Author Topic: Sys1 with drawer.  (Read 10878 times)
Offline adcolor
    • MIkey's Millworks and More
Sys1 with drawer.
« on: September 27, 2016, 01:11 PM »
A Sys1 with a drawer.  I would buy one for my C12.  Perfect for drills and accessories.  I have used a systainer with the top storage lid.  Not worth it, not enough room (I want to put a drill index in it that goes with me and the drill), or have other accessories in it, like common hole saws, etc.  And the lid was an issue due to a broken latch (too fragile for the way I work).
Offline SRSemenza
Re: Sys1 with drawer.
« Reply #1 on: September 27, 2016, 07:46 PM »
Yeah, I agree that size option would be good.  Maybe we will see more drawer combinations down the road.
Offline Steve-Rice
« Reply #2 on: September 28, 2016, 08:30 AM »
I'd like to see a separate drawer unit which could be added to any existing systainer.
Offline ajmdecorators
« Reply #3 on: September 28, 2016, 12:23 PM »
I was thinking this the other day, they really need to bring out a say 1 with a drawer
Offline mrrhum
« Reply #4 on: November 18, 2016, 04:25 PM »
Tanos makes (or used to make?) a single-depth set of drawers in the classic line (not T-Loc, unfortunately). Lee Valley has them at http://www.leevalley.com/US/wood/page.aspx?p=64653&cat=1,43326,68749 . Get it while you can, because it has disappeared from the Tanos products page at tanos.de.
I have one, but I found it to be a nuisance, being non-T-Loc, and ended up just making dividers for a regular Sys I.
What we really need is a T-Loc single-drawer Systainer.
A good craftsman knows enough to buy good tools.
« Reply #5 on: November 18, 2016, 04:33 PM »
Yep me too, want one for my cxs and rts
Offline PreferrablyWood
« Reply #6 on: December 14, 2016, 03:42 PM »
I'd think the Sys combi small version would be the closest solution to what your looking for. A little more space so you could fit a drill and jigsaw would be bad.
RO 150, 850 HL E Planer rustic head standard head angle fence, MFS 400x2, MFS extensions MFS VB 700 x 1 MFS VB 1000 x 2 . CMS GE, sliding fence, VB and 2x VL extension tables, OF 2200, Accessory Set ZS OF 2200 M,36mm 5m antistatik hose, CMS OF+ CMS TS 75 insert modules. SYS-MFT Fixing-Set,  3.5m sleeved hose, Syslite duo, Sys 4 sort 3 x3, Sys Roll, Sys 1 Box x2 , classic Sys 3-Sort 4, classic Sys 3 Sort 6 x2, Sys Cart x3 Systainer 4 x2  as toolbox with selfmade inserts Systainer 5 as toolbox with insert.
Festool 18V HKC 55 Li 5.2 EB Plus FSK 420,FSK 250, Extra blade for the HKC 55 W32.TI 15, CXS 2.6 Ah version, RO 90 DX, PDC 18/4 plus DC UNI FF depth stop chuck,AD 3/8 square socket holder FF chuck, Centrotec Bits; -->Bit holder and bit selection BHS 65 CE TL 24x, ,Bradpoint DB WOOD CE SET ,Zobo (Forstner) D 15-35 CE-Zobo SET ,Masonary/stone bits DB STONE CE Set,Extender BV 150 CE, Countersink QLS D2-8 CE Hook turner HD D18, end centrotec<--.  TS 75 EBQ, PSC 420, OF 1010, RS 300 EQ, CTL Midi, MFT 3, Parf dogs x2pair +Bench dogs x2pair, FS 1080, FS 1900 .  will get Domino DF 700 XL,  CMS insert BS 120 Belt sander.
Offline ben_r_
« Reply #7 on: January 25, 2017, 11:45 AM »
Yea Id like to see such a combo offered too.
Offline DiscoStu
« Reply #8 on: February 18, 2017, 04:19 AM »
I'd like to see either a Sys 1 with a Drawer or a Sys 2 with a Sys 1 top and a drawer underneath. The option of a Sys 1 size drawer would be very flexible for a lot of uses.
Offline jdw101
« Reply #9 on: May 01, 2017, 10:26 PM »
Great idea, could have all kinds of sizes.
Offline Luzzy
« Reply #10 on: May 26, 2017, 05:22 AM »
I use Systainers for my everyday hand tool storage. I would LOVE having sys 1-5 drawer options , especially with two larger drawers in a 3 or 4. Something with twice the height of the current combi's.
It would make my mobile stack so much fore user friendly !!!
Offline Bob D.
« Reply #11 on: May 26, 2017, 05:48 AM »
I like the sound of this. You could add a drawer into a stack wherever you wanted to and
it would be semi-permanently attached to the Sys above it in the stack. Meaning it would
mount to the underside of a Systainer with a more secure latch than the T-latch.
Then whatever tool you have you could add a drawer (or two) for accessories used with that
tool. A single drawer unit with dividers and deep enough to use the little storage boxes would
be great. I would get one for the router to hold bits, one for the drill for all sorts of accessories
as well as screws, and at least one or two more for miscellaneous bits and small hand tools.
« Reply #12 on: May 30, 2017, 12:41 PM »
This is a great idea and thinking it over it is even more practical than one might think at first.
I have a plethora of drills - too many perhaps. It is a slight nuisance to keep track of some specialty bits and pieces for the drills when I bring the "right one" for the task at hand. A single drawer unit would sort it out by simply having all the bits and small pieces separate in a SYS Drawer and then simply add whatever drill I need for the day.
I know there is a Centrotec kit but it does not have all I use and too much that I don't. I prefer building my own kits.
I have been entertaining the idea of making a few inserts and have a SYS 1 with my own stuff. But - a drawer is just that much nicer in use and could be kept permanently at the bottom of the stack/pile/tower.
DSC-AG Grinder,  RAS 115
Drills: T18, BHC18, CXS.
SysLite KAL II, SYS Rock.
Sys- and Sortainers galore.
