Author Topic: How do I insert an image in a PM?  (Read 1732 times)
Offline ear3
« on: April 12, 2017, 08:31 AM »
Title says it all.  There's no attachment feature as with a forum post, and when you click the image icon, it creates html codes  (mg) (/img) {I used parens rather than square brackets so it will display} is there something I'm supposed to insert between those codes?
Kapex KS 120 w/UG Cart and Extensions • CXS Set • T18+3 w/Centrotec Installer's Set • PDC 18/4 • TS 75 • TSC 55 • HKC 55 w/250, 420 and 670 FSK rails • Carvex 420 w/Accessory Kit • Domino 500 Set • Domino 700 XL • OF 2200 w/Base Accessory Kit • OF 1400 • OF 1010 • MFK 700 EQ Set • LR 32 • MFS 400 w/2000, 1000, and 700 extensions • Rotex 90 • Rotex 150 • LS 130 • ETS-EC 150/5 • ETS 150/3 • Pro 5 LTD • RTS 400 • RAS 115.04 • RS 2 • HL 850 • Vecturo OS 400 • CT 26 w/Long-Life Bag • CT Sys w/Long-Life Bag • MFT/3
Offline Alex
Re: How do I insert an image in a PM?
« Reply #1 on: April 12, 2017, 08:37 AM »
You have to paste an image url between those codes. I don't think you can attach an image to your post directly like an email attachment, but you can link to a picture that's hosted somewhere on the net and use its url. The picture is then displayed inline in your pm like with a normal webpage.
Offline SRSemenza
« Reply #2 on: April 12, 2017, 09:49 AM »
Yup.
Offline Untidy Shop
« Reply #3 on: April 12, 2017, 07:58 PM »
As most here have their images stored either on the cloud or hard drives both of which rarely have URL links, perhaps @TylerC  could consider adding the post type image linking to PMs as well when the FOG 'revamp' takes place. I have often wanted to add images to PMs. As they say, a picture is worth a 1000 words.  [big grin]
