Jim Becker
Offline
Think twice...write once...
« Reply #90 on: January 06, 2010, 03:41 PM » |
The BHS65 works very well...and I'm pretty much dependent on it at this point...but it does extend the length of the drill/driver which reduces the benefit of the Festool tool design.
“Never raise your hands to your children, it leaves your groin unprotected.†- Red Buttons
Alex
Offline
« Reply #91 on: January 06, 2010, 04:52 PM » |
For me, the benefit of the design doesn't lie in the fact that the drill is shorter than others but in the fact that you can change your bit very fast. Most of the time you're not bothered by the length of the drill.
Brice Burrell
Offline
Remodeling Contractor
« Reply #92 on: January 06, 2010, 07:59 PM » |
Well, yes that's true. It makes the overall length of drill long longer but compared to using a keyless the size is nearly the same.
Jim Becker
Offline
« Reply #93 on: January 07, 2010, 12:19 PM » |
No question that the adapter isn't much different in length than using the keyless (which has only been on my drill/driver once in about three years). But one of the appeals of the tool is close-quarters work, such as inside cabinetry. I can insert a wire-detent bit into the raw tool to drive in that case, but it's not secure. And I use Robertson/square drive fasteners which have a healthy grip on the bit, so when the fastener is driven, the bit stays in the recess instead of the drill/driver.
I'm sorry, but I really remain bugged by the lack of native support for Robertson/Square Drive fasteners from Festool. They are the preference for many industries as well as thousands of folks who "do this" for fun. It makes no sense to me that the same manufacturers that can produce the more complex bit styles can't also product quality Robertson/square drive bits for an acceptable cost. It sure doesn't seem like Rocket Science to me. Maybe McFeely's will finally realize an opportunity here and produce them since Festool hasn't stepped up since I brought this up years ago.
WarnerConstCo.
Offline
« Reply #94 on: January 07, 2010, 12:33 PM » |
Why make an inferior drive bit when everyone should be using Torx anyways?
Inner10
Offline
« Reply #95 on: January 07, 2010, 02:33 PM » |
Why make an inferior drive bit when everyone should be using Torx anyways? Because they hold the screw better.
WarnerConstCo.
Offline
« Reply #96 on: January 07, 2010, 02:58 PM » |
Why make an inferior drive bit when everyone should be using Torx anyways? Because they hold the screw better.  Get a magnetic tip then.
Jim Becker
Offline
« Reply #97 on: January 07, 2010, 03:14 PM » |
We shouldn't have to change screw formats, especially from a proven design that we like and do not consider "inferior" in any way. I'm not saying that Torx is in any way undesirable for folks who like it. Same thing for other formats. But missing a major and respected recess type from the excellent Centrotec design remains disappointing.
« Last Edit: January 07, 2010, 03:14 PM by Jim Becker »
WarnerConstCo.
Offline
« Reply #98 on: January 07, 2010, 03:27 PM » |
But to them, square drive is inferior. Not many square drives screws across the pond.
I really don't understand the love for a square drive. They always turn into circle drives.
Inner10
Offline
« Reply #99 on: January 07, 2010, 04:02 PM » |
Warner if you want to get into the best its probably the Wurth A-Drive.
As for not being used 'across the pond' you are absolutely correct. I bought a Wera screwdriver and it came with a bunch of Pozi Drives, I didn't even know there were different sizes of Pozi. I never encounter them except on weird European equipment and maby need one twice a year.
I know everything is done on a cost basis, but a little accommodation to the NA market would be nice to see. Not having a drive to support your most popular screw really reduces the added benefit. For me I would love to have one of thier drills for the right angle and 0-space chuck; but they do not offer an impact driver and the centrotech offers no benefit. If I were to go for it I would be carrying around 2 different chargers and 2 different batteries....not worth it.
The second I see an impact driver and centrotech drives I would use I will buy one.
harry_
Offline
« Reply #100 on: January 09, 2010, 05:43 AM » |
I really don't understand the love for a square drive. They always turn into circle drives. Agreed. I love things that I can swear by. It seems that when it comes to square drives & their fasteners is it more like swear AT!
Inner10
Offline
« Reply #101 on: January 09, 2010, 10:29 AM » |
Quote I really don't understand the love for a square drive. They always turn into circle drives.
Agreed. Try holding the drive in-line with the screw and not off at and awkward angle and you will never strip another one.
William Herrold
Offline
"failure is imminent"
« Reply #102 on: January 10, 2010, 07:36 PM » |
I'm "across the pond" here in metricland and I use square drives only because I use Kreg jigs and I can't find the proper screw profile here in Europe. I would be just as happy w/ torx if I could find the proper head shape and thread/shank ratio. This thing has turned into an ugly "Chevy/Ford" argument. I see it as companies forcing us into buying "their product" based on marketing strategy. Next week, Dack and Blecker will release the 4th dimensional anti-gravity drive and the screw will become obsolete.
"I don't believe anything, but I have a lot of suspicions" R.A.W.
Jim Becker
Offline
« Reply #103 on: January 14, 2010, 06:21 PM » |
I did cam out a square drive screw the other day while doing some shop rearrangement. Then I realized I had a Phillips bit in the TDK-12. Silly me...
WarnerConstCo.
Offline
« Reply #104 on: January 14, 2010, 06:38 PM » |
GRK's are even distributed out of Canada.
Inner10
Offline
« Reply #105 on: January 14, 2010, 07:54 PM » |
I think Fastenal even stocks them.
Dave Ronyak
Offline
Flyin' from NE Ohio
« Reply #106 on: February 17, 2010, 01:41 AM » |
I, too, don't understand why Festool doesn't offer square drive (Robertson) bits for Centrotec chucks and holders, but it isn't that difficult to modify bits you can obtain inexpensively from others, as discussed and demonstrated earlier in this thread. It is obviously due to my lack of proper [alignment] technique, but I find that I have a lot more problems driving square drive screws than driving Phillips head screws (genuine Phillips brand) with a genuine Phillips bit. When driving pocket hole screws made by Kreg with a Kreg bit, the bit frequently won't engage the screw or disengages from the screw due to only slight misalignment. My experience with McFeeleys square drive decking screws versus Phillips brand decking screws is similar. The key is proper fitment of the driver bit to the recess in the head of the screw; many of the foreign (Chinese?) manufacturers today don't pay enough attention to the dimensions and tolerances that are needed for reliable connection of bits and screws.
Dave R.
Friends, family and Festools make for a good retirement. PCs...I'm not so sure.
markchamness
Offline
« Reply #107 on: January 04, 2013, 03:09 PM » |
Vi_k
Offline
Scenic Carpenter - I.A.T.S.E
« Reply #108 on: January 04, 2013, 06:27 PM » |
Agreed. Try holding the drive in-line with the screw and not off at and awkward angle and you will never strip another one. +1
Have a good one,
Vi_k
C-15 Set, TS-75 EQ, CT-36 E
leakyroof
Offline
« Reply #109 on: January 05, 2013, 12:46 PM » |
Dave R.
I have read that much like Torx screws and their imitators, Robertson screws are slightly different than just plain square drive screws. The taper on the bit has to be a certain angle, and cheap copies don't bother with that for either the driver bit or screw head recess from what I'm told.
GhostFist
Offline
« Reply #110 on: January 05, 2013, 08:14 PM » |
I just wanted to post how much I hate the BHS65 or what ever the heck that over priced piece of garbage is called and how happy i am that ATLAS manufactures excellent quality centrotec Robbies. Though I'm also somewhat upset at ATLAS for selling me to BHS65's because they both crapped out within months.
hockey_magnet
Offline
« Reply #111 on: January 05, 2013, 09:32 PM » |
Dave R.
I have read that much like Torx screws and their imitators, Robertson screws are slightly different than just plain square drive screws. The taper on the bit has to be a certain angle, and cheap copies don't bother with that for either the driver bit or screw head recess from what I'm told. Actually I believe the true Canadian Roberston bit is ALMOST straight edged and are actually sometimes 2 pieces whereas "square drive" bits have more of a taper and are always one piece. The Robertsons do not hold the screws on the bit as well but tend to cam out less than the square drives. Lee Valley mentions this: Lee Valley Robertson bits
Tom Bellemare
Festool Dealer
Offline
« Reply #112 on: January 05, 2013, 11:24 PM » |
I suspect that all modern square-recess heads have tapered internals.
To make a truly parallel-sided, square shouldered impression in steel would almost require drilling and broaching the hole. (1) There are other modern processes but they would be prohibitively expensive for screws.
Considering the strength required, I suspect that the heads of internal square-drive screws are forged or cold formed with a tapered punch of some sort. Inserting anything in a hole without cutting, almost certainly requires a taper on the impregnator.
In the case of Robertsons, I would assume it's a serendipitous advantage. Apparently, when tolerances of the cavity and the driver are tight enough, the tapered surface(s), and there are four, tend to help hold the fastener to the driver.
That same advantage exists with other fastener designs that are more torque intensive. The key is the fastener-to-driver tolerances.
(1) I've worked where we designed holes in steels and, mostly, BeCu and then broached them for 1/4" and 3/8" ("standard") square drives. We could afford to do it because money was of little concern and our manufacturing volume was low.
Andywoj
Offline
« Reply #113 on: January 10, 2013, 09:01 PM » |
If you can find the Robertson bits that use a carbide tip you will find that this style of bit works so much better than the standard steel tip style. Stay away from anything made in China. Andy
fdengel
Offline
« Reply #114 on: January 11, 2013, 01:58 PM » |
