Reply #35 on: August 28, 2009, 04:49 PM » |
I tend to stay away from stainless steel screws, they seem very soft, at least the ones that come with all the hidden fasteners for decking. Never used the GRK stainless. Never had the need since their other screws can be used with any material. You are in ohio so lets see: http://www.grkfasteners.ca/grk/servlet/GRKFindRetailer?imstate_prov=Ohio
WarnerConstCo.
Offline
« Reply #36 on: August 28, 2009, 04:51 PM » |
As for Wera, I have a dealer for them I know in Michigan, Wera's stuff can be hard to get ahold of. One of thier diamond dust #2 phillips tips has lasted me over a year. I promise it is the same one I have not lost it (C12 bit storage works wonders huh?)
Steve Rowe
Offline
« Reply #37 on: August 28, 2009, 05:01 PM » |
And all this time (thread started 2-1/2 years ago with no responses until the last week), I thought I was the only one that wanted square drive bits for the Centrotec.
Since Festool obviously has no interest in providing bits that work for screws commonly available in NA, I went out and found my own solution. It is the Makita 18v Impact Driver and it accepts all the bits that I need or can ever see wanting. It also works great. I also prefer the APEX bits. Now, I seldom use my Festool drill/driver.
Neill
Offline
« Reply #38 on: August 28, 2009, 05:26 PM » |
Steve, This may be a bit off topic and maybe a bit argumentative. Don't get me wrong, I love my Festools and Customer Service goes above and beyond to assist us users. It does seem that Festool often times wants to tell us what we want rather than providing what we need. The philosophy seems to be, if we don't make it, you don't need it. The square drive bits for the Centrotec seems to be indicative of this. I have actually read where a poster to this Forum made a comment about how Festool has done us a favor by selling their tools in North America. Oh, please! I have used the square drive bits with the Jacobsen chuck in my kit and with the Festool bit holders but it is just not the same. I wonder if a supplier like McFeeley's who champions the square drive screw and also sells Festool would be interested in developing a compatible bit. They may be hesitant because of their relationship with Festool. They don't seem to have any difficulty with selling their square drive screws packaged in a systainer or sortainer. I am a hobbyist, so I can manage without a square drive Centrotec bit, but I sure would like to have one. Neill
Kapex, Domino, MFT/3, Rotex 150 FEQ, CT 22E, TS 55, C12 Drill, 1400 Router, Rotex 90 DX, Rotex 125 FEQ, LS 130 EQ Linear, Parallel Guide Set, Deltex 93 E, Trion 300 Barrell Grip, ETS 150/3 EQ, ES125 EQ, Guide Rail Accessory Kit, Sanding Block, various rails, systainers, sortainers, vacuum hoses and accessories for various tools.
Peter Halle
Global Moderator
Offline
« Reply #39 on: August 28, 2009, 06:11 PM » |
I wouldn't be surprised to find out that the Centronic shaft is patented and that is why nobody else will develop for it.
Frank Pellow
Offline
Location: Toronto, Ontario, Canada Member Since: Jan 2007
Toronto, Ontario, CANADA
« Reply #40 on: August 28, 2009, 06:31 PM » |
Festool has known about this requirement for at least 5 years.I am very disappointed in their lack of support.  My reaction is never to purchase another one of their drills (I do have a TDK 12) until they provide such bits. I know that it's not much pressure but, other than notes like this that seem to get ignored, its all that I can do. I am frustrated.
Cheers, Frank (Festool connoisseur)
WarnerConstCo.
Offline
« Reply #41 on: August 28, 2009, 06:46 PM » |
Are you guys dense, or just illiterate?
Wera makes the same shaft.
Jesus christ!!
And what the heck is wrong with the bit holder? I have no issues with it.
« Last Edit: August 28, 2009, 06:48 PM by WarnerConstCo. »
ForumMFG
Offline
« Reply #43 on: August 28, 2009, 08:03 PM » |
Thanks steve
Are the Wera stainless steel bits the way to go?
« Last Edit: August 28, 2009, 08:07 PM by ForumMFG »
Christian Oltzscher
Festool Employee.
Offline
« Reply #44 on: August 28, 2009, 08:50 PM » |
Hello,
We are well aware of the need of square drive bits with Centrotec shaft. It is not that we don't want to sell square drive bits. We are a company, our purpose is to sell product. And McFeely's is a company that wants to sell product. If we get requests for something, we look into it. Exactly this is what we did a long time ago, together with McFeely's.
So, why do we not have square drive bits in the program? It was not possible to find a supplier that could provide bits with Centrotec shank and square drive tips at an acceptable quality for an acceptable price. We had numerous samples and did tests both here in the US and in Germany in the R&D department. The manufacturer of our bits doesn't have any expertise in square drive tips. Square drive bit manufacturers couldn't manufacture the Centrotec shank at an acceptable price at the quality level Festool requires.
Yes, we want to fulfill all of your wishes, and we would like to provide square drive bits. And no, we are not going to fulfill those wishes if we have to compromise on quality. We want to be sure that if we provide a product, it is at the quality level you came to expect from us.
Christian
Steve Rowe
Offline
« Reply #45 on: August 28, 2009, 09:05 PM » |
Jesus christ!!
I see no need to resort to name calling and hurling insults at other members of this forum. You want to know what is wrong with the bit holder OK - It is 0.02mm across the flats too small. Now I have no idea whether the ball detent will work in the centrotec or not and at this point, really don't care. The problem is more than just the centrotec, it expands to the eccentric chuck and right angle attachment as well. Neill is spot on regarding Festool telling us what we need instead of providing us what we want. It seems that if Festool marketing is smart enough to recognize that supplying 1/4" collets with their routers makes sense, the same argument could be made for centrotec bits.
ForumMFG
Offline
« Reply #46 on: August 28, 2009, 09:55 PM » |
Christian,
Thanks for the information. I didn't get the impression that Festool is still looking for a supplier? Knowing Festool, they are but it didn't sound like it. Secondly, it is shocking to me that it's so hard to produce a square drive bit at a affordable cost. Just by looking at the bit it does not look like rocket science and if you ask me, the square drive would seem to be one of the easy bits to make because it square. But, there's alot of things that go into the design of a product that a end user doesn't know about or appreciate or understand the complexity of it.
-Dave
Frank Pellow
Offline
« Reply #47 on: August 29, 2009, 08:22 AM » |
Hello,
We are well aware of the need of square drive bits with Centric shaft. It is not that we don't want to sell square drive bits. We are a company, our purpose is to sell product. And McFeely's is a company that wants to sell product. If we get requests for something, we look into it. Exactly this is what we did a long time ago, together with McFeely's.
So, why do we not have square drive bits in the program? It was not possible to find a supplier that could provide bits with Centronic shank and square drive tips at an acceptable quality for an acceptable price. We had numerous samples and did tests both here in the US and in Germany in the R&D department. The manufacturer of our bits doesn't have any expertise in square drive tips. Square drive bit manufacturers couldn't manufacture the Centronic shank at an acceptable price at the quality level Festool requires.
Christian
Christian, there are lots of manufactures of square drive screws and bits other than McFeely's. Are you continuing to attempt to locate such a company that can make the Centronic bits that we want? For example, have you contacted the Robertson Company ( http://www.robertsonscrew.com/) that invented square drive screws (or Robertson screws as they are better known in Canada)?
« Last Edit: August 29, 2009, 08:23 AM by Frank Pellow »
Anthony
Festool Dealer
Offline
Feel a bit like Rocko
« Reply #48 on: August 29, 2009, 08:40 AM » |
As mentioned by Martin, I find the Festool Centrotec adaptor with mechanical bit locking is the answer for me, so I can easily use square square drive bits I already have.
Charimon
Offline
Tool and Tile Junkie
« Reply #49 on: August 29, 2009, 01:32 PM » |
Christian, there are lots of manufactures of square drive screws and bits other than McFeely's. Are you continuing to attempt to locate such a company that can make the Centronic bits that we want? For example, have you contacted the Robertson Company ( http://www.robertsonscrew.com/) that invented square drive screws (or Robertson screws as they are better known in Canada)? Frank I looked on the site you just listed and on http://www.robertsonscrew.com/product_4100.html the last line states. "Other types and styles of drivers and bits made to order. " Why don't we just have some made. find out how much they would run for a batch and see if they would drop ship them direct to FOGers Craig
« Last Edit: August 29, 2009, 01:32 PM by Charimon »
"The existence of the flame thrower proves that at one time, somewhere, somebody said, " You Know, There's a group of people over there that I'd like to set on fire right now but they're too far away."
ForumMFG
Offline
« Reply #50 on: August 29, 2009, 03:46 PM » |
I bet you a production run is thousands.
Alex
Offline
« Reply #51 on: August 29, 2009, 06:07 PM » |
I don't know, but it sounds like a strange excuse. Having gone through engineering college myself (not finished though) I know that engineers get an incredible large amount of maths and trigonometry. I'm sure their engineers could work out the shape of the bit, even if they never made one before. They also learn a lot about material properties and I'm also pretty sure they could work out a way to make the bits really strong. Square drive bit manufacturers couldn't manufacture the Centrotec shank at an acceptable price at the quality level Festool requires.
That's weird. Acceptable price? Other manufacturers have no problem putting quality bits on the market for less than half what Festool charges.
Jim Becker
Offline
« Reply #52 on: September 01, 2009, 10:28 AM » |
I use it. But it has the disadvantage of extending the length of the drill/driver/bit combination and obviating some of the compact advantage of the Festool product. --- At this point, I remain skeptical about the supposition that quality Robertson/square drive bits cannot be manufactured in a Centrotec format at an acceptable price point. In fact, I would think that they would be easier to make than the more complicated Posidrive and Torx formats, even with the subtle tapering that's required. CNC machines are pretty good at that...
« Last Edit: September 01, 2009, 10:37 AM by Jim Becker »
lcc
OfflineMember Since: Aug 2009
« Reply #53 on: September 03, 2009, 06:53 AM » |
Hi,fellow festool fanatics; just use a grinder to knock the edges of of the hex of a 2" long #1,#2,#3 square drive and grind a detent relief so that it is captured in the chuck.Don't grind a tip you will lose the surface hardness. All ss exterior finish and inside finish screws are now Robertson drive.There are other "phillips" type screws,reed and prince,phearson these two previous are used in wooden boat building.one size bit will fit #4 to an #16 screw. The taper is the same , the cross grows exponentialy as the size screw increases and the shaft size of the bit gets larger yet they will work .
Brice Burrell
Offline
« Reply #54 on: September 03, 2009, 11:23 AM » |
I use it. But it has the disadvantage of extending the length of the drill/driver/bit combination and obviating some of the compact advantage of the Festool product. Jim, this is where I don't understand the problem, Festool's Centrotec bits are as long or longer than the locking bit holder and screw driver tip. The advantage Centrotec bits have over the the locking bit holder is a smaller diameter so they'll fit into a deep recess like a pocket screw hole. The need for is deep recess ability is very limited and can easily be accomplished by using a regular long bit in the keyless chuck. I don't mean any disrespect but I think people have really blown this issue out of proportion. At this point, I remain skeptical about the supposition that quality Robertson/square drive bits cannot be manufactured in a Centrotec format at an acceptable price point. In fact, I would think that they would be easier to make than the more complicated Posidrive and Torx formats, even with the subtle tapering that's required. CNC machines are pretty good at that...  That's my knee jerk reaction too but giving it more thought I'm not so sure. My understanding is the price to manufacture something goes way up once the tolerances pass a certain point, that could be the case here. And we have no idea what Festool considers an acceptable price.
Tom Bellemare
Festool Dealer
Offline
« Reply #55 on: September 03, 2009, 12:27 PM » |
just use a grinder to knock the edges of of the hex of a 2" long #1,#2,#3 square drive and grind a detent relief Though a regular hex drive bit can be ground to fit into the Centrotec chuck, it must be deep enough to engage the internal hex of the output shaft of the drill. The image below shows the anatomy of the Centrotec system. The part in blue is the output shaft of the drill...  Tom
lcc
« Reply #56 on: September 03, 2009, 01:22 PM » |
There is no problem with that on non tapered shafts the detent is matched up to festools bit. I have a set of high speed drills and bits with hex all ground to fit centrotec. I wish that I could make vix bits work but the shafts are too short.
HowardH
Offline
« Reply #57 on: September 07, 2009, 07:32 PM » |
I second the GRK screws. I found some locally at Rockler, they had a decent selection and when combined with the centrotec Torx pattern bits, they work great! It's nice being able to quickly switch between the driver and drill bits and those torx patterns simply don't slip. I always thought one screw is like another (don't go there, please  ) but there is a difference! I have a supply of square drive I have to use up but after that, it's GRK all the way. I will need to buy a few thousand of them this fall when I replace my deck. Their composite screws should work well.
Martin Johnson
Offline
« Reply #58 on: September 08, 2009, 09:40 AM » |
I like the GRK as well. The guys here like both Wurth and GRK...I tried the the GRK for the first time this week, as Rockler carried them, and I stocked up on about $70 of various lengths...I've used square drive and like them as well, but I have to confess that I am now a GRK Torx convert. They went into hard maple and maple ply clean as a whistle, no pre-drilling and no tear-out when they went below the surface.
« Last Edit: September 10, 2009, 03:16 PM by Martin Johnson »
WarnerConstCo.
Offline
« Reply #59 on: September 08, 2009, 09:48 AM » |
Glad to see you guys were able to use some of the GRK's and were happy with them.
The only screw I have been using for the last few years, minus drywall screws for drywall.
The GRK's are champs. Torx heads are the way to go, no slip out.
Jim Becker
Offline
« Reply #60 on: September 08, 2009, 10:45 AM » |
Been there, done that--put them in a spigot chuck on the lathe and used some files to adapt them. It works. But it's not ideal and certainly not as precise as a native solution would hopefully be.
ForumMFG
Offline
« Reply #61 on: September 08, 2009, 08:26 PM » |
I second the GRK screws. I found some locally at Rockler, they had a decent selection and when combined with the centrotec Torx pattern bits, they work great! It's nice being able to quickly switch between the driver and drill bits and those torx patterns simply don't slip. I always thought one screw is like another (don't go there, please  ) but there is a difference! I have a supply of square drive I have to use up but after that, it's GRK all the way. I will need to buy a few thousand of them this fall when I replace my deck. Their composite screws should work well. Got a website link?
HowardH
Offline
« Reply #62 on: September 08, 2009, 10:08 PM » |
http://www.grkfasteners.com If they don't make it, you probably don't need it...
Joe Jensen
Offline
« Reply #63 on: September 10, 2009, 01:49 AM » |
I have to admint, I was a "No square drive Festool hater" until I found the Centrotec Bit Holder "Bhs 65mm". Here is a link; http://www.festoolusa.com/products/cordless-drills/centrotec-drill-bits/pilot-bit-with-depth-stop/centrotec-bit-holder-bhs-65mm-492648.htmlIt has a locking collar, and with short hex shank bits, it's not longer combined than a Centrotec Festool bit. The only downsides are that it is slightly floppy, but way better than more magnetic holders. And, if you have a recess and need a longer shaft bit, the combo would likely be longer than a Centrotec bit. I'd prefer a centrotec solution, but this $29.50 locking collar bit holder is darn good.
bill-e
Offline
Location: Rindge, New Hampshire, USA Member Since: Jan 2007
« Reply #64 on: September 10, 2009, 10:18 AM » |
This does seem like a good compromise for those times when diameter isn't an issue. I have to admit the biggest complaint I have about using square drive bits in the Centrotec bit extender is leaving the bit stuck in the screw head.....this would solve that. But for those occasions were you dont want the extra bit diameter or bit length, a Centrotec bit would sure be nice. I'd even be happy to pay less money for a lesser quality Centrotec bit.
thinkingdog
Offline
Location: Illinois, Michigan UP & Wyo - USA Member Since: Aug 2009
« Reply #65 on: September 10, 2009, 12:41 PM » |
Another dedicated endorser of the GRKs. They are excellent!
Joe Jensen
Offline
« Reply #66 on: September 10, 2009, 01:03 PM » |
Anyone want to buy the couple hundred dollars worth of square drive screws and bits I bought from McFeelys last year  I'd like to switch, but a gradual shift isn't very fun or workable, and I hate to dump all the square drive I have. Also, is there a great online source ala Mc Feelys for the GRKs?
HowardH
Offline
« Reply #67 on: September 10, 2009, 08:36 PM » |
their videos are something else. They can make a screw 3' long!  Of course the demo would have been better had they used a T15 to drive them. These guys have them but I have never purchased anything from them.
Shawn
Festool Dealer
Offline
Location: Toronto, Ontario, Canada Member Since: Oct 2009
« Reply #68 on: November 18, 2009, 10:19 PM » |
Robertson would be key! It is time!
Dan Clark
Offline
« Reply #69 on: November 18, 2009, 10:55 PM » |
These guys have better prices and a MUCH better selection: http://www.buygrkfasteners.com/. Here's a GRK info site: http://www.grkfasteners.com/ . Here's another vendor that carries nothing but Torx screws: http://screw-products.com/ I've bought maybe two thousand screws from them. Not a good as GRK, but pretty decent and the prices are better. Dan.
« Last Edit: November 19, 2009, 11:00 AM by Dan Clark »
jvsteenb
Offline
« Reply #70 on: November 19, 2009, 06:28 AM » |
Doesn't look like Torx to me..... The inner and outer edges of a Torx profile are rounded, which is actually a design parameter. It helps to distribute the torque load over a wider part of the circumference, reducing wear significantly and increasing effectiveness when slight wear or minor misfitting occurs. Those are stardrives - they've been around a while, be it obscure. There's also a 12-point version, that was used in large bolts that had to be torqued very precisely. European car manufacturers used these 12 point stardrives on cilinderhead bolts, especially the "stretched" single-use bolts. They may still use them, but the majority is Torx now..... Come on guys, get aboard the Torx-train.... you won't regret.  Regards, Job
TS55, OF1010, RO150, RTS400, PS300, T15+3, CTL22E, CMS-TS55+Basis5A (OF1010), MFT/3, MFS400/700, FS800-1080-1400-1900, Centrotec-SYS 09, DF 500 full set, some accessories
Dan Clark
Offline
« Reply #71 on: November 19, 2009, 10:54 AM » |
Job, They're Torx. Check out the drawings and pics on the first page of the catalog: http://screw-products.com/pdfs/spi-retail.pdf. I've used Screw-Products, GRK, and other brand screws with Torx bits. GRK are better quality, but the heads are the same. I'm pretty sure they call them "Star Drive" because they think it's a more marketable name for Americans. They sell bits in T10 to T40 sizes: http://www.screw-products.com/drive-bits.htm. Hmmm... I wonder what the "T" means?  Dan. p.s. I've been on the Torx-train for years. I don't understand the reticence to move in that direction.
Steve-CO
Offline
« Reply #72 on: November 19, 2009, 10:58 AM » |
Dan, Thanks for the links, one thing about your links, when you include a "period" at the end of them they don't work unless the period is deleted.
Dan Clark
Offline
« Reply #73 on: November 19, 2009, 11:16 AM » |
Dan, Thanks for the links, one thing about your links, when you include a "period" at the end of them they don't work unless the period is deleted. Steve, Thanks for the heads-up. It's fixed now. Unfortunately this is a problem with some forum software packages (like SMF) because they include periods when they parse the url address. When you place a url at the end of a sentence (like I normally do) and end the sentence with a period, the SMF software includes the period with the link. It's irritating. Other software packages (like vBulletin) don't have this problem. When you include a URL address and close it with a period, the software ignores the period when creating the link. So why doesn't Festool move to the another forum software package? Because it's huge effort when you have a well-established, customized forum like FOG. Other forum packages have some nice features, but I don't think it's worth the risk and effort to convert. I wouldn't do it and don't recommend it to others. Regards, Dan.
« Last Edit: November 19, 2009, 11:17 AM by Dan Clark »
Shane Holland
Festool USA Employee FOG Administrator
Offline
« Reply #74 on: November 19, 2009, 11:21 AM » |
Torx is a trademarked brand and you have to pay a license to use that name. Star drive is the same thing without paying the licensing basically. That's my understanding from my days at a certain screw retailer.
jvsteenb
Offline
« Reply #75 on: November 19, 2009, 12:06 PM » |
OK Dan, you've convinced me - sort of. The link to the PDF you supplied sported some Torx heads, though some of the recesses look a bit "off-standard". There's only two Torx profiles: the Torx and the Torx-Plus ( slightly wider lobes, far less common ), the profile's ratio's are the same throughout the size range. ( And there's TTAP, and ofcourse tamper-resistant versions of the lot ) It's just that the picture you linked to in your earlier post doesn't really resemble a Torx profile, it's "edgy" instead of "lobe-like", and that nullifies part of the advantages. And apart from that, the name "star drive" has been used for the sharp-edged variant in 6- and 12-point (more common, aka spline-drive) configuration as well, and they've been around longer than Torx, for as far as I know - hence my confusion. Anyhow: I'm glad you're aboard the Torx-train - it's a smooth ride, isn't it ? I think I can conclude with a piece of advice that both parties can relate to: Screw Robertson !  Regards, Job
Brice Burrell
Offline
« Reply #76 on: November 19, 2009, 12:31 PM » |
.... Screw Robertson !  Regards, Job Unless you're a Canuck (Canadian) and then you're getting screwed by Robertson because that's all you can get up there.
Forrest Anderson
Offline
« Reply #77 on: November 19, 2009, 05:28 PM » |
Doesn't look like Torx to me..... The inner and outer edges of a Torx profile are rounded, which is actually a design parameter. It helps to distribute the torque load over a wider part of the circumference, reducing wear significantly and increasing effectiveness when slight wear or minor misfitting occurs. Torx is a trademarked brand and you have to pay a license to use that name. Star drive is the same thing without paying the licensing basically. That's my understanding from my days at a certain screw retailer.
I agree with Job (jvsteenb) and Shane. The photo at http://screw-products.com is this:  Although the patent has lapsed, TORX is still a trademarked name in the USA, Canada, UK and other other countries and Acument Global Technologies allow selected manufacturers to manufacture TORX products under license. They naturally take a poor view of manufacturers making look-alike products, as the following except from their TORX Drive System brochure shows (note the curved walls of the "Authentic TORX Drive bit"):  Their Licensing Program Review brochure shows that they hunt down companies of items which are sold TORX, but are not the genuine licensed article or manufactured to the correct standards:
Trademark Usage and Counterfeits Our licensed product trademarks are currently registered in 78 countries and registered with United States Customs. Our trademarks are known and recognized worldwide. It is imperative that any product infringement is stopped immediately. By not doing so, end users not only receive an inferior product, but the product could become unrecognizable in the marketplace and take on a generic connotation. We then run the risk of losing our reputation in the marketplace. We are very active in the pursuit of counterfeit activity. We attend trade shows, review trade journals, and do key-word searches on the internet. We also rely heavily on our licensees to report violations. We are committed to pursue all trademark infringements and counterfeits brought to our attention and will use any resources, including legal action, to protect these trademarks and patents. We are protecting not only our interests, but the interests of our licensees. As a licensee, training on how to spot illegal product is an important part of the package. The confidential product binders go into detail explaining the proper usage of the trademarks so there is no mistaking a genuine product versus a fake.
To get round these legal problems, manufacturers of TORX-like items often call them "star drives" or "star bits" or something similar. They don't have to pay a license fee or make them to the strict TORX standards, but that naturally means that the shape of the star recess will vary a bit from manufacturer to manufacturer. That, in turn, means that getting a good fit between bit and screwhead can be difficult. A good example of this is the screw-products.com own brochure, where close examination of a selection of their "Star Drive" heads will reveal several different designs:  Forrest
« Last Edit: November 19, 2009, 06:07 PM by Forrest Anderson »
Inner10
Offline
« Reply #78 on: November 20, 2009, 12:45 AM » |
We have decent access to TORX screws through Fastenal up here.
TORX is excellent for hi-torque applications, all my concrete screws are TORX. For softwoods the robertson is king since it holds itself on the drive better without the use of a magnet. Too bad we can't all standardize on the Wurth screws with their special tapered star-type end.
jvsteenb
Offline
« Reply #79 on: November 20, 2009, 12:05 PM » |
Especially for these applications, there's TTAP. It's an authentic Torx profile ( acually I should state TORX profile ) with a small cilindrical cone added to the tip of the driver/bottom of the recess. It may be driven with a standard Torx bit, but then you don't get the added advantage of the hold-fast wedging action. However: I get around with standard Torx, they don't tend to fall off, even when screwing top-down a simple magnetig bitholder is enough to hold the screw, and they NEVER stick in the screw when done ( the main reason a standard hex-drive will drive me nuts from time to time instead of just driving nuts ( and bolts and screws, of course ).
Another nice design is the UniScrew, it's sort of a stepped hex-drive that has only one bit-size. The depth of the recess varies with the screwsize, and determines how much of the size-steps are actually used. In a pinch, they can be loosend with a standard hex key. Nice design - having only one bit size without the usual trade-offs is a big pro. I like 'm a lot, but they're far from common.
Regards,
Job
Inner10
Offline
« Reply #80 on: November 20, 2009, 12:39 PM » |
Im sure its not as big of an issue with wood, but in concrete TORX is so reisitant to cam-out that you can easily snap the head off your fastner when using an SDS drill to drive them (or other big drill that offers poor control).
jvsteenb
Offline
« Reply #81 on: November 20, 2009, 12:55 PM » |
I would imagine so..... It's also easy to snap the head of an M8 bolt with a 3' extension bar on your spanner...... Still I would be way more p*ssed if the head rounded over, or the spanner gave up.
Regards,
Job
Joe Jensen
Offline
« Reply #82 on: December 13, 2009, 03:52 PM » |
I gave up on Robertson bits for the Festool. Just ordered a full assortment of Torx from GRK. 100 or like 20 sizes. Anyone want to buy an assortment of Robertson from McFeelies
William Herrold
Offline
"failure is imminent"
« Reply #83 on: December 26, 2009, 12:34 PM » |
I have two boxes of Kreg screws (shipping to Sweden cost more than the screws) so I'm going to jump on the wagon here with the square-drive plea. Another thing, I ordered the 2008 centrotec doodad systainer and was really bummed to find that there was no centrotec locking bit holder(bhs65mm) in the box.
"I don't believe anything, but I have a lot of suspicions" R.A.W.
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #84 on: December 28, 2009, 02:25 PM » |
This does seem like a good compromise for those times when diameter isn't an issue. I have to admit the biggest complaint I have about using square drive bits in the Centrotec bit extender is leaving the bit stuck in the screw head.....this would solve that. But for those occasions were you dont want the extra bit diameter or bit length, a Centrotec bit would sure be nice. I'd even be happy to pay less money for a lesser quality Centrotec bit. Don't bet on the Festool Centrotec bit holder BHS 65 extension (Item 492648) working that well. I recently received mine and upon comparing its function to my nearly new Centrotec bit holder BH 60 (Item 492539) supplied with my new T 12 +3 drill set, I found that can pull the Festool supplied 25mm bits out of the BHS 65 with locking collar just as easily (or with as much difficulty, if you prefer) with my hand as from the BH 60 bit holder. In other words, the locking mechanism is not a true locking mechanism, but it does assist in release of the bit. I visually confirmed that the quick release collar on my BHS 65 was working properly in the sense that sliding the collar allows the detent gripping wire ring to retract. The BHS 65 is not worth the $29.50 in my opinion since both bit holders are magnetic which feature I like. Save yourself ~US$9.50 by buying the BH 60 bit holder, or least try it at the store before purchasing. The power of the magnet in the BH60 is sufficient to firmly hold 3/4 inch long Phillips head screws with the drill assembly pointing straight down. This is very handy for installation work. If there was a good combination bit holder, one that would equally well hold both wire detent and ball detent bits, that would be of value and use to me. Making your own Centrotec compatible [Robertson] bits appears to be rather simple, if you want to reduce the wobble of conventional bits of lengths longer than 25mm. The dealer that sold me my drill showed me what is different about Centrotec and how I could modify regular 1/4 inch hex drive bits to fit Centrotec. Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
Brice Burrell
Offline
« Reply #85 on: December 28, 2009, 03:32 PM » |
Dave, in regards to the BHS 65, I believe it is made to lock on to both wire and ball-detent bits. I borrowed the BHS from Dan Clark so I could comment on its function for my T15 review. While I didn't try to pull the bits outs of the BHS, I didn't have any trouble with ball-detent drill bit pulling out as I withdrew the bit from the hole after drilling. Have you tried using a ball-detent drill bit with your BHS? Maybe yours is bad.
RonWen
Retailer
Offline
« Reply #86 on: December 28, 2009, 04:59 PM » |
I gave up on Robertson bits for the Festool. Just ordered a full assortment of Torx from GRK. 100 or like 20 sizes. Anyone want to buy an assortment of Robertson from McFeelies  I'm somewhat disappointed in the McFeely's square drives -- they seem to cam out awfully easy. Where is the best deal on GRK torx screws?
Steve-CO
Offline
« Reply #87 on: December 28, 2009, 05:19 PM » |
I gave up on Robertson bits for the Festool. Just ordered a full assortment of Torx from GRK. 100 or like 20 sizes. Anyone want to buy an assortment of Robertson from McFeelies  I'm somewhat disappointed in the McFeely's square drives -- they seem to cam out awfully easy. Where is the best deal on GRK torx screws? Rockler carries a limited supply of GRX or try here
Alex
Offline
« Reply #88 on: December 28, 2009, 10:33 PM » |
I guess yours must have a little defect because after reading this I tried to pull a couple of different bits out of my BHS 65 but I didn't succeed one time. They were all secured very tightly. Over all it functions quite ok but I do have some annoyances with it. I am used to work with a bit holder that, I'm sorry to say, was of much higher quality than this BHS 65 yet was a whole lot cheaper, namely 5 euros against the BHS 65's 27 euro. I got the other holder for over 10 years now and there's not a dent nor a spec of rust on it and it still works as it should. It's simply indestructible and the moving collar has a very smooth action. The BHS 65's collar on the other hand doesn't move so well I think. It's a bit wobbly and it sometimes gets stuck behind the ring around the nozzle opening. It also feels a bit rough, as if you move the collar over sanding paper whereas my old bit holder's collar just glides with great ease. I also think the magnet in the BHS 65 is way too strong. It is not needed to hold the bit. In fact, it makes removing the bit too much of a hassle. Very often do I need to put a lot of force into gripping the little part of the bit that sticks out to take it out. It might be nice if you want to drive a screw into something and stick the screw on the bit. But when you have to loosen a screw, I find it pretty irritating that every screw keeps sticking onto it and you have to remove them by hand. Finally, I think the tip of the BHS is too wide. If a screw is sunken a bit deeper into the material the tip of the BHS will hit the material. On my older bit holder the tip was beveled so the bit holder could get deeper into the screw hole. The BHS 65 is not worth the $29.50 in my opinion since both bit holders are magnetic which feature I like. Save yourself ~US$9.50 by buying the BH 60 bit holder, or least try it at the store before purchasing. The power of the magnet in the BH60 is sufficient to firmly hold 3/4 inch long Phillips head screws with the drill assembly pointing straight down. This is very handy for installation work.
I agree with you that the BH60 is much better value for the money. I like this one. The magnet is very strong and keeps the bit perfectly in place. I haven't had one pulling out yet while this would happen over and over again with other bit holders I used. And since it is thinner than the BHS65 it is also much easier to take the bit out because your fingers get a better grip on the bit. Before I got this one, I never liked non-locking bit holders. But I like this one very much. I find myself using the BH60 more and more over the BHS65.
PaulMarcel
Online
« Reply #89 on: December 30, 2009, 04:13 AM » |
Joining this thread a lil late... only came up on my recent unread list after the previous posting. I've had on my to-do list the regrinding of a couple drive bits for the C12, which is a relatively recent acquisition. When I read this thread, I said, "oh yeah..." and went to do the grinding much like lcc and Jim Becker mentioned earlier. I have a couple sets of #1 and #2 Robertson drives so I picked one to gently file down the hex corners then work in a ball detent. Maybe 10 minutes for both including finding a file that walked away. Fit like a dream and don't wiggle. I also did the same to the Kreg #2 that came with my pocket screw set... okay, much longer cuz that puppy is made out of diamonds or something, but nothing a Dremel with a grinding bit couldn't hog out. It, too, fits perfectly. Picture below shows, left to right, the Festool drive bit adaptor, McFeelys #1, McFeelys #2, and an unmodified McFeelys #2 and the bastards that did it  Highly recommended.
Visit my blog for Festool adventures Shirt size: L  Twitter: @HalfInchShy
Jim Becker
Offline
« Reply #90 on: January 06, 2010, 03:41 PM » |
The BHS65 works very well...and I'm pretty much dependent on it at this point...but it does extend the length of the drill/driver which reduces the benefit of the Festool tool design.
Alex
Offline
« Reply #91 on: January 06, 2010, 04:52 PM » |
For me, the benefit of the design doesn't lie in the fact that the drill is shorter than others but in the fact that you can change your bit very fast. Most of the time you're not bothered by the length of the drill.
Brice Burrell
Offline
« Reply #92 on: January 06, 2010, 07:59 PM » |
Well, yes that's true. It makes the overall length of drill long longer but compared to using a keyless the size is nearly the same.
Jim Becker
Offline
« Reply #93 on: January 07, 2010, 12:19 PM » |
No question that the adapter isn't much different in length than using the keyless (which has only been on my drill/driver once in about three years). But one of the appeals of the tool is close-quarters work, such as inside cabinetry. I can insert a wire-detent bit into the raw tool to drive in that case, but it's not secure. And I use Robertson/square drive fasteners which have a healthy grip on the bit, so when the fastener is driven, the bit stays in the recess instead of the drill/driver.
I'm sorry, but I really remain bugged by the lack of native support for Robertson/Square Drive fasteners from Festool. They are the preference for many industries as well as thousands of folks who "do this" for fun. It makes no sense to me that the same manufacturers that can produce the more complex bit styles can't also product quality Robertson/square drive bits for an acceptable cost. It sure doesn't seem like Rocket Science to me. Maybe McFeely's will finally realize an opportunity here and produce them since Festool hasn't stepped up since I brought this up years ago.
WarnerConstCo.
Offline
« Reply #94 on: January 07, 2010, 12:33 PM » |
Why make an inferior drive bit when everyone should be using Torx anyways?
Inner10
Offline
« Reply #95 on: January 07, 2010, 02:33 PM » |
Why make an inferior drive bit when everyone should be using Torx anyways? Because they hold the screw better.
WarnerConstCo.
Offline
« Reply #96 on: January 07, 2010, 02:58 PM » |
Why make an inferior drive bit when everyone should be using Torx anyways? Because they hold the screw better.  Get a magnetic tip then.
Jim Becker
Offline
« Reply #97 on: January 07, 2010, 03:14 PM » |
We shouldn't have to change screw formats, especially from a proven design that we like and do not consider "inferior" in any way. I'm not saying that Torx is in any way undesirable for folks who like it. Same thing for other formats. But missing a major and respected recess type from the excellent Centrotec design remains disappointing.
« Last Edit: January 07, 2010, 03:14 PM by Jim Becker »
WarnerConstCo.
Offline
« Reply #98 on: January 07, 2010, 03:27 PM » |
But to them, square drive is inferior. Not many square drives screws across the pond.
I really don't understand the love for a square drive. They always turn into circle drives.
Inner10
Offline
« Reply #99 on: January 07, 2010, 04:02 PM » |
Warner if you want to get into the best its probably the Wurth A-Drive.
As for not being used 'across the pond' you are absolutely correct. I bought a Wera screwdriver and it came with a bunch of Pozi Drives, I didn't even know there were different sizes of Pozi. I never encounter them except on weird European equipment and maby need one twice a year.
I know everything is done on a cost basis, but a little accommodation to the NA market would be nice to see. Not having a drive to support your most popular screw really reduces the added benefit. For me I would love to have one of thier drills for the right angle and 0-space chuck; but they do not offer an impact driver and the centrotech offers no benefit. If I were to go for it I would be carrying around 2 different chargers and 2 different batteries....not worth it.
The second I see an impact driver and centrotech drives I would use I will buy one.
harry_
Offline
« Reply #100 on: January 09, 2010, 05:43 AM » |
I really don't understand the love for a square drive. They always turn into circle drives. Agreed. I love things that I can swear by. It seems that when it comes to square drives & their fasteners is it more like swear AT!
Inner10
Offline
« Reply #101 on: January 09, 2010, 10:29 AM » |
Quote I really don't understand the love for a square drive. They always turn into circle drives.
Agreed. Try holding the drive in-line with the screw and not off at and awkward angle and you will never strip another one.
William Herrold
Offline
« Reply #102 on: January 10, 2010, 07:36 PM » |
I'm "across the pond" here in metricland and I use square drives only because I use Kreg jigs and I can't find the proper screw profile here in Europe. I would be just as happy w/ torx if I could find the proper head shape and thread/shank ratio. This thing has turned into an ugly "Chevy/Ford" argument. I see it as companies forcing us into buying "their product" based on marketing strategy. Next week, Dack and Blecker will release the 4th dimensional anti-gravity drive and the screw will become obsolete.
Jim Becker
Offline
Think twice...write once...
« Reply #103 on: January 14, 2010, 06:21 PM » |
I did cam out a square drive screw the other day while doing some shop rearrangement. Then I realized I had a Phillips bit in the TDK-12. Silly me...
“Never raise your hands to your children, it leaves your groin unprotected.†- Red Buttons
WarnerConstCo.
Offline
« Reply #104 on: January 14, 2010, 06:38 PM » |
GRK's are even distributed out of Canada.
Inner10
Offline
« Reply #105 on: January 14, 2010, 07:54 PM » |
I think Fastenal even stocks them.
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #106 on: February 17, 2010, 01:41 AM » |
I, too, don't understand why Festool doesn't offer square drive (Robertson) bits for Centrotec chucks and holders, but it isn't that difficult to modify bits you can obtain inexpensively from others, as discussed and demonstrated earlier in this thread. It is obviously due to my lack of proper [alignment] technique, but I find that I have a lot more problems driving square drive screws than driving Phillips head screws (genuine Phillips brand) with a genuine Phillips bit. When driving pocket hole screws made by Kreg with a Kreg bit, the bit frequently won't engage the screw or disengages from the screw due to only slight misalignment. My experience with McFeeleys square drive decking screws versus Phillips brand decking screws is similar. The key is proper fitment of the driver bit to the recess in the head of the screw; many of the foreign (Chinese?) manufacturers today don't pay enough attention to the dimensions and tolerances that are needed for reliable connection of bits and screws.
Dave R.
markchamness
Offline
« Reply #107 on: January 04, 2013, 03:09 PM » |
Vi_k
Online
Scenic Carpenter - I.A.T.S.E
« Reply #108 on: January 04, 2013, 06:27 PM » |
Agreed. Try holding the drive in-line with the screw and not off at and awkward angle and you will never strip another one. +1
Have a good one,
Vi_k
C-15 Set, TS-75 EQ, CT-36 E
leakyroof
Offline
« Reply #109 on: January 05, 2013, 12:46 PM » |
Dave R.
I have read that much like Torx screws and their imitators, Robertson screws are slightly different than just plain square drive screws. The taper on the bit has to be a certain angle, and cheap copies don't bother with that for either the driver bit or screw head recess from what I'm told.
GhostFist
Offline
« Reply #110 on: January 05, 2013, 08:14 PM » |
I just wanted to post how much I hate the BHS65 or what ever the heck that over priced piece of garbage is called and how happy i am that ATLAS manufactures excellent quality centrotec Robbies. Though I'm also somewhat upset at ATLAS for selling me to BHS65's because they both crapped out within months.
hockey_magnet
Offline
« Reply #111 on: January 05, 2013, 09:32 PM » |
Dave R.
I have read that much like Torx screws and their imitators, Robertson screws are slightly different than just plain square drive screws. The taper on the bit has to be a certain angle, and cheap copies don't bother with that for either the driver bit or screw head recess from what I'm told. Actually I believe the true Canadian Roberston bit is ALMOST straight edged and are actually sometimes 2 pieces whereas "square drive" bits have more of a taper and are always one piece. The Robertsons do not hold the screws on the bit as well but tend to cam out less than the square drives. Lee Valley mentions this: Lee Valley Robertson bits
Tom Bellemare
Festool Dealer
Offline
« Reply #112 on: January 05, 2013, 11:24 PM » |
I suspect that all modern square-recess heads have tapered internals.
To make a truly parallel-sided, square shouldered impression in steel would almost require drilling and broaching the hole. (1) There are other modern processes but they would be prohibitively expensive for screws.
Considering the strength required, I suspect that the heads of internal square-drive screws are forged or cold formed with a tapered punch of some sort. Inserting anything in a hole without cutting, almost certainly requires a taper on the impregnator.
In the case of Robertsons, I would assume it's a serendipitous advantage. Apparently, when tolerances of the cavity and the driver are tight enough, the tapered surface(s), and there are four, tend to help hold the fastener to the driver.
That same advantage exists with other fastener designs that are more torque intensive. The key is the fastener-to-driver tolerances.
(1) I've worked where we designed holes in steels and, mostly, BeCu and then broached them for 1/4" and 3/8" ("standard") square drives. We could afford to do it because money was of little concern and our manufacturing volume was low.
Andywoj
Offline
« Reply #113 on: January 10, 2013, 09:01 PM » |
If you can find the Robertson bits that use a carbide tip you will find that this style of bit works so much better than the standard steel tip style. Stay away from anything made in China. Andy
fdengel
Offline
« Reply #114 on: January 11, 2013, 01:58 PM » |
